Old 01-08-2014, 01:24 AM   #15
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Getting closer. Turbo has been mounted. I've routed all of the turbo oil/coolant lines. Next will be the oil pump and intercooler/piping.
Oil line feed installed.
Spring clamps added to evap lines to hold under boost. These things were a pain to install.
Factory overpipe and shielding removed. Biggest puzzle piece I've had to remove yet. Would have been much easier when I had the tranny removed.
New overpipes installed.
Turbo mounted, bottom and top view.
A moth kept flying into my turbo piping, no joke. I had a bit of a struggle to get one out. Sealed them out for good!
rb6freak is offline   Reply With Quote
The Following 4 Users Say Thank You to rb6freak For This Useful Post:
Deadpool_25 (05-29-2015), Hicklinc (01-30-2018), Proof (01-08-2014), ZionsWrath (01-18-2014)
Old 01-14-2014, 01:29 PM   #16
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Some photos of the turbo exhaust piping / downpipe / waste gate. Tonight I'll completing the exhaust piping. Remaining items for the turbo - oil scavenging pump, intercooler and piping, intake piping, BOV, vacuum lines, ECU reflash etc... If all goes well I should be starting her up this weekend.
The Following User Says Thank You to rb6freak For This Useful Post:
Old 01-14-2014, 01:39 PM   #17
Pete156
I like to eat!
Great pictures. Definitely subscribed.
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
Old 01-15-2014, 11:16 PM   #18
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Exhaust, sway bar and end-links installed.
Exhaust photos.
Sway bar and end-links.
The Following 3 Users Say Thank You to rb6freak For This Useful Post:
Hicklinc (01-30-2018), Kakawate (01-20-2014), ZionsWrath (01-18-2014)
Old 01-16-2014, 04:04 AM   #19
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Oil scavenge pump mounted. Over the next couple days I will finally be able to get to the fun part of bolting on the intercooler and piping :-D
Oil scavange pump.
Old 01-18-2014, 05:11 AM   #20
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
It's all coming together now. Pic heavy update.
Oil pump line fitted.
Rota center caps.
Intercooler mounted. Sorry PTuning, not trying to hide the logo. Just trying to be less "flashy". It is still there but very faint. I chose the red IC piping to really show off the fine work when I pop the hood ;-)
MAP sensor installed.
First intercooler piping from the turbo compressor outlet.
Blow-off valve fitted.
My dog sleeping on the job.
A months worth of dust build up, sigh...
Second intercooler piping from the turbo with blow-off valve, mounted and (almost) ready for boost!
The Following 2 Users Say Thank You to rb6freak For This Useful Post:
kanundrum (07-09-2015), ZionsWrath (01-18-2014)
Old 01-18-2014, 07:01 AM   #21
ZionsWrath
Thanks
ZionsWrath's Avatar
Nice build man. What alignment settings are you running with the springs? Would 245 width fit? Any rubbing?
Old 01-18-2014, 08:16 AM   #22
Ninth_Cloud
Drives: Nissan Primera GT
Good stuff, can't wait for some more progress.
Ninth_Cloud is offline   Reply With Quote
Old 01-18-2014, 10:04 AM   #23
jdm-az-fuk
Drives: 2013 Fr-S
Good thread... I have always wondered about the install process of this kit.
Any plans on going with an aftermarket header?
jdm-az-fuk is offline   Reply With Quote
The Following User Says Thank You to jdm-az-fuk For This Useful Post:
Old 01-18-2014, 11:18 AM   #24
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Keep the pics coming. Looks like you got a buddy to help you out
MrC
Mrc@ptuning is offline   Reply With Quote
The Following User Says Thank You to Mrc@ptuning For This Useful Post:
Old 01-18-2014, 11:39 AM   #25
Mrc@ptuning
Drives: S1000RR
@RB6freak, I recommend you reposition the WG barb fittings to make sure the boost line is away from the bottom of the vehicle as shown below:
MrC
The Following 2 Users Say Thank You to Mrc@ptuning For This Useful Post:
Old 01-18-2014, 01:39 PM   #26
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Thank you. I only have about 20 miles on the tires, haven't had the chance for an alignment. I'm not getting one right away until I break in the car. Also, I may be changing the suspension setup too. Once I get it on the track a few times I will know which direction to take.
245 - I doubt it without a spacer on the front. My 235's are maybe 10mm from rubbing the spring. I haven't had any rubbing issues locking the wheel side to side and going up driveway at an angle.
Old 01-18-2014, 02:08 PM   #27
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Not yet. Down the road, possibly.
MrC
Toan and Patrick have been coaching me throughout the turbo build. Those guys are a great help!
MrC
Thank you sir. Will revisit this tonight.
Mrc@ptuning (01-20-2014), ZionsWrath (01-18-2014)
Old 01-18-2014, 03:58 PM   #28
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
Subscribed! Awesome walkthrough of your Turbo Install. Looking forward to it!
carlossanchez89 is offline   Reply With Quote
The Following User Says Thank You to carlossanchez89 For This Useful Post:
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 03:55 PM
My trip to FBM - FBM Premium Turbo Kit build brzaapi Forced Induction 170 11-12-2013 06:04 PM
400hp build and other turbo questions. Ludacrits Forced Induction 22 10-26-2013 09:01 AM
Just wanted to show off my turbo build sw20kosh Forced Induction 5 04-01-2013 03:16 PM
Turbo engine build, and parts No Limit Motorsport Forced Induction 30 12-11-2012 07:32 PM
