#15 |
Drives: 2013 BRZ Limited-SWP
I see a trip to the local Home Depot also. It should cost me about $2
#16 |
Drives: JAWS
@enjoyminutemaid Did you use any spacers or just the rubber stop itself? I've never trained myself to not press the clutch pedal all the way to the floor, so I think this could be a great mod for me. I did however adjust my clutch pedal height, still above the height of the brake pedal.
#17 | |
Drives: 2013 asphalt frs
Just bought mine! How many of the spacers did you use?
| The Following User Says Thank You to sanmarcosfrs For This Useful Post: | JB86'd (03-11-2014) |
#18 |
Drives: Subaru BRZ Limited WRB Manual
I didn't use any of the spacers. Don't think it would be a good idea with oem clutch.
| The Following User Says Thank You to enjoyminutemaid For This Useful Post: | sanmarcosfrs (02-15-2014) |
#19 |
Drives: Silver Subaru BRZ
@enjoyminutemaid Could you post the instructions that came with the works kick clutch pedal stop? Or could someone else post a DIY. The only site that sells the kit comes out to over $40 shipped, pretty crazy. I went to Home Depot and tried to do it myself but the parts I got aren't ideal and I was killing myself trying to install it, and it didn't work. Any help?
#20 |
I bought mine from 86 industries.... Pretty sure I got ripped off. Haven't heard anything in two weeks
#21 |
#22 |
Damn, I guess I got in before the lock on that guy. Even at $40 it would still be worth it to me, regardless of its home depot origins. Maybe contact Works directly?
#24 |
Drives: Asphalt Scion FR-S
Home depot and Lowe's don't have the exact rubber stopper, but a quick browse on McMaster-Carr would get you what you need.
#25 |
Drives: 2014 Monogram FR-S White MT
got any pics or diy to how to post this up?
#27 |
There really isn't much to it as it's basically just a bolt with that goes through a hole and you put a nut on the back end to secure it, but you will find things much easier if you can figure out a way to pin the clutch to the floor but still have two free hands.
#28 |
which hole does it go through?
| whining/whirring noise during high load/rpm clutch engagement | 7thgear | Issues | Warranty | Recalls / TSB | 105 | 06-19-2017 12:04 PM |
| clutch Engagement Issue? | Bu-Tang | Issues | Warranty | Recalls / TSB | 68 | 02-19-2017 03:03 PM |
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 01:11 PM |
| DI seal improved material | radroach | Engine, Exhaust, Transmission | 21 | 01-16-2014 01:42 AM |
| Clutch Pedal Engagement Adjustment | denverizzles | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-25-2012 06:01 PM |
