Old 03-25-2014, 04:58 PM   #15
evan
Drives: fr-s
Originally Posted by DoomsdayJesus View Post
They're shit. Either that, or the fluids they used were shit. Mine ate the synchros by 5000 miles without any tracking or beating it up. When they drained it the fluid was filled with metal shavings. Numerous other people in here have had the same problem and tranny replacements.
I'm fucked since I'm so heavily modified they would laugh me out the door if I tried excercising warranty, which I won't. Sucks since this is happening to stock cars and my mods obviously wouldn't be to blame.
evan is offline   Reply With Quote
Old 03-25-2014, 06:52 PM   #16
LuxuryVapes
Drives: 2013 Raven Scion Frs
Funny part is these transmission so "rated" to handle 300hp
LuxuryVapes is offline   Reply With Quote
Old 03-26-2014, 10:08 AM   #17
NOHOME
Drives: RAVEN
My gut feeling is that gearboxes are going to be an Achilles heel on these cars. They sure do hate the cold.
NOHOME is offline   Reply With Quote
Old 03-26-2014, 01:37 PM   #18
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Honestly from everything I've heard from everyone else, just using better gear oil seems to solve the problem. People switching to Motul 300V have said nothing but good things. Unfortunately I didn't find that out until it was too late with the first transmission, and I'm pretty sure upon replacement they used a different gear oil as well than stock.
I'd also make an early gear oil change, in the rear dif as well, part of your break-in. Both have been dirty as hell for everyone draining them.
DoomsdayJesus is offline   Reply With Quote
Old 03-26-2014, 04:08 PM   #19
evan
Drives: fr-s
I was using Pentosin MTF2 which worked great at solving cold operation issues until the ACT clutch mucked everything up. Ultimately, I'm going to dump this unit and go with some as of yet unidentified unit in the near future.
Old 03-26-2014, 05:49 PM   #20
pgeist
pgeist's Avatar
Drives: 2013 Black BRZ Limited 6MT
New Trans is in.. seems smoother.. but time will tell. Is there any break in procedure I should use or just drive normal?
Zeta Stage 2 Drop In + Red Silicone Tubing || Zeta SS Cat Back || DC Sports Cat-Delete Front Pipe || Torque Pro + MiniOBD Bluetooth || Fumoto F-108 Drain Valve || Konig Daylite Gold 17x7 +40 14.2lbs || Anarchy Motive Shift Knob
Future: Catted header, OEM Audio+
pgeist is offline   Reply With Quote
Old 03-26-2014, 05:51 PM   #21
evan
Drives: fr-s
Not really any break-in unless they changed the clutch too. I would be skeptical of the mtf they put in there. I know that Motul, Pentosin and RL MTL has worked better for others..
Old 03-26-2014, 05:55 PM   #22
chas3wba0
chas3wba0's Avatar
Drives: Yes
I would think the same as the initial break-in... don't shift at too high of RPM's for a while, run it through all gears, engine-brake, etc. just to let all the teeth in each gear "mate" properly
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 03-27-2014, 09:55 PM   #23
fledonfoot
Drives: Asphalt FR-S
New manual gearboxes come from Toyota pre-filled with factory fill fluid at the correct level. The auto's ship to us empty.
fledonfoot is offline   Reply With Quote
Speeds at each gears. mickey177 Engine, Exhaust, Transmission 10 08-25-2016 06:40 PM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 05:34 PM
You know what really grinds my gears...... z3ro Off-Topic Lounge [WARNING: NO POLITICS] 7 10-10-2013 01:55 PM
2nd gears a b*tch Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 32 01-29-2013 05:09 PM
Changing Gears Naughty AFRICA 10 01-09-2013 12:30 PM
