Old 03-05-2014, 08:34 AM   #15
wparsons
wparsons's Avatar
Originally Posted by WolfsFang View Post
Here is my thread on my wheels, they are 8.5 +14 front and 9.5 +16 rear. The rear is stock camber while the front are what ever stance gave me.
http://www.ft86club.com/forums/showthread.php?t=38680
By stock camber in the rear do you mean you adjusted it back to stock settings, or just left it alone and let the drop give you whatever camber it was going to give you?
flickr
Old 03-05-2014, 03:36 PM   #16
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
The rear have stock control arms so it never changed since there is no way of adjusting camber with stock parts. On the front picture I just remembered I took that pick with stock suspension and never retook when I got coils. With the coils on now the top of the wheel is 100% flush with the fender, I never touched the camber on the plates. If you want I could retake a pic of how the fronts look now.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 03-05-2014, 04:17 PM   #17
wparsons
wparsons's Avatar
If you haven't adjusted it, but are dropped that much then you have way more negative camber than stock. I would bet you're at -3* in the rear (stock is about -1.5*). The lower the car is the more camber you'll have (without adjusting anything), especially in the rear. As the suspension compresses (or you lower it) you get more negative camber, the front doesn't gain nearly as much as the rear though.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
WolfsFang (03-05-2014)
Old 03-05-2014, 04:47 PM   #18
WolfsFang
Scrape Master
WolfsFang's Avatar
Thanks never knew this, I think im maxed out on the rear unless the cold is binding it and not letting me go lower.
Old 03-17-2014, 03:28 PM   #19
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Old 03-17-2014, 06:15 PM   #20
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Originally Posted by Oh Damn Andrew View Post
To be accurate, these are GTR copies but you'll get the idea
wow this looks amazing. and like spitfire said up above, -2 to -3 degrees all around and youll be good, so pretty much natural camber when lowering the car + playing with the camber plates a lil and you should be golden. Good luck, looking foward to seeing this!
SLICVIC is offline   Reply With Quote
Old 03-18-2014, 12:15 AM   #21
CreinCrein
any guess as to how much that silver car is lowered by?
CreinCrein is offline   Reply With Quote
Old 03-18-2014, 02:34 AM   #22
Tranz
Tranz's Avatar
Drives: 86 GTS
While searching around for wheels a while ago, I found this, unsure of how thick the adapter is (they are actual 33GTR wheels as far as my knowledge goes) but:
Looks amazing imo, and doesn't seem like you need crazy camber to get them to fit.
Tranz is offline   Reply With Quote
Old 11-20-2014, 10:47 PM   #23
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Bringing this back from the dead.
Anybody have legit concrete facts of what needs to be done to make these fit? Don't want to run silly camber.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 11-21-2014, 02:08 AM   #24
slava
slava's Avatar
Drives: brZed
Yea I have these wheels. I run 15mm kicks adapters with them. I use them as drift spares now, but when I had them all around I ran -3.5 camber front and -2 rear.
Current (-3 camber rear)
slava is offline   Reply With Quote
The Following User Says Thank You to slava For This Useful Post:
HeadBanger (11-22-2014)
Old 11-21-2014, 02:09 AM   #25
slava
slava's Avatar
Drives: brZed
oh and as far as what needs to be done, if you dont cut the factory studs when you install the adapters, you will have to shave some metal off the wheel (in the back) to make them fit. This can be the case with a lot of different wheels with the adapters.
Old 01-02-2017, 09:24 AM   #26
Falken86
Falken86's Avatar
Drives: '13 WRB BRZ '22 ISM BRZ Ordered
Wheel Directory: OEM Nissan Skyline R33 17x9.0 +30
Bump from the dead. Thought I would post mine finally.
Falken86 is offline   Reply With Quote
Old 11-21-2017, 01:10 PM   #27
Falken86
Falken86's Avatar
Also plan on doing the hub conversion at some point next year!
Wheel Directory : Drag DR-38 17x9.0 +38 smbstyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 07-21-2019 07:32 PM
Wheel Directory: ESM 004 17x9.0 +38 Scott Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-26-2017 05:54 AM
Wheel Directory: Rota DPT 17x9.0 +35 lightdir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 05-17-2016 04:10 AM
Wheel Directory: Rota RT5 17x9.0 +30 b-25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-03-2013 03:21 PM
Wheel Directory: XXR 531 17x9.0 +35 Drftfan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-19-2013 06:16 PM
