Old 02-10-2014, 03:48 PM   #15
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
I have a pretty good idea. A basemap should at a minimum have MAF scaling for the additional flow/possible change in pipe size, fuel injector scaling if injectors were changed, and possibly MAP sensor scaling if you changed yours. I would expect the car to be safe to drive and have a very safe ignition map. I would not drive if you won't have a boost gauge and wideband gauge to verify that your car is running properly.
I have p3cars gauge so i have a pretty good idea
lbroskee is offline   Reply With Quote
Old 02-10-2014, 04:07 PM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Have we learned nothing from @nelsmar 's experience? Install a wideband and don't rely solely on the OEM sensor.
The Following User Says Thank You to King Tut For This Useful Post:
Sportsguy83 (02-10-2014)
Old 02-10-2014, 04:13 PM   #17
lbroskee
lbroskee's Avatar
Well duh but wudnt boost b fine? I def am adding a wideband to it tho
Old 02-10-2014, 04:16 PM   #18
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Boost should be fine as long as you have an aftermarket MAP sensor. The ECU doesn't report the actual boost the engine is running though, you have to subtract the atmospheric pressure. I am not sure what the P3 cars gauge does as far as that.
lbroskee (02-10-2014)
Old 02-10-2014, 04:20 PM   #19
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
I was referring to the base map I was given as a joke.
Ironsquid is offline   Reply With Quote
Old 02-10-2014, 04:23 PM   #20
nelsmar
lol...
And to the OP, depends on the "base map". To me a base map is a map that makes the vehicle operational with limited ability providing the ability to transport the vehicle to a tuner. If you are buying a kit and you are getting a basemap talk to your tuner before continuing. If they have a polished basemap that is more of a "canned tune" and they give you the green light then do it. But if its say a speed density based tune then it can be skewed by a number of things and may require basic adjustments prior to being considered safe to drive.
In short: Call your tuner that made your basemap and ask him the question, not a forum full of idiots like us.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 09:56 PM
Anyone running Advan AVS? Wise Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-31-2013 10:52 PM
Running low on gas Arctek83 Scion FR-S / Toyota 86 GT86 General Forum 63 04-15-2013 07:35 PM
HID for Daylight Running Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 3 09-21-2012 06:47 PM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
