Old 05-03-2017, 11:24 PM   #15
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Getting the shelf installed was fairly straight forward.
The light bar isn't exactly plug and play so it looks like a glue gun should do the trick.
Chad86 is offline   Reply With Quote
Old 05-06-2017, 02:27 AM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Does anyone know of aftermarket shelf with deleted brake light but retained child seat mount brackets?
Old 01-27-2018, 02:10 PM   #17
Brink
Drives: 2017 BRZ
Can anyone with the PWJDM rear deck tell me if installing it requires the panels on both C-pillars to be removed? Thinking about ordering the type 1 to go with my Intec 3rd brake light and just want to know what to expect. I know the OEM rear deck is supposed to come out without removing C-pillars, but looking at the tabs on the ends of the PWJDM deck I can't tell if I'll need to remove them to install this. I'm guessing those tabs go under the c-pillar panel? Can it be installed with just 1 panel off?
Looks like I'll need to remove the passenger side pillar to run the wiring for the Intec anyway, but I might install the Intec before I get the deck so I want to avoid opening up the c-pillars more than once.
Brink is offline   Reply With Quote
Old 01-27-2018, 04:23 PM   #18
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I made mine out of the stock one.
I LIKE TIRES!
Old 01-29-2018, 07:01 PM   #19
Brink
Drives: 2017 BRZ
Anyone know about this? I'll probably have time to wire up my Intec brake light on Wednesday. I haven't ordered the rear deck yet but will probably end up getting that, just don't want to have to open up the c-pillar(s) an extra time.
Password:JDM Dry Carbon Fiber Rear Deck Shelf Subaru BRZ / Scion FR-S (Type I/ II) password:jdm Interior Parts (Incl. Lighting) 124 01-28-2015 03:17 PM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
eliminate rear deck popping with rear strut bar? chenshuo Issues | Warranty | Recalls / TSB 11 07-03-2013 06:44 PM
Good aftermarket Deck Unit with Navi?? taimysho0 Cosmetic Modification (Interior/Exterior/Lighting) 2 05-17-2013 07:55 AM
P8400 Aftermarket deck HELP NEEDED WITH WIRING iamkyle Electronics | Audio | NAV | Infotainment 1 01-13-2013 03:41 AM
