Old 12-01-2014, 08:19 PM   #15
shif7i7down
Erected Member
Drives: frs
Originally Posted by Dipstik-sportech View Post
Noob with a turbo this should be fun...... Google man it will explain everything.
Everybody's gotta start somewhere.
shif7i7down is offline   Reply With Quote
The Following 7 Users Say Thank You to shif7i7down For This Useful Post:
Boofneenee (12-01-2014), CSG Mike (12-01-2014), Guff (12-15-2014), Koa (12-01-2014), R2RO (12-03-2014), raven1231 (12-01-2014), Tye300 (12-02-2014)
Old 12-01-2014, 09:46 PM   #16
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Originally Posted by shif7i7down View Post
But wouldn't the bottle neck be the throttle body and not the turbo? You would think that a 20g turbo could do 16psi... ehhh. Shows what i know lol
But yeah, i see your point thou...
Guess i didn't have to worry about shit hitting the fan if i can't even boost that high.
learning myself as well. Mike's example of fire house vs faucet is maybe not so much about describing a restriction as it is output. Think of sitting in front of a small fan and a large fan both spinning at the same rpms. The larger fan is going to provide more flow.. right? Their are of course pros and cons to using either turbo size.
In a different discussion, another member gave you an example using straws with different diameter sizing. This is a better example of restriction because air needs to come in and out. While the throttle body may be a "restriction" by your definition, it is still only but a super small part of the piping taking air in and taking air out. 3" exhaust piping is better than 2.5" piping for an FI car. The larger the piping the easier it is for those hot exhaust fumes to exit the car and keep the heat away from the engine which can cause increased cylinder temps, etc.
Engine needs to breath. Combustion needs to happen. The question is how much energy can you get out of it without blowing stuff to pieces.
How is the SBD on your car? you still gitty when you drive? I think its a great buy and if i was more mechanically inept I would do the same!
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following User Says Thank You to Boofneenee For This Useful Post:
shif7i7down (12-01-2014)
Old 12-01-2014, 09:57 PM   #17
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Read This: Compression Ratio - Boost 101
Now with a really high compression ratio and your tuner will need to remove so much timing advance (on pump fuels, 91-93 octane) it over negates the effectiveness of the boost, in turn lowering your overall power output.
If you are running E85 though then there is a major benefit to higher compression and more boost. That is where the fun begins.
Cheers,
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
CSG Mike (12-01-2014), Frogamazog (12-03-2014), shif7i7down (12-01-2014)
Old 12-01-2014, 10:04 PM   #18
Fastbrew
Drives: 2014 Pearl White BRZ
All boost wears a car down faster. The question is - how do you define "safe"? By its very nature you are going to cut down on the engines life by boosting. I figured 10-12psi of boost out of an AVO getting about 300HP on 92 pump and lasting at least 4 years was "safe".
Fastbrew is offline   Reply With Quote
Old 12-01-2014, 10:11 PM   #19
DeliciousTuning
Until the details of how the FA20 engine breaks down when pushed to the limits is really well understood I do not think anyone will really ever know. That will take some years to determine and when a couple companies have invested a lot of R&D into understanding those limits.
We have pushed stock Subaru STI engines to 600whp but found even if the smallest thing was off that was the end of the engine almost instantly. How you drive the car, how you maintain the car, how the engine was built from the factory (on a Monday morning or Friday afternoon), etc... will all have an impact especially at higher boost levels on a vehicle never intended for boost.
So to say there is a "safe" number is really unknown. We have had completely stock FR-S cars fail because the cam sensor was aligned incorrectly from the factory, while we have 500+whp stock engines on E85 running strong day in and day out.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Sportsguy83 (12-10-2014)
Old 12-01-2014, 10:15 PM   #20
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
I ran 16 PSI on E85. And my car was a daily. I beat the snot out of it every day. 471hp and 368Tq had no issues or any signs of the motor messing up. Was i sacred the motor might blow? Yes, but after the first oil change i went crazy and never looked back. Its a chance you take. Motors blow on low boost just as well on high boost. A good tune and a good setup will carry a long ways. long as you dont have a lemon motor.
471whp/368TQ@16lbs. BW EFR 7064 recently sold
Fabron757 is offline   Reply With Quote
Old 12-01-2014, 10:15 PM   #21
shif7i7down
Erected Member
Drives: frs
The sbd kit feel awesome, this being my first turbo car, I'm loving the boost. Btw, the install wasnt hard at all, the last thing i did that was "technical" was install brake pads or i guess installing the phantom sc lol. But i did the turbo kit install by myself and took pictures with my Smartphone Just so i remember how everything goes back together, it took me roughly 12hrs totally.But if i had to do it again i think i can probably do it in half the time from start to finish.
The Following User Says Thank You to shif7i7down For This Useful Post:
Old 12-01-2014, 10:17 PM   #22
Fastbrew
Cheers,
William Knose
Indeed - the dice are alive.
Old 12-01-2014, 10:26 PM   #23
shif7i7down
Erected Member
Drives: frs
Just a little background on my car, the reason i want a bit more power is because i recently installed a 3.73 final drive differential from a IS300 and the car feels a bit sluggish compared to the mfactory 4.67 final drive that i had. So i thought that by improving the power i would be able to utilize the taller final drive more effectively. Hence why I'm asking all these "noob" questions.
Old 12-01-2014, 10:40 PM   #24
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
There's no point in pulling the motor to do head studs and head gaskets, but not doing pistons/rods. I ran 20psi on e85 with an avo kit for a while. Then I went with a built motor with a bigger Turbo/kit
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
shif7i7down (12-02-2014)
Old 12-01-2014, 11:22 PM   #25
Fabron757
I thought the 3.73 final drive would feel faster since you don't have to shift as fast. So people with a good size turbo reap the benefits. I'm actually looking for the 3.73 final drive.
Old 12-01-2014, 11:56 PM   #26
shif7i7down
Erected Member
Drives: frs
On the 3.73 2nd gear feels like 3rd, and 3rd feels like 4th, but yes the max wg boost is reached faster on the 3.73 but once Max boost is reached (7psi) acceleration on the 4.67 feels So much faster, only bad part is you have to shift. Into 5th gear at 90mph
Old 12-02-2014, 12:08 AM   #27
spitfire481
Drives: 2JZ FRS
I can do 137@8000rpm with my 26" rear tires and the 3.73 in 4th. That's with the new setup. With the avo kit the stock 4.10 rear wasn't too bad. I shifted at like 7000rpm with that setup. Boost/power drop was pretty bad up top with that small turbo
MoTeC
Build Thread
@spitfire481
Old 12-02-2014, 04:02 AM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
ahh I have had that website bookmarked for quite sometime, @DeliciousTuning, good read.
if your okay with following some math, this website will help too; Warning, since the work is done in grey colored font on a black backing, you may want to highlight it to see it.
http://www.enginelogics.com/read-a-t...ompressor-map/
The Following User Says Thank You to cdrazic93 For This Useful Post:
Safe amount of boost on stock engine? Octane Forced Induction 51 12-06-2017 07:25 PM
Open Flash Tablet + E85 = Safe for a STOCK CAR?? ScionFrsFan Engine, Exhaust, Transmission 55 03-13-2015 12:25 PM
How much spacer is safe on stock rear studs? wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 12-27-2014 01:49 AM
Greddy Turbo Kit FRS Dynojet Results: 334hp 293tq 93octane @16psi R/T Tuning Forced Induction 16 06-20-2014 11:25 AM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 01:12 PM
