#15 |
Drives: 2013 86 STD SPW
I will post this here, since it's some questions that are quite probably really really stupid, but it occurred to me this morning:
My 86 is pretty accurately a year old, and I would like it to be serviced regularly. 1) Does this car have a service light/indicator of sorts, or do I simply have to remember myself? (probably a retarded question, but hey) 2) I want to change oil(s). Motor Oil and (if needed - not sure about this at all, maybe someone can enlighten me - gearbox oil as well). How do I ensure that our (frankly piss-poor) Toyota dealership puts the right oil in the parts? |
#16 | |
Drives: Toyota MR2 Spyder Turbo
2) Ask the dealership to give you the empty containers
#17 |
Thanks
Yes, check after a few minutes. If I check right after turning off the engine it will not even register the first dot on the dipstick. If I wait a couple minutes it reads correctly, for me about halfway between the 2 dots.
They probably use bulk oil so no containers.
#18 | |
Drives: PEARL WHITE GT86 TRD
#19 | |
Platinum Member
Drives: Toyota 86 Vortech SC
#20 |
Drives: 2014 Satin White Pearl GTS auto
psssssshhh check oil and water? one of the perks of having a brand new car is not to worry about these things.
I save that energy for working on the MR
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto |
#21 | |
Thanks
But hey, if you trust the dealer jockeys to do everything right and your car to be perfect more power to you.
| The Following User Says Thank You to ZionsWrath For This Useful Post: | qbzee007 (11-05-2014) |
#22 | |
I thought that the empty container was the answer, but wasn't sure abotut he huge bottles and all. Thanks again! |
#23 | |
My fiance had a mercedes A class for 6 years, not once did it ever cross my mind to check the oil and that car was perfectly fine, hell on my daily driver where i do 4000kms a month and drive it like i stole, it, its not something im concerned about, if everything is within factory spec then you shouldnt have a problem, Have theses cars been noted for oil consumption in mass numbers? not that I know off, Now my MR2 with the original 1zz engine was, that I checked fluids etc regularly, and now that i fitted a 2zzge crate motor to it, I still do it because its modified, and if something had to go wrong it would actually be my problem and not a warranty claim. Dont get me wrong I plan to keep the 86 long term, but when its older and out of warranty etc. then I will worry I dont expect a new factory stock car to take oil or water and if it did, then theres warranty for that, if you are supercharged or did some mods then by all means I agree, check everything for peace of mind.
2014 37J 86 Auto |
| The Following User Says Thank You to WesleyG For This Useful Post: | Dammod (06-25-2015) |
#24 |
Drives: Toyota 86 Supercharged
| The Following User Says Thank You to CWP68 For This Useful Post: | ZionsWrath (11-06-2014) |
#25 |
Drives: Lawn moweR
Blue Coolant Part number: 08889-01203
My coolant levels were at the min level this weekend,
I went to the dealership that I purchased my vehicle from: McCarthy Toyota Gateway (Umhlanga) They insisted that the Toyota 86 uses the red coolant, they then said I must call Subaru and ask them for the "Blue coolant" that I requested. Called Subaru Dbn: They said they use Red coolant in all their BRZ's I then drove the Gateway Toyota (Who still denied there being a Toyota Blue Coolant in existence) and called Imperial Toyota Randburg (Infront of the Gateway Toyota Parts manager) who assisted me with the following part number: (Blue coolant part number) 08889-01203 Toyota Gateway parts said its the first time they heard about this coolant - Not sure if it was ignorance or stupidity. I then drove to Durban South Toyota to buy it as they where the closest dealer in KZN to have stock. Not sure if this is the correct coolant or not ![]() But my car hasnt exploded as yet lol so it should be fine... ![]() Cost R311.48 (Excluding VAT) - 4L |
#26 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
| The Following User Says Thank You to Ryan86 For This Useful Post: | sav (06-25-2015) |
#27 |
Drives: Lawn moweR
#28 |
Drives: Toyota 86 - Charcoal Grey
| Coolant, Anyone tried this?? | stevo_12v | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 04-27-2016 05:50 PM |
| FRS uses a lot of coolant? | JLMtm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 124 | 01-23-2015 07:34 AM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 06:56 PM |
| Where did my coolant go? | ZionsWrath | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-02-2013 12:46 PM |
| Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 01:03 PM |
