| Northern California NorCal |
#15 |
Drives: 2013 Scion FR-s
I did Raceseng reverce lock. I used a drill bit and punch out with small hammer. The only issue I had was that the cable loop was not aligned with the hole. I had to reach under the loop and push up to align with the hole. Works great and looks fine.
#16 |
F Z1LLA
Drives: Lexus IS-F Series 2
2URGSE |
#17 |
Drives: 2013 Subaru BRZ Limited GBS
I am in similar situation as I have portions of small philips screwdriver broken in the hole as well... Anyone have suggestions on how to remove embedded broken pieces? (other than getting another punch and power through...)
#18 |
Coffee Snob
Drives: '14 SWP BRZ Limited
You need a solid punch, literally, not one that is hollow in the middle. It'll push it out - sadly it's going to be tough because your screwdriver might have expanded the pin some.
| The Following User Says Thank You to leicaboss For This Useful Post: | Zed (03-11-2014) |
#19 |
Yes this is what I am afraid of... I am also thinking the hole may have been damaged due to improper tool use... I plan on swinging by the hardware store to pick up real punches and trying again this weekend. Fingers crossed that I finally get to finish this mod
#20 | |
Coffee Snob
http://www.homedepot.com/p/Dasco-Pro...e-34/100507476 The above set is the one I found through trial and error to be available at Home Depots (check online first) for pickup and aren't too expensive. Nice to have punches around anyway. Use a mallet or cover the punch with a towel so when you bash it the paint won't flake off and get everywhere in your cabin. Edit: and put your car into reverse first, and hold your shifter firmly. You don't want to be bashing up your trans.
#21 | |
Thanks, Ill look into that brand. Any ol hammer will work with the punch? or should I be looking into some fancy rubber mallet types? I was hacking away via metal headed hammer and philips screwdriver (which no doubt made some lasting scars on the trans
). Detailed RecountQuote:
#22 |
Drives: blue FRS
Thank guys i finally got it. much love
#23 |
Drives: IB '05 E46 M3 ZCP
Reviving this thread...
Thanks to everyone with tips/tricks on the install. It was entirely way TOO EASY when I installed mine. Took maybe 5 min MAX. Just used a 3/32 drill bit & hammered through while it was in Reverse gear.
![]() '05 Interlagos Blue |
| The Following User Says Thank You to E46toFT86 For This Useful Post: | BAMF86 (03-22-2014) |
#24 |
I tried this again last night to little success with the proper punch. The broken bit of screwdriver is somehow embedded with the pin. As I hammered the punch, it would get caught between the broken screwdriver bit and the empty space inside which then wedged the punch off center. Anyone have ideas on how to remove the broken bits inside the hole? I was thinking a strong magnet may help ease it out but I'm not positive it will be that easy...
#25 |
Drives: 2013 BRZ Silver M/T
Just installed mine. Pin was hard as everyone stated. Used a Allen key 3/32.
Spent 10 min hitting it out and also spent 15 getting the ashiko knob to align right. Will post pics soon. Sent from my HTC One using Tapatalk |
#26 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
Where can I get a punch pin ? Canadian tire didn't know what this was ?!?
Isn't this just one of those punch metal spikes with rubber on the end?
#27 | ||
aeiou
Drives: WRB BRZ
But good on you for searching.In any case, if somebody wants to borrow a pin punch, let me know. A center punch (has a point on the end) might be a bit easier, but I took mine off a few times already. It's very easy. Here's how my Beatrush looks ![]() and fellows owners sometimes comment on my black interior parts, so
#28 | |
Drives: Toyota GT86
I now have installed my Raceseng reverse lockout. I'm still getting used to the Raceseng knob...looks really sharp and shifts well, just not sure about it. Only time will tell.
| Reverse lockout rattle fix | clintavo | DIY (Do-It-Yourself) Guides | 24 | 06-17-2020 12:27 PM |
| Raceseng reverse lockout installed | OICU812 | Cosmetic Modification (Interior/Exterior/Lighting) | 22 | 08-05-2015 10:33 AM |
| FS: Beatrush Reverse Lockout | TONY_BRZ | Interior Parts (Incl. Lighting) | 10 | 05-15-2015 12:04 PM |
| Beatrush Reverse Lockout Lever | simpleisbest | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 04-16-2015 11:19 PM |
| Reverse lockout vibration | SubaSteve | Issues | Warranty | Recalls / TSB | 4 | 03-23-2013 02:26 PM |
