Old 12-05-2014, 01:11 AM   #15
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by bren5279 View Post
Ok I see both, the bottom one is completely pressed and the top one doesnt even touch when the clutch is released. And when pressed the bottom one doesnt touch at all and the top one is pressed in... seems right to me
That little white protrusion needs to be completely pressed in by the white circular pad when you release the clutch pedal. I presume your new clutch doesn't allow the pedal to return all the way up... or something...
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 12-05-2014, 01:17 AM   #16
bren5279
Drives: series.blurrr
Just checked the neutral switch. Grounds when neutral so seems to work fine
Yeah it's completely in. Like allllll the way completely flush with the plastic stop. Matter o fact I have it all the way out so that's basically what's stopping it from coming back any further.
bren5279 is offline   Reply With Quote
Old 12-05-2014, 02:39 AM   #17
chas3wba0
chas3wba0's Avatar
Drives: Yes
Huh, I'm out of ideas then. On another note, if the clutch pedal isn't able to come up all the way, it might allow some slippage
Old 12-05-2014, 03:12 AM   #18
Poodles
Drives: 2015 Series.Blue
Here's the official procedure:
(1) Perform cruise cancel conditions diagnosis.
Perform the diagnosis according to displayed cancel code.
(2) Perform the data list diagnosis.
Check the input signal of cruise control system.
(3) Check the cruise control command switch.
Perform the diagnosis according to the Cancel Code 11.
(4) Check stop light switch and brake switch.
Perform the diagnosis according to the Cancel Code 12.
(5) Check the neutral position switch.
Perform the diagnosis according to the Cancel Code 14 or 62.
(6) Check vehicle speed sensor.
Perform the diagnosis according to the Cancel Code 22.
You'll need a more powerful diagnostic tool to read the codes usually
I'd be inclined to think it was the vehicle speed sensor as it would have been unhooked when the transmission was dropped.
Old 12-05-2014, 11:21 AM   #19
bren5279
Just got back from stealership. I dont know what he did with the subaru diagnostics but its working now. Not really sure what he did but can't complain since I didn't get charged…
Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!) bren5279 Issues | Warranty | Recalls / TSB 44 07-03-2017 09:36 AM
DIY : install cruise control system (CCS) aagun DIY (Do-It-Yourself) Guides 10 02-06-2016 12:23 PM
install cruise control coz for me roll connector / steering sensor fail aagun Issues | Warranty | Recalls / TSB 15 11-14-2013 10:29 AM
Cruise control notout86 Scion FR-S / Toyota 86 GT86 General Forum 50 05-13-2013 03:01 AM
