#15 |
Drives: toyota
Thanks guys. If that whirring sound is the fan, it must mean that the fan is only programmed to kick in after certain RPM as I don't hear it when driving normally.
#16 | |
![]() humfrz |
#17 | |
| The Following User Says Thank You to s2d4 For This Useful Post: | humfrz (08-11-2014) |
#18 |
Drives: '13 Argento MT FR-S
You should be fine, so long as you're not getting any knock. A lot of engines will knock under load at low rpms, not saying it's overly harmful, but just something to be aware of. I usually drop it down a few gears to get into the powerband if I'm going to suddenly accelerate from cruising.
#19 |
The Angry Brit
Drives: 1991 E30 318iS
I have 28,000 miles on my car, and while a lot of it is highway... it sees redline often, and a lot of spirited driving. Redline is there for a reason, as is the rev limiter.
While probably not expected to sit at 7000+ rpm's its entire life, during Subaru and Toyotas collaboration on the design of the engine and management system they probably expect the car to be beaten on, often. And have built it to a degree of being able to take that on a somewhat regular basis without premature failure. Last edited by VacantSky; 08-13-2014 at 01:48 AM. |
| The Following User Says Thank You to VacantSky For This Useful Post: | Chad86 (08-12-2014) |
#20 | |
Drives: '14 Whiteout FR-S
lolwut? |
#21 |
Drives: Panda FR-S
There is a safety factor in engine design. The redline is 7.4k. I'm sure the engine is designed to run safely well above that.
I don't work in automotive, but I'm sure engines undergo some rigorous testing.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#22 |
Drives: '16 MX5 rip '14 FRS
Do you really have a Panda Frs? I plan to wrap it in the future. Can you tell me the ballpark figure?
| The Following User Says Thank You to Mini Cooper S For This Useful Post: | Frishkorn (08-12-2014) |
#23 |
Hi everybody!
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
I'm also interested in a ballpark figure to do this in vinyl. Sadly I don't think there is one single place in Pittsburgh that does these type of vinyl wraps.
#24 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
That's the "Italian Tune Up"
Need to flog it once in a while to knock dust out of the corners.
"I gotta rock." -- Charley Brown |
#25 |
Drives: Raven FR-S
We called that blowing the carbon out. And actually it did that with my parents Corolla. After years and years of running at less than 3000 rpm, teen son gets into it and flogs it up to redline, emiting a big black cloud out the exhaust. Was good after that!
#26 |
Senior gif poster
Drives: 2013 Asphalt FRS
Im rough on mine and put about 30k on her in about a year without any problems at all. It's good to give it the beans every now and again and rev her up to keep the engine running nicely.
#27 |
30k miles and I've slammed into the rev limiter a few times when I had my mind on other things (merging onto the freeway, finding the braking point for turn one at thunderhill).
This engine can sound nasty when you wring it out, especially to someone used to an automatic econo-box never surpassing 3.5k rpm during it's entire lifespan. Drive the piss out of it, that's what it was meant for. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Frishkorn (08-20-2014) |
#28 | |
Drives: Firestorm 2013 FR-S
This is NOT true. Remember energy increases with the square of velocity. Your engine might survive a trip above redline and it might not. |
| What happens on a Boxer engine when there's too much Oil? | @Art_Mighty | Engine, Exhaust, Transmission | 29 | 06-15-2014 04:36 PM |
| Boxer engine and temps | SlinkyAvalanche | Engine, Exhaust, Transmission | 9 | 03-27-2014 03:00 PM |
| What makes the Boxer engine so special | ZakD | Scion FR-S / Toyota 86 GT86 General Forum | 111 | 11-02-2012 09:54 PM |
| Next Gen Boxer Engine 4U-GSE | WingsofWar | Engine, Exhaust, Transmission | 33 | 12-10-2011 12:04 AM |
| Could this be the base FT-86 boxer engine? | iff2mastamatt | Engine, Exhaust, Transmission | 2 | 02-10-2011 10:55 PM |
