#15 |
Drives: BRZ Sport-tech
I have a gravel driveway that has a small grade and I used the scissor trunk jack to swap my summer on in about 45minutes, no problem.
The only weird thing is that the jack doesn't really engage the pinch with the groove (the groove in the jack is too deep) so it's lifted on the frame adjacent to the pinch, and I got a small transfer of the factory underbody spray onto my jack.
#17 |
Drives: 13 frs
hey thanks guys been a bit busy .think I got my answer e-brake wasn't engaged. car was on flat cement floor and jack was in front of rear wheel. got the spare in the wheel wel that saved the rotor from hitting the floor.no damage. thanks for the great response.
| The Following User Says Thank You to mafrs1 For This Useful Post: | wheelhaus (05-14-2014) |
#18 |
Glad it was an easy solution an no damage occurred.
#19 | |
I've used the factory jack a number of times without issue. Obviously use the e-brake and it helps to put the transmission in gear, just in case. I also chock the wheels.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | PMPB (05-14-2014) |
#20 |
Drives: Asphalt Scion Frs 6MT
Mine broke.
#21 |
Drives: 2013 BRZ Limited
The jack is exactly the same one that came in my 95 impreza. They wear out really quick.
OP: Good rule of thumb with emergency jacks is to throw something on each side of a tire(preferably the one farthest away from the affected tire) in order to prevent rolling. I don't trust emergency jacks or brakes to actually hold a car still.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
#23 |
Drives: 2013 Scion FR-S (Argento)
I've (probably stupidly) used mine to change the tires about 4x since I got the car. No issues except scraping knuckles on asphalt.
#24 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I've swapped to winter tires, then to summer tires, then to winter tires, also changed my brake pads, and had at least one flat tire (which involved jacking twice since it was a rear tire.)
So basically I've jacked my car up like 20 times with this jack and haven't had any issues. |
| $10 Jack Buddies | blalor | DIY (Do-It-Yourself) Guides | 24 | 10-20-2017 07:16 PM |
| Bad Emergency Jack? | JDMenrique | Issues | Warranty | Recalls / TSB | 35 | 11-27-2015 07:55 PM |
| JACK's BRZ! | Mr. Jack | Member's Car Journals | 10 | 07-05-2013 09:19 AM |
| Where ti jack car up at? | skatery1989 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-13-2012 01:53 AM |
| Jack Spots? | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 06-11-2012 09:09 AM |
