#15 |
Drives: 23 BRZ
Getting closer. Turbo has been mounted. I've routed all of the turbo oil/coolant lines. Next will be the oil pump and intercooler/piping.
Oil line feed installed. ![]() Spring clamps added to evap lines to hold under boost. These things were a pain to install. ![]() Factory overpipe and shielding removed. Biggest puzzle piece I've had to remove yet. Would have been much easier when I had the tranny removed. ![]() New overpipes installed. ![]() Turbo mounted, bottom and top view. ![]() ![]() A moth kept flying into my turbo piping, no joke. I had a bit of a struggle to get one out. Sealed them out for good!
#16 |
Drives: 23 BRZ
Some photos of the turbo exhaust piping / downpipe / waste gate. Tonight I'll completing the exhaust piping. Remaining items for the turbo - oil scavenging pump, intercooler and piping, intake piping, BOV, vacuum lines, ECU reflash etc... If all goes well I should be starting her up this weekend.
#17 |
I like to eat!
Great pictures. Definitely subscribed.
#18 |
Drives: 23 BRZ
Exhaust, sway bar and end-links installed.
Exhaust photos. ![]() ![]() ![]() ![]() Sway bar and end-links. ![]()
#19 |
Drives: 23 BRZ
Oil scavenge pump mounted. Over the next couple days I will finally be able to get to the fun part of bolting on the intercooler and piping :-D
Oil scavange pump. ![]()
#20 |
Drives: 23 BRZ
It's all coming together now. Pic heavy update.
Oil pump line fitted. ![]() Rota center caps. ![]() Intercooler mounted. Sorry PTuning, not trying to hide the logo. Just trying to be less "flashy". It is still there but very faint. I chose the red IC piping to really show off the fine work when I pop the hood ;-) ![]() ![]() MAP sensor installed. ![]() First intercooler piping from the turbo compressor outlet. ![]() Blow-off valve fitted. ![]() My dog sleeping on the job. ![]() ![]() A months worth of dust build up, sigh... ![]() Second intercooler piping from the turbo with blow-off valve, mounted and (almost) ready for boost!
#21 |
Thanks
Nice build man. What alignment settings are you running with the springs? Would 245 width fit? Any rubbing?
#22 |
Drives: Nissan Primera GT
Good stuff, can't wait for some more progress.
#23 |
Drives: 2013 Fr-S
Good thread... I have always wondered about the install process of this kit.
Any plans on going with an aftermarket header? |
#24 |
Drives: S1000RR
Keep the pics coming. Looks like you got a buddy to help you out
![]() MrC |
#25 | |
Drives: S1000RR
@RB6freak, I recommend you reposition the WG barb fittings to make sure the boost line is away from the bottom of the vehicle as shown below: ![]() MrC |
#26 | |
Drives: 23 BRZ
245 - I doubt it without a spacer on the front. My 235's are maybe 10mm from rubbing the spring. I haven't had any rubbing issues locking the wheel side to side and going up driveway at an angle. |
#27 | |
Drives: 23 BRZ
Not yet. Down the road, possibly.
Thank you sir. Will revisit this tonight. |
#28 |
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
Subscribed! Awesome walkthrough of your Turbo Install. Looking forward to it!
| AVO turbo kit for BRZ - initial build thread | AVOturboworld | Forced Induction | 3109 | 12-01-2019 03:55 PM |
| My trip to FBM - FBM Premium Turbo Kit build | brzaapi | Forced Induction | 170 | 11-12-2013 06:04 PM |
| 400hp build and other turbo questions. | Ludacrits | Forced Induction | 22 | 10-26-2013 09:01 AM |
| Just wanted to show off my turbo build | sw20kosh | Forced Induction | 5 | 04-01-2013 03:16 PM |
| Turbo engine build, and parts | No Limit Motorsport | Forced Induction | 30 | 12-11-2012 07:32 PM |
