Old 04-07-2014, 06:30 PM   #15
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
I bought the spc rear lower control arms and my rear alignment is even. You might consider doing the same.
enjoyminutemaid is offline   Reply With Quote
Old 04-07-2014, 06:36 PM   #16
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by supramkivtt2jz View Post
The cars are like this off the factory floor.
Im at -1.8 LR, -2.8 RR
That is outside the factory spec, you should take it to a dealer and have them replace parts.. that is if you are -2.8 on stock springs and not lowered.
I did not have anywhere near this much cross camber on the rear of mine, i was at -1LR -1.2RR at stock ride height.
Old 04-07-2014, 07:50 PM   #17
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
im lowered without control arms. factory I was at -1, -1.8 or so.
supramkivtt2jz is offline   Reply With Quote
Old 04-08-2014, 09:21 AM   #18
transition
Update: it appears to be the JDL overpipe that is rubbing on hard turns. Going to take it home to see if i can adjust it a little bit then update again.
transition is offline   Reply With Quote
Old 04-08-2014, 09:35 AM   #19
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
those pipes, they always get ya
what an uneventful ending to an exciting wild goose chase
Old 04-08-2014, 03:24 PM   #20
transition
Alright confirmed it was definitely the JDL over pipe that was the source of the noise. Adjusted it as much as i can and eliminated 95% of the rub. The flanges now from the header to the overpipe now line up very poorly - i guess that doesn't surprised me as i've had bad luck with JDL parts in general. For the record it's a JDL UEL Header too - so there's no excuses on why their over pipe shouldn't be a perfect fit.
Below shows the clearance i get with the cross-member and the over pipe. Unfortunately after loosening both the front-pipe and header side of the overpipe there is simply no more room for adjustment.
How much rubbing is too much rubbing? Pokeguyjai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 12-10-2013 08:04 PM
FS: RCE Yellows + Koni Yellows ***SOLD*** raul Brakes, Suspension, Chassis 0 10-22-2013 01:14 PM
Feeler: RCE Yellows + Koni Yellows *PRE-ASSEMBLED* raul Brakes, Suspension, Chassis 0 08-09-2013 03:22 PM
RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings raul Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 05-24-2013 08:33 AM
Rubbing sound? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-15-2013 11:06 AM
