| Software Tuning Discuss all software tuning topics. |
Drives: Subaru BRZ Limited
Ecutek Corrupt ECU, Bad Flash, Can i reset?
So just wondering, has anyone ever got a bad flash, hung flash, etc....with @EcuTek , if so how do they fix their ecu?
Reason i ask. recently flashed my ecu back to stock and trying to flash it with a new tune, etc...was going fine, on the part where it says, turn off ignition, i do that, then it says turn on ignition. I do that. and nothing.....it just hung up. normally you get the success message and such, but this time it did nothing..... Now my car wont start.....it turns on and looks normal, but wont actually even try to start, just turns back off. If i try to detect the vehicle with the software, it says the obd request failed. I can manually pick the vehicle. then when i try to program it gives me the no obd request error again. Here is a screenshot showing it.... Any ideas? Anyone? And because i know it will be asked, i have the most recent software, i have tried resetting both my computer, adn turned the car on and off, unplugged all dongles, obd cabls, etc.. and replugged.
#2 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
try to flash it again.
ur flash didn't go thru because maybe ur cable wasn't plug correctly or you moved it
#3 | |
"No response to OBD Request" So cant flash, read dtc, start car, etc.... Trying to see if there is a way to reset the ecu.. I am thinking and hoping that with all the number of people and tuners on here that flash ecus, this has happened before, and there has to be a way to reset the ecu..... thanks for the help though. |
#4 |
Thupercharged
Maybe a bad connection, try wiggling the OBDII plug or putting pressure on it while flashing... I remember hearing something about our OBDII plug/pins getting bent easily and having poor connection
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#5 |
Love Boost!!!!!!!!
Make sure obd2 is plugged in property
Select the car manually And then try flashing it Sent from my iPhone using Tapatalk
#6 |
Love Boost!!!!!!!!
If u choose detect vehicle it wont work but it has to work manually if u have the latest Ecutek software updated
#7 |
Yeah, i have tried the manual selection, that is how i got the program screen and got that screenshot.
#8 |
SLO NO MO
Make sure your battery is good - I had a similar issue one time and it turned out I had a bum battery and it didn't have enough cranking power to turn the motor over after a flash.
| The Following User Says Thank You to Foobar For This Useful Post: | gdrider77 (12-27-2013) |
#9 | |
I also put on a charger to be safe/sure, still no luck. |
#10 |
Love Boost!!!!!!!!
#11 | |
"No response to OBD request" Just seems like the software and ECU are not communicating. I tried pressing in the cable harder, wiggle it, etc...Cant see how that could go bad....but who knows. Really hoping @EcuTek will have some ideas. |
#12 |
Love Boost!!!!!!!!
u might need a new license then
#13 |
I believe its something with the ecu....bricked im guessing.
I have torque and a tablet with a bluetooth elm device, tried that, and it cant connect to eh ecu either, so just seems like the ecu is dead... |
#14 |
Drives: 2013 Scion Frs(Scarlet)
this happen to me once. disconnect black cable(negative) from the battery. ull need a 10mm wrench. Let the car sit for like 5 mins and hook it back up. make sure ecutek cable is plugged in correctly and try it again. I had the same problem one time and this worked for me. Good luck
| The Following User Says Thank You to brichard0625 For This Useful Post: | gdrider77 (12-27-2013) |
| Tags |
| lovethe@mentions |
| Ecutek flash & warranty | 3000HP | Software Tuning | 40 | 04-06-2015 10:33 AM |
| FA20CLUB ecutek flash | mach330 | Software Tuning | 19 | 08-09-2013 10:35 AM |
| When do you reset the Avg MPG? | WRXcellent | BRZ First-Gen (2012+) — General Topics | 50 | 01-16-2013 10:30 PM |
| DynoComp EcuTek Flash | JRollar | Engine, Exhaust, Transmission | 8 | 01-16-2013 06:16 PM |
| FA20 Stg 2 Ecutek flash or no? | DC-FRS | Engine, Exhaust, Transmission | 25 | 12-25-2012 07:13 AM |
