Old 06-11-2014, 12:03 PM   #15
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i want a set of @Raceseng for my AST's...time to give them a ring and send me a set to @AZP Installs
i dont plan on running my suspension all year round anymore. too much of an investment for new jersey winters to destroy them. plus i could use the clearance.
Jive Turkey is offline   Reply With Quote
Old 06-11-2014, 12:18 PM   #16
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
+1 for RaceSeng. Love my plates, great service and support, easily adjustable, good quality. I run RCE Yellows and Bilstein B8s currently plus some other random bits.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-11-2014, 01:24 PM   #17
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
So do the Raceseng plates affect ride height? I'd want to use the plates with stock struts and RCE yellows (for now) without affecting the drop from the yellows.
Phaedrus29 is offline   Reply With Quote
Old 06-11-2014, 01:27 PM   #18
BRZZZZZZZZZZ
Car Nut
No not as far as I can tell, and as far as I know they shouldn't.
Old 06-11-2014, 01:28 PM   #19
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
If you want more front damper bump travel, get HVT/RCE front top plates. If you want caster adjustability, get RaceSeng fronts. If you want more rear bump travel, get RaceSeng rear top hats.
fooddude is offline   Reply With Quote
Old 06-11-2014, 01:45 PM   #20
Phaedrus29
Phaedrus29's Avatar
I just meant that since I'm using stock struts without height adjustability, I won't be able to correct for any drop/raising from the plates.
So the HVT are better for front damper bump travel? Can you explain why and what that means exactly?
Old 06-11-2014, 01:55 PM   #21
fooddude
When you lower the car with shorter lowering springs, the damper shaft get compressed too, and loses bump travel/stroke. The HVT top plates raise the upper mounting point for aforesaid damper shaft, on the raised top hats...hence, giving you more bump travel and re-aquires some of that bump travel lost from the use of those shorter lowering springs.
Old 06-11-2014, 05:18 PM   #22
Phaedrus29
Phaedrus29's Avatar
It looks like the HVT plates can do "1.8 degrees of camber adjustment". Does that mean 1.8 degrees of negative camber?
The Raceseng plates say they can do 4.5 degrees of negative camber, but I think that is including the use of camber bolts.
Does anyone know the amount of negative camber possible with both plates without the use of bolts?
Old 06-11-2014, 05:23 PM   #23
BRZZZZZZZZZZ
Car Nut
RaceSeng without bolts goes to about -2.7 degrees on my car.
Old 06-11-2014, 05:43 PM   #24
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I have the HVT plates with rce tarmac springs and koni yellows they are fantastic. I have them in combo with the stock camber bolts from subaru. -3.5 degrees up front for camber
Hey, I'm currently on stock struts with RCE yellows. I'm using the crash bolts to adjust camber, but the clearance up front is dicey with my aftermarket wheels. I'd like to adjust camber with plates, so I can put the solid strut bolts back in.
I'm looking for caster/camber plates that will work with the stock struts but also WOULD work later on with aftermarket coilovers. It looks like both the HVT and Raceseng will do that.
Any thoughts on comparing these two options? The Raceseng are more pricey but look more badass. If I'm not mistaken, the HVT adds caster but does not have adjustable caster...while the Raceseng allows caster adjustability. (I might be wrong on that.) I'm not sure how useful adjustable caster would be for me.
Since I'm on the stock struts right now, I need plates that won't raise or lower the ride height. Is that true of both the HVT and Raceseng plates?
Thanks for the help.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-11-2014, 10:13 PM   #25
Pacific Auto
Master Installer
Pacific Auto's Avatar
Drives: Scion FRS
Have the same amount using HVT plates maxed out, no bolts and at 1" drop.
Pacific Auto is offline   Reply With Quote
Old 06-18-2014, 05:11 PM   #26
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
In my correspondence with Jarrett I was told that the Raceseng plates would not raise the car. I *think* this is because even with standard springs they use a custom spring perch so that the total stack height isn't increased vs stock. That's my theory anyway, hard to say exactly without having them in my hands.
Cheers
Nathan
SubieNate is offline   Reply With Quote
Old 06-19-2014, 12:25 PM   #27
MidnightRunner
MidnightRunner's Avatar
Are you sure the HVT will work later with coilovers? There are two different versions of those plates, one for oem struts and one for coilovers. I remember seeing something about the spring perch being too small on the coilover version if trying to run oem diameter springs. I might be mistaken, but I don't think the HVT plates can work later for your coilovers.
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 06-19-2014, 12:29 PM   #28
was385
Drives: MT WRB BRZ Limited, 2007 911s
I emailed HVT about this very thing when I purchased my plates and was told that to switch over, you need is the new perches, which run $100 for the set.
was385 is offline   Reply With Quote
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 01:21 AM
Caster, SAI, Steering and Camber Wepeel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 02-24-2015 08:09 PM
Raceseng | Billet Aluminum Caster Camber Plates Raceseng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 162 12-29-2014 10:32 AM
Raceseng | CasCam - Caster + Camber Plate Black Friday Sale Raceseng Brakes, Suspension, Chassis 0 11-30-2013 11:09 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
