Old 04-18-2014, 03:35 PM   #15
Simply_the_best
Tom's Racing ADDICT
Simply_the_best's Avatar
Drives: 2013 Toyota 86, 1999 Toyota Corolla
Originally Posted by Pokeguyjai View Post
Hi guys,
I installed a Greddy oil drain plug in my car. It did not have any leaks after I did my first oil change (obviously when I swapped it in). But after the second oil change (new crush washer) it started leaking. I torqued it down to factory specs. I just did my fourth oil change a few hours ago and just saw a small pool of oil under the car. Not huge, probably a few good sized drops. Going to go back to the OEM drain plug when I do another oil change in a few weeks after a track day just to stop the leaking.
Was wondering if anybody also had the same issue?
I have the Greddy drain bolt with no problems to date just did my 3rd oil change and still no leaks. I also change my drain gasket every time with the OEM 803916010 from Subaru. Hope that helps.
Check out my car journal!
"Straights are for fast cars. Corners are for fast drivers."
Instagram: @simply_the_best
Simply_the_best is offline   Reply With Quote
Old 04-18-2014, 03:49 PM   #16
Pokeguyjai
Pokeguyjai's Avatar
Drives: 2013 GBS BRZ (AT)
Thanks guys for the feedback. I swapped out the Greddy last night and went OEM. No leaks. I definitely used a fresh OEM gasket every time.
I will look into the magnet for the oil filter.
Pokeguyjai is offline   Reply With Quote
Old 09-15-2015, 05:56 PM   #17
philooo
Drives: 13' Scion FRS Track car
I have to report as well that my greedy magnetic oil plug has a slight oil leak... I did use the poem washer and all.. there may be something effective with the greedy plug...
philooo is offline   Reply With Quote
Old 10-11-2015, 03:25 PM   #18
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Mine has zero leak
Old 09-15-2016, 06:34 PM   #19
Lorne
Drives: 2013 Subaru BRZ, 1999 Dodge Neon
Having this issue as well, guys stay away from this drain plug.
Lorne is offline   Reply With Quote
Old 09-25-2016, 04:16 PM   #20
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
never using greddy again waste of my 20$. one time use... leaked after 1st oil change.
wasted money had to buy oil again as well since i leaked right before i had to go to the track.
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 03-28-2026, 09:56 AM   #21
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Posting here 10 years later. Had the Greedy drain bolt for last 10 years with no issues. Now it started leaking. Used a new washer, but can't torque it down to 39 Nm. Just keeps on spinning and I'm afraid of shearing it off. Gonna replace it with a new Oem bolt.
Edit: replaced the bolt and added a picture of the Greedy one. Looks like it was going to fail and second
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Subaru or Toyota drain plug? yayforaddison Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-06-2020 10:59 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 06:04 PM
GReddy Magnetic Drain Plug BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 01-05-2013 10:19 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
