Old 08-04-2014, 11:00 PM   #15
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by stockysnail View Post
I am lowered a little (0.8"). I'd rather not rip open my axle bushing unless I know that's the issue, unless someone has an x-ray machine I can borrow to see through the rubber. I wonder if I push down hard on the rubber and tried to feel is there was any cracked metal, if that would work for checking...
You cant feel down inside the CV joint.
that cage you see is inside a joint about the size of a beer can.
My car just started making this noise as well.
I think it IS a failing CV joint.
I cant tell if it is an inner or outer from the noise.
I can make it do it repeatedly by rocking against something like the curb in my driveway.
I plan on taking it to the dealer next week..
Old 08-05-2014, 01:42 AM   #16
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I doubt the dealer would cover mine since I have a supercharger, among many other things, if that ends up being my issue. I know a guy that works at a dealer so perhaps he can pull some strings.
stockysnail is offline   Reply With Quote
Old 08-05-2014, 01:46 AM   #17
whataboutbob
AutoX-10/10ths every run
It is probably your axle. Mine has been clicking more frequently recently. It started just after 30K and I'm past 60K now and the frequency of it happening is increasing. Yours is much louder than mine right now.
Build thread:Here
Old 08-05-2014, 06:48 AM   #18
gonzo
Drives: frs
Does it sometimes click when letting off the accelerator while above ~3k rpm in first gear?
gonzo is offline   Reply With Quote
Old 08-05-2014, 08:17 AM   #19
SHOspazz92
Drives: 2013 BRZ Limited
FYI, My bone stock BRZ does this exact same thing @ 23,000 miles. It does it while in reverse, moving from a stop, the 1-2 and sometimes the 2-3 shift is noticeable as well. The noise happens (or is noticeable anyways) under normal, sane driving conditions. I can't hear it with the windows up and it's also nothing I can feel either. No idea what it is.
-Sam
2013 WRB BRZ Limited - DD
1992 Taurus SHO - Auto-X Prepared - 13.1@107
2012 Mazdaspeed 3 - Wife's DD.
2002 SVT Focus -....?
SHOspazz92 is offline   Reply With Quote
Old 08-05-2014, 08:05 PM   #20
stockysnail
Just the tip
above or below 3k
Old 08-06-2014, 11:37 PM   #21
Dephective
Drives: '13 Whiteout FRS
my car makes this exact noise only when e-brake is engaged and I either rock the car as I get out, or I put it in first gear and start to engage the clutch while e-brake is still engaged. No other time do I hear this, and I'm lowered about 1.5-1.75". Exact same noise. 14k miles and still no issues.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 08-07-2014, 09:59 AM   #22
yohan04
yohan04's Avatar
Drives: Your sister
Re-torque your axle nuts - fairly common problem w/ subaru drivetrain.
yohan04 is offline   Reply With Quote
Old 08-07-2014, 11:03 AM   #23
stockysnail
Just the tip
I tried that already and they were already at the proper torque which didn't help. Thanks though.
Old 08-07-2014, 09:23 PM   #24
stockysnail
Just the tip
I already tried that and it didn't help, plus the bolts were already at the correct torque when I used my torque wrench on them. Thanks for mentioning it however.
Old 08-08-2014, 12:57 AM   #25
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Haven't heard the video but possible exhaust??
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 08-08-2014, 10:09 AM   #26
yohan04
yohan04's Avatar
Drives: Your sister
Plan B. Fairly common remedy for all subaru drivetrain noise.
Old 08-08-2014, 07:20 PM   #27
stugray
Just got back from the dealer.
They wanted to say it was the brake pads or the calipers.
I demonstrated the noise while driving and not touching the brake pedal and they agreed that it must be a CV joint.
They just ordered me a new axle-shaft - under warranty.
Old 08-08-2014, 08:55 PM   #28
stockysnail
Just the tip
They just ordered me a new drive shaft - under warranty.
The drive shaft doesn't have a CV joint so I'm not sure why they ordered that. I'm confused.
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
Shifter clicking when coming to a stop larryt1026 Issues | Warranty | Recalls / TSB 1 07-15-2013 07:34 PM
GTS rear left popping/clicking sound and fix. sigmaoctantis AUSTRALIA 11 05-19-2013 06:58 AM
Clicking coming from rear.. HillCountryGuru Issues | Warranty | Recalls / TSB 3 03-22-2013 12:05 AM
Fixed flapping, clanking sound coming from rear Cornerman Issues | Warranty | Recalls / TSB 2 08-16-2012 09:27 PM
