Old 12-27-2013, 09:03 PM   #15
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by brichard0625 View Post
this happen to me once. disconnect black cable(negative) from the battery. ull need a 10mm wrench. Let the car sit for like 5 mins and hook it back up. make sure ecutek cable is plugged in correctly and try it again. I had the same problem one time and this worked for me. Good luck
Thanks. I had tried that already, no luck. But everyone keep the ideas coming, just sitting here in my garage tryign to get something to worked.
just installed software on a different computer to , but still same problem.
gdrider77 is offline   Reply With Quote
Old 12-27-2013, 09:04 PM   #16
Boostedpro
I know this sounds weird but does your cigarette lighter work? The obd2 port and lighter are usually on the same fuse. If that fuse blows from too much load on the lighter it will cause your obd2 port not to have power and there will be no communication.
Boostedpro is offline   Reply With Quote
Old 12-27-2013, 09:07 PM   #17
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
do u have team viewer?
wanna see if i can help
Old 12-27-2013, 09:08 PM   #18
gdrider77
gdrider77's Avatar
It has power. I checked all my fuses with a multi meter to be sure and all good.
Old 12-27-2013, 09:30 PM   #19
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
i bricked my pcm.... not using ecutec, but i digress...
tried resetting ecu, removing battery cables, connected with toyota techstream n tried to reflash back to stock rom, sadly once you brick it, its got to be reformatted and reflashed. the toyota software cant make any connection to the ecu, and just basically "doesnt see it". all other systems in the vehicle work fine... other than no start/no go...
in my case, toyota is replacing ecu which they say "is on backorder from suby japan"... yeah i been in a rental for a month to the day...
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 12-27-2013, 09:46 PM   #20
jamesm
weird on the backorder thing... a local bricked his and just picked up a new ecu at the dealer for like $600 iirc.. had it in stock
Old 12-27-2013, 09:49 PM   #21
gdrider77
gdrider77's Avatar
Yeah, hoping that worst case and not something i look forward to. Seems crazy that there wouldnt be a way to reset/reflash the ecu with software. As i said before, really hoping @EcuTek can chime in. Or possibly a master tuner.
I reached out to paul @AVOturboworld and hoping he might have some insight, as i purchased my turbo kit and my ecutek license, dongle and cable from him.
Figures it happens on a damn friday night...ugh.
Old 12-27-2013, 09:55 PM   #22
SkullWorks
Drives: SSM LT MT BRZ
I recovered my Bricked ECU with ECUflash software,
It wouldn't recognize with anything at the time of the bricking either.
Do you have a tactrix OP2.0 cable or access to one?
SkullWorks is offline   Reply With Quote
Old 12-27-2013, 09:59 PM   #23
gdrider77
gdrider77's Avatar
I can check with a few peeps, might be able to get my hands on one. but probaly not till next week.
Old 12-27-2013, 10:03 PM   #24
SkullWorks
have you reached out to @Visconti ?
He has actually been very supportive of the community since his re-instatement
Old 12-27-2013, 10:15 PM   #25
gdrider77
gdrider77's Avatar
Yes, he (@visconti) has actually reached out to me, how is that for support!
And @whitefrs jumped on remotely and checked it out, seeing the same issues i had.
And Toni at @FA20club has been chatting with me via email.
And Paul at @AVOturboworld has also said he has some ideas and is reaching out to Ecutek to see about unbricking my ECU. So hopefully can get this thing up and running soon! i have a feeling alot will just depend on @EcuTek and how and when they can get to it. Really hoping i wont have to purchase a new ecu....
Great that we have a community that rallys like this....
i am going to need to send beers and pizza out to some folks...
Old 12-27-2013, 10:49 PM   #26
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
I'm going to keep this in mind, a tactrix cable sure as shit is cheaper and easier than a new ecu.
Deadspool is offline   Reply With Quote
Old 12-28-2013, 01:10 AM   #27
steve99
Originally Posted by gdrider77 View Post
That the thing, cant flash again, it wont even connect to the ecu now...
"No response to OBD Request"
So cant flash, read dtc, start car, etc....
Trying to see if there is a way to reset the ecu..
I am thinking and hoping that with all the number of people and tuners on here that flash ecus, this has happened before, and there has to be a way to reset the ecu.....
thanks for the help though.
Have you checked to odb-2 socket under the dash carefully check that one or more of the pins have not been pushed back into the socket . Its possible the power pins are ok but one of the data pins is crook. might have to remove mounts and check from rear of obd socket.
It does sound like a hung ecu but worth a check in case the dud pin caused the flash fail .
Old 12-28-2013, 01:45 AM   #28
Lonewolf
Lonewolf's Avatar
Drives: Moped
Too bad he as well as other tuners who might have been able to help have been booted again...
lovethe@mentions
Ecutek flash & warranty 3000HP Software Tuning 40 04-06-2015 10:33 AM
FA20CLUB ecutek flash mach330 Software Tuning 19 08-09-2013 10:35 AM
When do you reset the Avg MPG? WRXcellent BRZ First-Gen (2012+) — General Topics 50 01-16-2013 10:30 PM
DynoComp EcuTek Flash JRollar Engine, Exhaust, Transmission 8 01-16-2013 06:16 PM
FA20 Stg 2 Ecutek flash or no? DC-FRS Engine, Exhaust, Transmission 25 12-25-2012 07:13 AM
