#15 |
Stig's dark passenger
#16 |
lol sorry. Translated from Canadian hockey lingo, that actually means "You're a good guy" and not "i want to make out with you"
| The Following User Says Thank You to protpibe For This Useful Post: | SkAsphalt (04-04-2014) |
#17 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#18 | |
Drives: None
Sent from my LG-D800 using Tapatalk |
#19 |
Does anyone have the actual turbo specs on this?
I know its a hybrid of something....vf39? And 18g? Wheel sizes, trims? David |
#20 | |
It's not required, but I changed my oil after the install just because. If you don't, you'll still have to add a little bit of oil since the lines, turbo, and oil reservoir will have increased the oil capacity in your car. You won't lose any oil during the install unless you're doing it wrong lol. Both oil tap locations (galley plug and back of the cam) are mounted on top of the engine, so everything would of drained down. You don't need to drain the entire coolant system, but you will need to top it off since you will lose some coolant when replacing the lines. Make sure you use the right stuff. My BRZ needed Subaru Super Blue. 1L of 0w20 from the dealer and a jug of coolant shouldn't run you more than $30 or so.
#21 |
The only thing I've seen is that it's listed as an AVO 18/49 Turbo. I'm assuming 49 is the trim since it's not exactly known for it's giant power numbers? edit; Or maybe the a/r? I have no idea, just speculating lol
#22 |
It's pretty much a standard 7cm TD05-18G turbo. So it's larger than a VF39.
| The Following 2 Users Say Thank You to xwd For This Useful Post: | SkAsphalt (04-04-2014), Sportsguy83 (04-07-2014) |
#23 | |
Drives: None
I left the measurements at the shop ![]() I have it written down. I'll give it to you later today Sent from my iPad using Tapatalk |
| The Following 2 Users Say Thank You to Astroboy For This Useful Post: | D K (04-06-2014), ZionsWrath (04-08-2014) |
#24 |
Drives: None
Does anybody have pics of where each line goes connected from the turbo?
| The Following User Says Thank You to Astroboy For This Useful Post: | ZionsWrath (04-08-2014) |
#25 |
Drives: vrooom...
here are some pics:
![]() ![]() ![]() ![]() ![]() Sorry I don't have a pic of the water line that goes to the heater hose return pipe at the back of the engine. |
| The Following 2 Users Say Thank You to M1K3 For This Useful Post: | onzippy (04-06-2014), ZionsWrath (04-08-2014) |
#26 | |
Drives: 2014 FRS
This is where the coolant will come gushing out when you take it off. Also have a picture of the oem coolant hose that gets removed. It ran along under the intake manifold. hmm.. Damn I didn't put the braiding on the new hose. |
| The Following 2 Users Say Thank You to onzippy For This Useful Post: | M1K3 (04-06-2014), ZionsWrath (04-08-2014) |
#27 | |
Drives: vrooom...
Good team work
I wouldn't worry too much about it. I'm just anal and do stupid things that are not necessary. |
#28 |
Drives: None
| Installing a Turbo Kit + other mods | chiefshayan | Forced Induction | 21 | 01-22-2014 11:58 PM |
| Installing a hood for the fr-s? | Frs32907 | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 08-16-2013 12:06 PM |
| installing harness | andrew5826 | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 07-25-2013 11:41 PM |
| need help installing this | chenshuo | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-14-2013 02:17 PM |
| tips for installing amp and sub | brichard0625 | Electronics | Audio | NAV | Infotainment | 4 | 05-19-2013 08:25 AM |
