Old 08-11-2014, 05:36 PM   #15
djmm
djmm's Avatar
Drives: toyota
Thanks guys. If that whirring sound is the fan, it must mean that the fan is only programmed to kick in after certain RPM as I don't hear it when driving normally.
djmm is offline   Reply With Quote
Old 08-11-2014, 05:41 PM   #16
Oh, I'd say the fan is programmed to kick in when the water temperature reaches a certain temperature ..... regardless if RPM.....
Old 08-11-2014, 10:42 PM   #17
s2d4
s2d4's Avatar
Of course, wives know more that husbands. If you don't believe that ..... you are either not married ...... or miserable or soon to be made miserable.......
lol, I specifically didn't marry one that would be like that.
The Following User Says Thank You to s2d4 For This Useful Post:
humfrz (08-12-2014)
Old 08-11-2014, 11:01 PM   #18
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
You should be fine, so long as you're not getting any knock. A lot of engines will knock under load at low rpms, not saying it's overly harmful, but just something to be aware of. I usually drop it down a few gears to get into the powerband if I'm going to suddenly accelerate from cruising.
Kwaziekeller is offline   Reply With Quote
Old 08-11-2014, 11:32 PM   #19
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
I have 28,000 miles on my car, and while a lot of it is highway... it sees redline often, and a lot of spirited driving. Redline is there for a reason, as is the rev limiter.
While probably not expected to sit at 7000+ rpm's its entire life, during Subaru and Toyotas collaboration on the design of the engine and management system they probably expect the car to be beaten on, often. And have built it to a degree of being able to take that on a somewhat regular basis without premature failure.
VacantSky is offline   Reply With Quote
The Following User Says Thank You to VacantSky For This Useful Post:
Chad86 (08-12-2014)
Old 08-11-2014, 11:36 PM   #20
FR-S Guy
Drives: '14 Whiteout FR-S
My wife mentioned to me a couple of times while I was driving that I treated my car badly due to the way I drove.
I drive like normal most of the time but I sometime floor it all of a sudden after driving normally for most of the trip. This is mostly to beat the traffic lights or to prevent some inconsiderate aggressive numnuts from cutting into my lane.
lolwut?
FR-S Guy is offline   Reply With Quote
Old 08-12-2014, 01:44 AM   #21
Cal3000
Drives: Panda FR-S
There is a safety factor in engine design. The redline is 7.4k. I'm sure the engine is designed to run safely well above that.
I don't work in automotive, but I'm sure engines undergo some rigorous testing.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 08-12-2014, 02:10 AM   #22
Mini Cooper S
Mini Cooper S's Avatar
Drives: '16 MX5 rip '14 FRS
Do you really have a Panda Frs? I plan to wrap it in the future. Can you tell me the ballpark figure?
Mini Cooper S is offline   Reply With Quote
The Following User Says Thank You to Mini Cooper S For This Useful Post:
Frishkorn (08-12-2014)
Old 08-12-2014, 09:34 AM   #23
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
I'm also interested in a ballpark figure to do this in vinyl. Sadly I don't think there is one single place in Pittsburgh that does these type of vinyl wraps.
Frishkorn is offline   Reply With Quote
Old 08-12-2014, 11:52 PM   #24
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
That's the "Italian Tune Up"
Need to flog it once in a while to knock dust out of the corners.
Old 08-16-2014, 07:31 PM   #25
root
Drives: Raven FR-S
We called that blowing the carbon out. And actually it did that with my parents Corolla. After years and years of running at less than 3000 rpm, teen son gets into it and flogs it up to redline, emiting a big black cloud out the exhaust. Was good after that!
root is offline   Reply With Quote
Old 08-16-2014, 11:39 PM   #26
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Im rough on mine and put about 30k on her in about a year without any problems at all. It's good to give it the beans every now and again and rev her up to keep the engine running nicely.
DandoX is offline   Reply With Quote
Old 08-17-2014, 02:48 AM   #27
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
30k miles and I've slammed into the rev limiter a few times when I had my mind on other things (merging onto the freeway, finding the braking point for turn one at thunderhill).
This engine can sound nasty when you wring it out, especially to someone used to an automatic econo-box never surpassing 3.5k rpm during it's entire lifespan. Drive the piss out of it, that's what it was meant for.
Frishkorn (08-20-2014)
Old 08-17-2014, 02:57 AM   #28
pantdino
Drives: Firestorm 2013 FR-S
This is NOT true. Remember energy increases with the square of velocity.
Your engine might survive a trip above redline and it might not.
pantdino is offline   Reply With Quote
What happens on a Boxer engine when there's too much Oil? @Art_Mighty Engine, Exhaust, Transmission 29 06-15-2014 05:36 PM
Boxer engine and temps SlinkyAvalanche Engine, Exhaust, Transmission 9 03-27-2014 04:00 PM
What makes the Boxer engine so special ZakD Scion FR-S / Toyota 86 GT86 General Forum 111 11-02-2012 10:54 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 01:04 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 11:55 PM
