Old 07-06-2015, 11:06 AM   #15
Ben_G
Drives: Blue BRZ
Originally Posted by Ben_G View Post
So did you get this fixed? I've got just over 50k km on my BRZ and it just started to do exactly the same thing you described when leaving reverse and staying under 5-6. Sometimes I get caught up trying to shift from 2-3 if I don't specifically guide the stick.
Took it to a dealer today and they said that it's "nothing to worry about" and that I should try changing to transmission fluid because "I have high mileage" ???
Ok, not sure if anyone is still following this, but i got my problem fixed. It was rust on the linkage between the shifter and the transmission. The dealer had initially checked to see if the shifter pivot ball was greased (it was) and decided to try replacing the entire shifter assembly. When they removed the assembly, they saw the rod linkage was rusted. Replaced that and it's free moving again.
Ben_G is offline   Reply With Quote
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
Kart boy shifter issues boxer2.0 Engine, Exhaust, Transmission 11 10-25-2014 01:47 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
Kartboy Short Shifter Issues Yruyur Engine, Exhaust, Transmission 13 01-27-2014 01:19 AM
