Old 05-30-2014, 04:36 AM   #15
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Originally Posted by HRTROB View Post
In my 86 (not sure if it's JDM or European spec) there is no option to turn off the DRL LEDs in Techstream.
But you can do so manually by pulling out the DRL relay in the fuse box under the hood. DRL will no longer function, but the LED strip will still light up when you have your parking lights or headlights on. Just pop the relay back in if you want it to work again.
You're in Philippines, I'd be curious if you could detail your specs, in particular:
electric fold mirrors Y/N
dual zone auto A/C Y/N
anti turbulence plastic underpanels Y/N
touchscreen Bluetooth radio Y/N
trunck door trim Y/N
front fog lights Y/N
speed regulator Y/N
auto headlights Y/N
frameless inside mirror Y/N
alcantara red stiched leader seats/armrest/steering wheel/stick Y/N
GT86 protective carpets Y/N
TPMS Y/N
Harvey is offline   Reply With Quote
Old 05-30-2014, 06:19 AM   #16
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Here you go:
Left hand drive
electric fold mirrors YES
dual zone auto A/C YES
anti turbulence plastic underpanels YES
touchscreen Bluetooth radio NO
trunck door trim (not sure what this is)
front fog lights YES
speed regulator (not sure what this is)
auto headlights YES
frameless inside mirror YES
alcantara red stiched leader seats/armrest/steering wheel/stick: Same steering wheel and seats as the standard FR-S in the USA
GT86 protective carpets YES
TPMS NO
Push start button: YES
Alarm NO
Driver side knee airbag YES
Full size spare tire YES
Rear foglight NO (but car is prewired, easy retrofit)
HRTROB is offline   Reply With Quote
Old 05-30-2014, 09:32 AM   #17
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
TPMS is an interisting one.... it seems to be a standard in USA FRS and not available at all in GT86 europe, whereas for most other things the european version seems to have more standard equipment (electric fold mirrors, auto headlights, dual A/C, plastic underpanels, trunc trim, .... but is much higher priced, but therefore less noobs with them, so I don't think we'll get the Honda Civic symptom you're on about in the US)
TPMS is required by law in the US on all new light (a.k.a. typical passenger) vehicles sold after 01 September 2007:
http://www.nhtsa.gov/cars/rules/ruli...nalrule.6.html
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 05-30-2014, 10:36 AM   #18
D_Thissen
D_Thissen's Avatar
Does anyone know if Techstream will work on a Mac? Also a link to the download would be great. I know i should search but I'm lazy right now lol
Old 05-30-2014, 10:42 AM   #19
J_kennington
Drives: 2013 asphalt scion FRS
It will not work directly on a Mac. From my understanding some have had good luck running a windows VM on a Mac though. But, most cables come with the cracked version of the program anyways. I actually used the "newest" one that's posted here in the forums, and the crack that came with my cable. Then had to force install the drivers(xp drivers on a win7) then edit the registry for it to recognize the cable.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 05-30-2014, 11:10 AM   #20
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Could you please elaborate on how you edited the registry for it to work on win7? Are you using 64 bit?
Old 05-30-2014, 12:27 PM   #21
phobos512
phobos512's Avatar
If you're on 64-bit follow this:
http://www.toyota-4runner.org/genera...-8-64-bit.html
Otherwise the Windows XP drivers seem to work on 32-bit whatever version from what I've read. I'll be giving mine a shot in a few days once my cable comes in (I have a Win 8 32-bit tablet now).
Old 05-30-2014, 01:32 PM   #22
J_kennington
I can send you the file that will automatically do it for you when I get home from work tonight. Makes it a lot easier.
All you'll have to do is install everything, then open this file and it will edit it. Then I had to move the drivers into a seperate folder for it to work correctly.
And I was on 64bit OS. So I'm not sure about the 32bit. It may work correctly without having to do the work around
2005 Yamaha yz250f
Old 05-30-2014, 03:36 PM   #23
Harvey
Yeah, the whole install's a bit of a shamble, but you can get through it and it is worth it!
Old 06-04-2014, 03:04 AM   #24
73TORANA!
Drives: Orange GTS
Originally Posted by Mikem53 View Post
U can ask your dealer.. Some will do it for free.. I called an asked a local
Dealer here and they wanted 75 dollars to change the options.
So I bought the cable for $30 and DL the software here for free..
Installed on my win7 laptop and made the changes. It also has diagnostic functions and allows you to monitor the system temperatures and other operating specs. Very useful tool.
Sorry for being an idiot but where on this site might i find the mentioned software.
73TORANA! is offline   Reply With Quote
Old 06-04-2014, 03:32 AM   #25
Harvey
In fact you can download it straight from the toyota web site and the crack came on the CD with the cable.
I plugged it into the car for the first time monday (I parked the car 100 meters from my Toyota Dealer just in case something went wrong!), it's incredible all the information you can see about the car status!
I've not yet taken that much time yet, but I plan to adjust some settings (A/C stuff and DRL, ...).
I also want to log data for typical trips (home->work, work->lunch, ...) just to save them as references for when things start getting strange (you're always happy when something's wrong to know what the values should be when all is OK... however, the manual actually gives "normal" value ranges)
The Following User Says Thank You to Harvey For This Useful Post:
73TORANA! (06-05-2014)
Old 06-04-2014, 07:48 AM   #26
Mikem53
Drives: FR-S 6MT
Do a search on techstream. I downloaded from a link I found on here.
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
TechStream TIS - No work FRSFirestorm Engine, Exhaust, Transmission 19 07-10-2014 03:14 AM
Techstream/ECU customizations phanguy Northern California 60 10-05-2013 11:12 PM
techstream spitfire481 Mid-Atlantic 0 09-14-2013 09:37 PM
Toyota Techstream on BRZ? pinoy_dorifto Engine, Exhaust, Transmission 6 05-15-2013 11:56 AM
Techstream ECU Options mrjester Electronics | Audio | NAV | Infotainment 10 03-18-2013 10:24 AM
