Old 12-22-2014, 04:43 AM   #15
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by myioz86 View Post
since i have found out there is no check valve in the manifold and have since put one in there the boost on my car has gone up about 1.5pounds and is pulling even harder than before.now all i have to do is build a 3" mid pipe with high flow cat and see if i can get some more "boost" out of this thing "ye haa".
Did you mean the manifold fitting that runs to the rear PCV? Or the fitting that goes to the brake booster?
Can you show a picture of how yours is set up?
Fizz is offline   Reply With Quote
Old 12-22-2014, 04:48 AM   #16
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
On your sprintex setup it's gonna be like this: pcv line from the block goes to the catch can inlet, catch can outlet line then hooks to a check valve and then to the middle port on the back of the supercharger elbow.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 12-22-2014, 04:51 AM   #17
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Okie dokie
Old 12-22-2014, 01:50 PM   #18
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
Would this work the same way for a turbo charged ? same set up catch can from crank to inlet & outlet to port under the AC compressor
Sent from somewhere
PolishFrs13 is offline   Reply With Quote
Old 12-22-2014, 02:13 PM   #19
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
For style: Boomba Check Valve
alexand3r is offline   Reply With Quote
Old 12-22-2014, 06:16 PM   #20
myioz86
Drives: gt-86 2013
On mine i put the 1/2" plastic ckeck valve between the manifold and the catch can that way you dont have boost getting into catch can and on the hose coming from under the aircon you dont need a chech valve .
myioz86 is offline   Reply With Quote
Old 12-22-2014, 06:21 PM   #21
myioz86
Drives: gt-86 2013
There is supposed to be a check valve on the brake booster line but i have not pulled it off and checked if i can suck air out of the manafold yet . will check on the weekend and see.sorry no photos.
Old 12-22-2014, 06:37 PM   #22
PolishFrs13
building life
I run the FBM catch can.. Gonna put a check cable on hose coming from under the manifold to catch can & see if it works
Sent from somewhere
Old 12-28-2014, 05:15 PM   #23
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
What about putting a small air filter on the catch can and capping the manifold? Would there be any negative effects from this (maybe smell)?
Old 12-28-2014, 06:25 PM   #24
Rosticles
Drives: 1966 Mustang, 2013 FR-S
That is called a vent to air catch can. The main negative being that you don't get the vacuum pull on your pcv line, which helps flow and seals do their job.
Rosticles is offline   Reply With Quote
Old 12-28-2014, 06:26 PM   #25
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
That's a VTA catch can. I run it like that and use the intake manifold port for vaccum/boost signal.
Old 12-28-2014, 06:27 PM   #26
PolishFrs13
building life
anyone know if this fixes the evap P0441? I receive my check valve tomorrow & will plug in hose from block to catch can (inlet) & one for outlet
Sent from somewhere
Old 12-28-2014, 06:27 PM   #27
myioz86
Drives: gt-86 2013
Allready tryed caping the manifold but the engine dosent like it idle is up and down, when you decelarate throtal body closes and the engine needs air for idle so it sucks through manifold and out of crank,metered air.when accelarating check valve closes and the other port under air con is used for crank venting again metered air. dont think car likes having a open vented crank case as it muckes with computor and metered air in engine .
Old 12-28-2014, 06:35 PM   #28
Sportsguy83
Drives: Limited BRZ
I think there's a chance you didn't cap the manifold well and had a leak, as I have not had the PCV connected to the manifold for 12K+ miles with no issues.
PCV valve leaking? jamesm Forced Induction 24 12-25-2014 06:38 PM
Fumoto valve in the winter? Muskokan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 02-25-2014 12:06 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 01:47 AM
FS: Synchronic Diverter Valve Kit FReSh_86 Engine, Exhaust, Bolt-Ons 0 11-26-2013 02:21 PM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 09:42 PM
