Old 04-03-2014, 08:03 PM   #15
Turdinator
Señor Member
Turdinator's Avatar
Definitely clutch related. Wheelhaus looks to be on the money with those suggestions.
1974 TA22 Celica
2013 86 GT
Old 04-04-2014, 01:16 PM   #16
Pneub
Drives: Dark Grey BRZ
Originally Posted by wheelhaus View Post
Thirded.
I agree it's likely the clutch is dragging. A few things could cause this:
1- If the clutch pedal engagement is set too low, then there might not be enough pedal travel to fully separate the plates.
2- Air in the clutch hydraulic system (stated above).
3- faulty clutch (or somehow incorrect model installed).
4- faulty installation.
What would have caused #1 and #2? Bad parts? Bad installation? Factory set issues?
Pneub is offline   Reply With Quote
Old 04-04-2014, 02:20 PM   #17
wheelhaus
wheelhaus's Avatar
Yes yes and yes. Although they're all pretty rare.
A lot of users feel the clutch engages too high in the pedal stroke and want it lower, closer to the floor. It's an easy pushrod adjustment behind the pedal. It's possible the locking nut wasn't tight enough and it moved, but its unlikely this would happen from the factory. I think the shaft might need to be disconnected from the clutch pedal arm to adjust it, but I'm not 100% on that..
Air may have been pulled into the line during install if the slave cylinder was over extended, leaked, or if there was not quite enough fluid was in the reservoir.
Clutches aren't terribly complicated, but do need to be precise. A good friend of mine purchased a Spec clutch for his A4 (back in '04 or '05) and it was installed by a reputable shop with lots of experience with Audis. After a few weeks it began slipping badly. He paid to have the clutch removed again, and it turns out the pressure plate was machined nearly 1/4" too shallow. The unit was brand new, but because this massive defect somehow slipped past QA, it couldn't produce enough clamping force. The factory admitted 100% fault and wanted to provide a new unit, but refused to reimburse the replacement labor.
wheelhaus is offline   Reply With Quote
Old 04-04-2014, 02:26 PM   #18
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by JP View Post
bleed the clutch hydraulic system and then adjust the clutch master to get the correct throw when hot. You can't engage gears as the clutch plate is dragging.
^this
had similar symptoms on my 95M3. My other thought is the pressure plate.. if the fingers are weak it will cause the clutch to drag, heat *may* affect how much the fingers flex when the clutch is depressed.
OP, if you are sitting on flat ground in neutral foot on clutch, foot OFF the brake, if you try to put it into 1st, does it roll forward a little? If so, the clutch is dragging for sure.
Old 04-04-2014, 02:42 PM   #19
Pneub
Originally Posted by mad_sb View Post
^this
It does roll forward! If I'm locked out trying to get into gear the car slowly lurches forward.
This will be the third time I'm taking it to Evasive just for the clutch replacement. They've already had ACT cover the first replacement under warranty but I'm still paying for labor. To what extent is the clutch dragging ACT's fault, Evasive's fault for poor installation, or just unfortunate problems that come with cars and I should expect to foot the bill a third time? I don't mind paying for the work to get my car working but I would be interested to know why I have to deal with this again.
Old 04-04-2014, 04:08 PM   #20
mike the snake
Sounds like it's more an issue with the clutch master cylinder or the clutch slave cylinder, or air in the lines/needing bleeding.
If the hydraulics aren't disengaging the clutch enough, it will do exactly what your car is doing.
The fact that it gets worse when the car warms up is probably due to the extra drag from the cold fluid keeping the innards from spinning, allowing you to put it into gear, but once warmed up, the fragging clutch is spinning the innards which keeps you from getting it into gear when hot.
Once, I had a car that did this, and it was the floor mat which had bunched up under the pedal and didn't allow the pedal to be fully depressed.
Old 04-04-2014, 04:24 PM   #21
Pneub
I can confirm it is not the floor mat
Old 04-04-2014, 05:02 PM   #22
mad_sb
Make sure the pressure plate was replaced along with the clutch disk. I like ACT but if two of the same units develop the same problem, it's time to ask them for a full refund and some help paying for the labor... Dirk is a reasonable enough guy but you may have to prove it's a problem with the hardware by going to a different brand.
Hydraulics could for sure be the problem though. Clutch hose could be expanding under pressure, air in the line, defective master or slave cylinder etc etc.
Have you tried pumping the clutch a couple times before going into gear? If that helps I would be looking at hydraulics.
Old 04-04-2014, 05:15 PM   #23
Pneub
Pumping the clutch hasn't seemed to make any difference
Old 04-09-2014, 02:14 PM   #24
octavio.molina.1985
octavio.molina.1985's Avatar
Drives:
Hey guys, I was reading the following because it related to a rsx stage 2 clutch installation I had previously installed. I had the same issue with my rsx after a few months of driving it with the stage two competition clutch kit. I installed the flywheel, clutch disc, pressure plate and throw out bearing. So the issue was that a couple of moths later I felt a sudden partially clutch disengagement while fully pressing the clutch pedal. The gears were locked and if I tried to put it into a gear it would not go into the gear but would move the car forward while trying to push into 1rst. This indicates that the clutch is partially engaged or disengaged but not enough to grind the gears. The problem for me was the hydraulic system. First I bled the system and it solved the problem. A ewe weeks after the clutch master cylinder went out because of pedal adjustment issues. Finally I found out that the master cylinder will go out if the cylinder exceeds a certain pressure. I got the pedal adjusted after I replaced the clutch master cylinder.
I had warranties the clutch system and had installed the part twice so I knew that I couldn't have been the hardware. Adjustments are crucial. The pedal travel corresponding to disengagement of clutch or else you'll stress the clutch master cylinder. Haven't had a problem since last year august after that.
octavio.molina.1985 is offline   Reply With Quote
Old 04-09-2014, 02:44 PM   #25
Pneub
Thank you. I'm switching over to a Exedy Stage 2 clutch now. Hopefully they'll check all the adjustments, travel distance, and master cylinder.
Old 04-09-2014, 06:24 PM   #26
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
That's a shame. Which ACT setup did you have? Model # would be great.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
Old 04-09-2014, 06:52 PM   #27
Pneub
ACT SB7-HDSS Clutch Kit
Old 04-11-2014, 09:13 PM   #28
Pneub
Evasive Motorsports refunded my clutch and put the credit towards an Exedy stage 2, bled the master cylinder and did the install all for free. It doesn't get much better than that. Hopefully it's fixed.
At stop lights, do you stay in gear or go into neutral? boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 77 07-25-2014 09:23 PM
Can't get into any gear from a stop once car is warmed up Pneub Issues | Warranty | Recalls / TSB 5 04-04-2014 02:32 AM
Coasting to a stop in higher gear subiestyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-28-2014 05:31 PM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 10:06 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
