Old 12-01-2014, 03:45 PM   #15
viscositosis.rex
Drives: Currently 2018 Taco
VW put a snorkel on their dsg fluid drain plug. It's complicated.
viscositosis.rex is offline   Reply With Quote
Old 11-26-2016, 07:11 PM   #16
cjny
Drives: 2016 BRZ
Did my first oil change with Fumoto valve today. Sweet!
I was in no hurry and let it drip for a long time - probably 90 minutes. It was surprising how long it took before dripping stopped, even though the oil was quite hot when the valve was opened. Then I removed the valve to see how much more oil dripped out. Answer: slightly more than a tablespoon.
If that much old oil left in the pan is sufficient to keep you from using the Fumoto valve then you should let your car drain for the better part of an hour after you remove the drain plug, otherwise you are doing no better.
cjny is offline   Reply With Quote
Old 11-26-2016, 07:30 PM   #17
radroach
Drives: car
Thanks @cjny I was wondering how much would stay in the pan from the fumoto install.
I'd guess there's plenty more oil that stays up throughout the rest of the engine after you drain oil, or at least from my observation because apparently oil capacity is 5.7L, and I'm plenty overfull after about 5.4L on a regular oil change using the normal drain plug.
Old 12-02-2016, 05:07 PM   #18
cjny
Drives: 2016 BRZ
One of the advantages of the Fumoto valve I've never seen mentioned is that you can easily drain the oil when at full operating temperature. Hot oil drains more quickly and thoroughly, more than making up for the tiny bit that the valve might trap in the pan.
This might not seem like much to those who have access to a lift, but if you crawl under the car to drain then the Fumoto seems awfully nice. Not even a drop touches your hands or tools.
The Following 2 Users Say Thank You to cjny For This Useful Post:
2point0 (12-03-2016), why? (12-09-2016)
Old 03-17-2017, 01:03 PM   #19
reeves
OP, if you're still worried about a ~tablespoon of old oil left in the engine, just do what I do:
1) Change your oil more often (every 2.5K-3.5K miles)
2a) Quickly jack up & down the passenger side of your car to shake every bit of oil out of the engine, then 2b) Push the car side-to-side & up-down (yes, while its jacked up).. you'll see a tiny bit more drip out
reeves is offline   Reply With Quote
Old 03-17-2017, 01:33 PM   #20
humfrz
Well, yes, of course, after the car slips off the jack, and you are trying to get the jack out from under the car to jack it back up, naturally more oil will drain out .......
Today is pick on ol @reeves day .......
humfrz
wulfstan (03-17-2017)
Old 03-17-2017, 02:06 PM   #21
reeves
I was being a little sarcastic on the 2nd suggestion, but he gets the idea lol
The Following User Says Thank You to reeves For This Useful Post:
humfrz (03-17-2017)
Old 03-17-2017, 02:50 PM   #22
mhughett
Drives: 2015 Crystal White BRZ Limited
Originally Posted by mav1178 View Post
So you can sleep better at night, the stock Forester plug vs Fumoto:
Honestly, just don't think about it. You're better off monitoring your oil levels regularly than worrying about every last drop.
-alex
This cannot be the fumoto valve replacement for this drain plug. The diameter of the fumoto threads is much larger than that of the standard drain plug.
mhughett is offline   Reply With Quote
Old 03-17-2017, 02:59 PM   #23
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I never said it was.
It was meant to illustrate the length of the threaded portion that goes into the pan. See the exposed thread on the stock one vs the Fumoto? Its's basically like 2mm of extra thread into the pan when you run the Fumoto.
-alex
Old 03-17-2017, 03:02 PM   #24
reeves
If anyone's interested, this is the correct one (F-108) for our cars: https://www.amazon.com/gp/product/B003VCCUJI/
See there, @humfrz, I can be non-sarcastic and helpful once in a while..
Old 03-17-2017, 03:09 PM   #25
humfrz
OK, you're off the hook ....... for today ......
humfrz
reeves (03-17-2017)
Old 03-17-2017, 03:24 PM   #26
Ultramaroon
not playing cards
Ultramaroon's Avatar
To everyone who sweats an ounce or two of old stuff, consider how much stays behind in an oil cooler.
No worries.
Old 03-17-2017, 03:32 PM   #27
reeves
No, seriously.. shake the car while it's jacked up from the passenger side. You can see the oil dripping faster afterwards.. it works!
I mean, not speaking from experience.. but I saw a friend do it once. He had the exact same mileage and mods as me too.
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Transmission fill and drain plugs goshem Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 07-27-2014 01:37 AM
GROUP BUY: Fumoto Drain Valve Simon99 Mechanical Maintenance and Tools 8 03-28-2014 07:27 PM
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 06:18 PM
