Old 05-13-2014, 12:04 PM   #15
8R6
8R6's Avatar
Drives: FRS
i dont regret it at all, but i do miss the ease of sliding once in awhile
8R6 is offline   Reply With Quote
Old 05-13-2014, 12:08 PM   #16
evomike
Drives: frs
i put super cheap off brand tires on mine and im 100% glad i did, the primacys are probably the worst tires ive ever driven on i can only imagine actual good tires.
evomike is offline   Reply With Quote
Old 05-13-2014, 12:15 PM   #17
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I do enjoy the MPG savings with the Primacy tires. I will probably run a different Primacy when these are done for DD duty.
I do have a set of track wheels and tires for when I need them.
If you do things for a purpose, there shouldn't be a regret.
Old 05-13-2014, 01:02 PM   #18
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by unsurety View Post
Odd question, I know.
The twins are so fun to drive in their stock configuration. It's so balanced and confidence inspiring. Very easy to catch in a slide. Admittedly though, there is a fine line between traction and wheelspin.
I want the aesthetics that come with a wider wheel and tire setup. But does it make driving on the street a little less exciting?
You are basically asking if anyone regrets dumping this:
For this....
Old 05-13-2014, 01:04 PM   #19
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Ill let you know when my axles snap and my transmission explodes
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 05-13-2014, 01:04 PM   #20
Reaper
Reaper's Avatar
Drives: violent
Btw I like my 280 treadwear rated hankook v12s
Old 05-13-2014, 02:42 PM   #21
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Stock tires are great for learning, which many of the people on this forum need. As do i.
In a sense, if you get consistent times on stock tire, then time for a upgrade. If you're still learning, then stay with stock until you're consistent. I've been looking at Auto x times locally, there's members with stock tires doing better time then those running those RE-11A's or PSS.
Don't follow the forums, upgrade at your own pace for your own advantage.
One more thing, you get pick up stock tires for dirt cheap. I've picked up two sets with very little wear for around $200. But do be cautious of these tires feathering, they love to do that.
The Following User Says Thank You to dem00n For This Useful Post:
mx5 2nr (05-14-2014)
Old 05-13-2014, 03:12 PM   #22
fatoni
all the talk about the lack of trust in the stock tire is unwarranted. if you feel out of control with the stock tires, its not the tires. its your driving. changing to another reasonable street tire isnt going to change the characteristics of handling but just where they happen. in my experience they are a relatively predictable tire that is really communicative.
The Following 5 Users Say Thank You to fatoni For This Useful Post:
DrDuquette (05-14-2014), mx5 2nr (05-14-2014), Siffa (01-27-2016), SirBrass (05-13-2014), turbocat (05-13-2014)
Old 05-13-2014, 03:14 PM   #23
GT86Dan
GT86Dan's Avatar
Drives: 2013 scion frs
would have to agree with this , stock tires aren't all that bad. From my track experience with the car thus far feels great just needs more finesse with stock tires. But again all down to driver input
Sent from my RM-877_nam_att_205 using Tapatalk
Speed has never killed anyone, suddenly becoming stationary… that’s what gets you. Jeremy Clarkson
GT86Dan is offline   Reply With Quote
The Following 3 Users Say Thank You to GT86Dan For This Useful Post:
DrDuquette (05-14-2014), SirBrass (05-13-2014), turbocat (05-13-2014)
Old 05-13-2014, 03:47 PM   #24
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
The stock tires are always saying, "Running out of grip! Running out of grip!" at least on the rear of the FR-S. The MPSS don't say that at all. Fun! But aggravating. After I wear out a set of tires, I might try some off brand cheapo just to see how it is.
Old 05-13-2014, 03:52 PM   #25
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
I also agree with you both.
I ran all last season's local Auto-X on Hankook RS3s 225/45/17. Grippy but they hid a lot of my bad driving. It felt good but I wasn't learning as much as I should.
I just went to this season's first event. I was lazy and left my stock Michelin Primacy tires on for this event. Although the car was slower/less grip, it wasn't a tail happy drift machine either. It was very predictable and controllable. I had my air pressure up to 40PSI all around and the corner block wear was running true with the guide marks. IMHO the stock tires only lose grip when you aren't giving smooth inputs to the car. It sounds obvious but it isn't to most people. Not once was the car drifting with the tires ablaze rounding a corner. Sure they protested a little, but nothing that I couldn't correct and keep on line. Some car control education goes a long way. Its very eye opening to drive the stock tires on the limit in a safe environment.
turbocat is offline   Reply With Quote
The Following 5 Users Say Thank You to turbocat For This Useful Post:
8R6 (05-13-2014), DrDuquette (05-14-2014), GT86Dan (05-13-2014), SirBrass (05-13-2014), unsurety (05-13-2014)
Old 05-13-2014, 10:13 PM   #26
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Ashwaria
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 05-14-2014, 01:28 AM   #27
Lemar58
Drives: Scion FR-S
Originally Posted by cycleboy View Post
Nope. I went with Pilot Sport A/S3 (245's) and love them. I'm not big on sliding the tail around, wearing out tires faster and possibly inviting the law to frown upon my activities. With the new ones, I can corner about as fast as I'd ever want to on the street without sliding.
This. Did a perfect drift the other day in a non crowded area, halfway through saw a cop that proceeded to pull me over. Gave me a hard time but ended up letting me go. His partner was bitching about me doing "fast and furious" shit, because I wanted to "honor Paul walker" since he died a few miles from me. Didn't really care, just was happy I wasn't getting a ticket. Drifting is fun, but grip is more important imo
Lemar58 is offline   Reply With Quote
Old 05-14-2014, 01:40 AM   #28
Amir Ghadiri
Amir Ghadiri's Avatar
Hell no I don't regret it. I'm running 265/35-18 Falken Azenis RT615K (square), and I wouldn't have it any other way. The extra grip has saved me countless times, and now I can drive however I like without any worries. Sure, sometimes I like to break loose, and that's when my clutch comes in handy the most
I will admit, I did break my left side axle once. With stock tires.
Stickier tires cost a lot more though, and they also wear much quicker. I'd be lucky to get 3k miles out of a set of my tires, I usually only manage around 2.5k. Try to find a middle ground where the benefit will still outweigh the cost.
Amir Ghadiri is offline   Reply With Quote
Regret grippy tires? stock Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 04-11-2014 04:34 PM
Full Report: Road & Track tests stickier FR-S/BRZ tires poormans_LFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 74 08-15-2013 01:10 AM
Anyone regret getting MT? Almighty Bob Cars for Sale/Trade 39 03-24-2013 02:58 AM
Do you regret your purchase? Weeber Scion FR-S / Toyota 86 GT86 General Forum 44 12-31-2012 04:42 AM
Regret it or not? Bangduk Scion FR-S / Toyota 86 GT86 General Forum 83 08-03-2012 07:16 PM
