Old 11-20-2012, 10:21 PM   #1
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Turbo engine build, and parts
Just got a set of these new CP pistons in for a customer. They are 9:1 compression and look pretty sweet. I am so used to selling 99.5/100mm STI pistons its weird to see this small 86mm. We also have some Carrillo rods on order for it which will be here soon and I will post pictures. Combined with the slightly thicker HKS gasket compression should be 8.9:1, which should allow the motor to take a fair amount of boost.
HKS headgaskets
HKS spark plugs
Pauter connecting rods
No Limit Motorsport is offline   Reply With Quote
Old 11-20-2012, 10:48 PM   #2
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
That ringland looks stout.
dorifuto is offline   Reply With Quote
Old 11-20-2012, 10:51 PM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Can't wait to see how it turns out, what turbo are you putting on there?
JoeBoxer is offline   Reply With Quote
Old 11-21-2012, 04:18 AM   #4
cruzinbill
Drives: Argento 6spd FR-S
with a CR of 8.9:1 you should be able to run like 45lbs of boost lol since stock 20lbs appears to be fine.
cruzinbill is offline   Reply With Quote
Old 11-21-2012, 04:44 AM   #5
adamls2
adamls2's Avatar
Drives: LS460
Awesome!
~~adamls2~~
~~Injection is nice but I'd rather be blown~~
adamls2 is offline   Reply With Quote
Old 11-21-2012, 05:42 AM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
kinda where I'm at to. I'm getting the impression that in order to take advantage of such a drop in compression, with these combustion chambers, you'd probably want to be running hardblok aswell.
I can't wait to see the results of where this build is going though, should be stunning.
Old 11-21-2012, 09:34 AM   #7
benster
Drives: none yet
even with an open deck, if you add aftermarket sleeves you'll increase the rigidity of the block by a big margin. but I'm with you on the fact that dropping 3.5 points in compression is huger, I'm sure going down to 10, 10.5 would've been more than enough.
benster is offline   Reply With Quote
Old 11-21-2012, 10:21 AM   #8
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Wow that's low compression. Definitely in for results. This going to be a drag car mainly?
Jeff86 is offline   Reply With Quote
Old 11-21-2012, 11:02 AM   #9
Hal@Dynosty
Saw these at SEMA - they looked great!
Hal@Dynosty is offline   Reply With Quote
Old 11-21-2012, 12:06 PM   #10
No Limit Motorsport
Its a street car. It really isn't low compression at all, these cars just come abnormally high. It is perfect turbo engine compression for pump fuel.
Most WRX/STI guys run 8.2-8.5:1 compression.
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
JesseE (11-24-2012)
Old 11-21-2012, 12:50 PM   #11
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Ah... I didn't actually know what was normal for STIs. Coming from the K series most of us were dropping from 11:1 or 11.5:1 to around 10:1.
Old 11-21-2012, 01:37 PM   #12
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
With FI I would go with around 10:1, more response and power. If it wasnt DI I could see why going down so low.
Tansey86 is offline   Reply With Quote
Old 11-21-2012, 03:50 PM   #13
benster
Drives: none yet
the reason I said it was very low is for DI. will it still be enough for it to work properly or it doesn't matter as it isn't compression ignited like diesels, since you can actually have gas auto ignite(hence detonation)?
Old 11-21-2012, 04:58 PM   #14
Calum
That Guy
DI doesn't mean compression ignition. It's still a gas engine with spark plugs. It'll certainly still work. :happy0180:
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 03:55 PM
Stop Motion Engine Build Mishimoto Other Vehicles & General Automotive Discussions 0 08-06-2012 04:25 PM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Engine build Maxim Engine, Exhaust, Transmission 41 10-03-2011 09:22 PM
