Old 03-27-2014, 09:55 AM   #15
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Originally Posted by DrDuquette View Post
Anyone notice if you start out in 1st gear and lug the engine by accident the LEDs blink in and off. I find that interesting. BRZ only?
Yea, I have noticed this as well. More like flicker than blink though. Wonder if people with the auto trans experience the same thing.
Eurasianman is offline   Reply With Quote
Old 03-27-2014, 10:51 AM   #16
AdamBomb518
Stealth ***e
AdamBomb518's Avatar
The TapTurn module allows you to do this and 1,000 other things. It's like $80. Direct plug in. I'm gonna get one myself soon.
AdamBomb518 is offline   Reply With Quote
Old 03-27-2014, 04:13 PM   #17
Poodles
Drives: 2015 Series.Blue
Like you I don't understand the handbrake thing. To each their own. I like using the brake to blink the lights.
It's because they don't properly drive the LED's and only use resistors.
Originally Posted by codesplice View Post
I think I've seen it mentioned that the DRL LEDs are pretty picky about voltage. When the alternator output drops (like when you lug the engine in first), the voltage also drops below ~14VDC and the lights go out.
The "boomerang" LEDs have a proper LED driver, so they don't get affected like that.
Even the boomerangs don't have drivers, but they have a bit more circuitry that doesn't allow them to drop out as easy as the DRL's.
It's a shame how normal it is for the OEM's to skimp on driving the LED's properly...
Old 03-27-2014, 06:27 PM   #18
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
I don't see how this would allow what the OP wants.
subiestyle is offline   Reply With Quote
Old 03-27-2014, 07:39 PM   #19
emutcfut
Drives: 2013 Argento
IIRC when I was installing my Kartboy shifter I noticed a switch under the E-brake handle that turns the DRL on and off. Perhaps you can relocate that switch and keep it depressed. Thanks F1 for the pic!
emutcfut is offline   Reply With Quote
Old 03-27-2014, 08:00 PM   #20
AdamBomb518
Stealth ***e
My buddy has this installed and it allows him to have his ebrake on while still keeping his DRLs running. On the brz anyways. Should be the same for the frs. It does way more than just convenience signaling.
Old 03-28-2014, 01:04 AM   #21
Poodles
Keep in mind that will also cause other issues (disabling the "brake" light on dash, issues with the navigation IIRC, etc...)
Old 03-28-2014, 02:51 AM   #22
skyfire
skyfire's Avatar
Drives: Subaru BRZ
While parked (with handbrake on), my DRLs are off. Making handbrake off first time after engine start turns DRLs on, and no matter how I put handbrake, brake, gears, DRLs never offs till engine shutdown.
bot hard go pro
skyfire is offline   Reply With Quote
Old 03-28-2014, 08:32 AM   #23
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
Is your buddy Acree?
TapTurn flasher learn more here.
scottmcphee is offline   Reply With Quote
Old 03-07-2015, 05:45 PM   #24
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
Can anyone confirm the TapTurn does truly enable the LED DRLs to stay on with ebrake? If so, how do you set this?
Chad86 is offline   Reply With Quote
Old 03-08-2015, 12:59 PM   #25
scottmcphee
Well, I can confirm things about Tapturn.
The product does not normally have any interaction with any bulbs other than signal bulbs, front and rear. And the front and rear bulbs per side are linked, so both fire or stay lit in conjunction with one another, per side.
I am aware of some custom installations where people have wired up other lights with TapTurn in the equation. And Ive helped facilitate that too...
Old 03-08-2015, 04:01 PM   #26
TB
TB's Avatar
Drives: 2014 Scion FR-S Monogram
Here you go, sounds like exactly what you're asking for. With this I can have DRL's on when ebrake is pulled, and when projectors are on as well.
http://www.ft86club.com/forums/showthread.php?t=82908
SASKY◄ SASKATCHEWAN SK86BRZ / TB BUILD THREAD ►MY BUILD
TB is offline   Reply With Quote
Handbrake not working. MstrSHAKE Issues | Warranty | Recalls / TSB 44 01-19-2016 11:53 PM
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 09:56 PM
Leather Handbrake Boot Repair himbo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 12-12-2013 12:45 PM
BRZ complete red stitched handbrake BRZED Interior Parts (Incl. Lighting) 1 10-09-2013 03:28 PM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
