Old 08-23-2014, 02:49 AM   #15
NickDC88
NickDC88's Avatar
I never down shift into first. Just use the brakes.
NickDC88 is offline   Reply With Quote
Old 08-23-2014, 02:53 AM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by dray551 View Post
Is this a safety feature or is theresomething wrong?
Something is wrong: your driving technique.
To drive a manual transmission is easy.
To drive a manual transmission well is hard, until you understand how a transmission changes engine speed (RPM/crankshaft rotation speed) into wheel speed (input shaft > gear > driveshaft > axle > wheel speed).
Let's say your RPM in first gear is 2500 when you are at 10MPH. You will need to make sure your engine RPM is at 2500 when you attempt to downshift into first gear at 10MPH, otherwise you will just grind gears and do stupid things.
In this case, find a competent manual driver or watch more YouTube videos to fix your problem. No amount of internet advice via text will help.
-alex
Old 08-23-2014, 03:54 AM   #17
ZionsWrath
Thanks
ZionsWrath's Avatar
How I do it
If coming to a complete stop just leave it in whatever gear it's in. When I am close to complete stop clutch in and neutral.
If coming to slowed traffic brake and leave it in gear until I reach the slower speed. If I have to drop 1 gear I rev match. If 2 ormore gears I double clutch rev match.
Identifying every gear doesn't seem beneficial in my opinion.
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
hotpanda1 (08-26-2014), Jyn (08-24-2014)
Old 08-23-2014, 04:27 AM   #18
noodlebaka
Drives: '13 FRS
If you're trying to stop, throw it into neural. If the light turns green while you're braking/coasting, throw it into second.
noodlebaka is offline   Reply With Quote
The Following User Says Thank You to noodlebaka For This Useful Post:
Old 08-23-2014, 04:42 AM   #19
unlimited86
Drives: s2000
Seems like you need to change your driving technique, if its not letting you shift into 1st while moving above 10mph..theres a reason to that. The fact that you still force it in..I feel bad for your synchros. Listen to others.
unlimited86 is offline   Reply With Quote
Old 08-23-2014, 06:19 AM   #20
swpbrz
Drives: swp brz limited
First is the trickiest to rev match for me. It depends alot on how warmed up the engine is. You probably don't need to for stopping at a light. My trick for learning was findin a street I could cruise slowly on. After the car is fully warmed up. Drive in first at 10mph and note what rpm you are at. then shift to neutral and coast a bit let the rpms go to idle. Then blip the throttle to just above the rpms you noted earlier and shift NORMALLY and smoothly into first. If its locking you out don't force it. Try another blip and shift. A proper rev match shift to first should feel buttery smooth when the engine is warm. Its the hardest gear by far to get the feel for.
I sort of had a cheat sheet at first 15 to 20 mph needs like 4.5k rpms and a warm engine to snick in smoothly.
swpbrz is offline   Reply With Quote
Old 08-23-2014, 07:51 AM   #21
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
This is habit of mine. I always shift into 2nd before going to 1st regardless of the situation. Try it. It shifts a lot smoother this way. If at a stop and in neutral. I shift to 2nd .... Then easily into 1st. If rolling to a stop .... I typically downshift and use engine breaking a little, or coast in neutral .... But when I come to a stop .... 2nd gear and then 1st.
Braces is offline   Reply With Quote
Old 08-24-2014, 05:15 AM   #22
Stigmaru
Stigmaru's Avatar
Drives: 2022 Halo White GR86
There aren't very many situations where you need to shift to 1st gear while rolling to near stop unless you for whatever reason need to go right away to beat some other car or something.
But if you must do it, you need to clutch in and blip the throttle or do a double clutch down shift into 1st.
Stigmaru is offline   Reply With Quote
Old 08-24-2014, 06:25 AM   #23
paulca
Drives: Toyota GT86 Coupe Red (UK)
I agree with others, the car is telling you something. It's saying "Don't put me into 1st yet!". I would listen to it.
You can stop in any gear, there is on need to rally shift down the box, it's not a sequential. Block shifts are fine. 6th can be a bit difficult to stop in as you would need to clutch down at 25mph to prevent under reving. So an intermediate downshift to 3rd or 4th is wise.
The term some instructors here us is, "Gears to go, brakes to slow".
Of course this changes if you are "hooning it". I selected first for a hairpin bend the other day at about 20mph while deep on the brakes. A little throttle blip and then 'listen' to the synchro and what it's telling you, ie. don't force it! Push it against the synchro lightly, it will resist a little until it's ready then it will pop in.
You have to consider the shafts in the gearbox, if you are making a big rev change. If you were in 4th at 20mph, then your engine and gearbox speed would be low, around 1k. You then clutch it disconnecting the engine from the transmission and pull it out of gear. Now a large portion of the gearbox is spinning idle, connected to nothing. It is still spinning for 1k rpm (and slowing). You try and select 1st. The synchro has to spin that idling shaft up to road speed for 1st which at 20mph is about 5k. The shafts are not that heavy, but the synchros are small, so you have to give it time. Forcing it will make it grind.
The same happens the other way around if you red line it in 2nd and then (as that brings you to the speed limit here) select 6th to cruise. Engine speed 7.4k, required RPM for 6th at 60mph, 2k. So you are asking the synchro to synchronize a shaft at an equivalent 7.4k rpm with a shaft at an equivalent 2k rpm. You need to be patient with it. Hold it lightly against the synchro, don't force it, it will select when ready.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 08-24-2014, 08:36 AM   #24
ZionsWrath
Thanks
ZionsWrath's Avatar
If I redline second to merge I shift 3-4-5-6. I feel it helped me learn to be quick but smooth with the clutch.
Old 08-24-2014, 10:38 AM   #25
tennisfreak
Drives: 2018 BMW M240i
Holy shit.
"Why wont this square peg fit into this round hole?, I ram in in there but it just don't wanna go!".
The Following User Says Thank You to tennisfreak For This Useful Post:
Sideways&Smiling (08-24-2014)
Old 08-24-2014, 11:08 AM   #26
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Learn to stick...
First, learn how the gears in a manual transmission work, and how synchros work.
Second, don't force anything, you'll break things.
Third, It's not going into first because the gear speeds don't match up, you'll need to revmatch, double-clutch, or sequentially downshift.
Alternative solution: just leave it in neutral. =P
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 08-24-2014, 02:05 PM   #27
radroach
Drives: car
The input shaft is still spinning.. Putting it immediately in 1st causes it to come to an abrupt stop. Don't go 4th to 1st like that so fast. Downshift to lower gears and clutch in at a low speed / low rpm about 10 - 5 feet before the stop sign. Wait 1/2 second and then go into 1st. You're not driving very efficiently by clutching in from 20 mph all the time. Try clutching in at 10 mph in 3rd gear instead.
Otherwise, if you need to throw it into 1st at 10-15 mph (like during autocross racing) then you'll need to double-clutch.
Old 08-24-2014, 02:05 PM   #28
paulca
That's what synchros are for. Rev matching with the engine does nothing as the clutch is down the engine is not even connected to the gearbox. You rev match simply to prevent a lurch on a down change that might destabilise the car. So only really necessary when at the very limit.
Double de-clutching is a technique associated with very, very old cars with no syncros, so you had to reconnect the engine to the gearbox while in neutral, spin the shafts up the new gear road speed and then re-clutch to select the gear. Completely unnecessary today as the syncro's will do a far better job. You just have to give them a little time and not get impatient and force them.
In the OPs scenario double declutching, ie. clutch in, neutral, clutch up, throttle blip to 5k RPM, clutch in, select 1st, *might* make it easier if done correctly, but it would take him a lot longer than just waiting on the syncro.
If you try driving along at 30mph, put the clutch down and hold the shifter lightly against 1st and listen, you will hear and asscending whine as the gearbox spins up to effectively 7k rpm. It's a pretty cool sound, but I wouldn't recommend doing it all that often. Though if your brakes ever fail on you, you can always use 1st gear and the clutch for brakes.
shifting from 1st to 2nd jarviz Scion FR-S / Toyota 86 GT86 General Forum 35 05-26-2016 07:15 PM
shifting into 2nd cantaloupe BRZ First-Gen (2012+) — General Topics 63 06-23-2014 04:47 PM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
2015 86/BRZ vs 2015 Eclipse botbs FR-S / BRZ vs.... 55 04-16-2014 04:07 AM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
