Drives: 2015 Scion FR-S
Please help! shifting for 2015 frs
Hey everyone, so last month i bought a 2015 FRS Manual and i must say i love the car. however this has happened several times to me. When i am braking coming to a red light usually in fourth gear trying to come to a complete stop stop, at around 20 mph i keep the clutch to the floor and attempt to shift into first, however when i try to shift into first it wont let me and i have to FORCE it in and it makes a grinding sound and my whole shifter shakes. this only happens when i am trying to shift into first at a high speed coming to a complete stop. I have my clutch to the floor the whole time im not taking the clutch out at all. Is this a safety feature or is theresomething wrong? thanks everyone
#2 | |
Drives: 2019 BMW ///M4
Or in your case-- Clutch in, Down to third, clutch out, brakes, clutch in, down to 2nd, clutch out, brakes, clutch in and then fully come to a stoop. Can you shift into 2nd instead of 1st?
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
Drives: 2013 MT FS FR-S / 07 GT500
I would avoid trying to downshift into 1st while moving, use 2nd if need be and move it into 1st once stopped...
Stage 1 V2 .57trim Turbo Kit, ACT HD6P Clutch w/Streetlite Flywheel, Greddy EVO3
391whp/295tq 13psi 96 pump 335whp/260tq 10psi 93 pump |
The Fail Boat
Drives: CWP S.B.
1. Don't force it,
2. First gear is usually for dead stop/ below 10 mile only 3. Did you rev match? It's not going in cuz synchro don't like it. |
#5 | |
Drives: 2015 Scion FR-S Halo
Drives: 2013 GBS BRZ Limited
I was taught to never downshift into 1st and to wait until at a complete stop.
Back then it was because 1st gear did not have any synchros. I dont know about this trans. |
Drives: Whiteout FRS
Whenever I'm coming to a stop and I'm dropping from 20mph and below, I usually like to throw it into second. I usually blip the throttle (around 2.5k rpm) for a smoother transition. Hope this helps.
Drives: 2023 Subaru BRZ
I don't see the need to shift down especially when you're in 4th rather than 6th, you can change down to 2nd but I'd rather just coast in gear. I'd simply slow down and if you're certain to stop, neutral before the engine lugs. If the light changes green before getting to a stop, go to 2nd and be in your way. The only speed I'd ever shift down to 1st is less than 15 km/h or 9 mph to prevent 2nd from lugging likely the reason there isn't a 1st gear lock out.
Drives: FRS
going to 1st is unnecessary when slowing down. if you HAVE to shift to 1st when slowing down, rev match your rpm to whatever speed you're at and then it should snick in to 1st easily.
#10 |
Don't force it into first. I can only get the car while moving into first between 8-10MPH max. Just coast or use 2nd if you want to stay in gear.
#11 | |
Tire Destroyer
Drives: Firestorm+snail
#12 |
Drives: Panda FR-S
Yeah, Like everyone says, if you are cruising below 12 mph you can safely throw it into 1st. Anything above that will require a double clutch to go into 1st safely.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#13 |
The Angry Brit
Drives: 1991 E30 318iS
Totally agree with all the above posts! Please don't down shift into 1st at 20mph, it's a terrible idea. 1st gear is designed to be a "get you going" gear. Once you're rolling you can immediately transition to 2nd.
And if you are coming to a complete stop, wait until you are stopped before putting it in 1st, if the light turns green and you are still rolling, even at like 3mph, 2nd is the gear for you. Unless you like hauling ass everywhere. If that's the case rev match to first. I downshift to 1st on slow corners occasionally, like an immediate 90 degree turn. But only if I'm dogging on it, and then I'm heel and toeing to rev match so it doesn't harm the trans. |
#14 |
Drives: 2014 BRZ SWP LTD
4th to 1st while in motion? Good lord... And you wonder what you're doing wrong.
Is it too late to get an automatic? |
| The Following User Says Thank You to Turbo95eg6 For This Useful Post: | tyrantcf (08-24-2014) |
| shifting from 1st to 2nd | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 05-26-2016 07:15 PM |
| shifting into 2nd | cantaloupe | BRZ First-Gen (2012+) — General Topics | 63 | 06-23-2014 04:47 PM |
| Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC | mav1178 | Other Vehicles & General Automotive Discussions | 1 | 05-23-2014 10:47 PM |
| 2015 86/BRZ vs 2015 Eclipse | botbs | FR-S / BRZ vs.... | 55 | 04-16-2014 04:07 AM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 05:09 PM |
