Old 12-03-2013, 07:23 PM   #15
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
OP could stagger the tires. Put 235s up front and 245s in the rear.
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline   Reply With Quote
Old 12-03-2013, 07:25 PM   #16
MrMarinakos
Drives: Asphalt Monogram Fr-s
Originally Posted by mav1178 View Post
Nah, I have 18x9/9.5 F/R on my car, mostly for looks.
The issue isn't that there are "no issues". The issue is that OP can't even run a stretched tire, and running a "normal sized" tire on this wheel setup will just look.... odd.
I know, I had this for a few days then got embarrassed enough to throw on the coilovers.
-alex
its not that i care if it looks odd i just heard that jts a problem for fitment, so does it fit or does it not?
MrMarinakos is offline   Reply With Quote
Old 12-03-2013, 07:33 PM   #17
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
Listen to your mom. Stretched tires are retarded, and the car basically came rolled from the factory. Why don't you just spend $200-$300 on lowering springs..
bkblitzed is offline   Reply With Quote
Old 12-03-2013, 07:35 PM   #18
Originally Posted by headlikeahole View Post
Bingo.
furthermore 9.5s on this car is outrageous, unless youre building a car strictly for show/appearances. There is no reasonable advantage for having wheels that wide on a 200hp lightweight.
We will be running 9.5" wheels with unmodified fenders on our second BRZ for track duty...
Old 12-03-2013, 07:42 PM   #19
husker741
I'm not as young as you are, but I still consider myself younger in comparison to a lot of owners of this car. You need to do a lot of research to figure out what will work with what, and know if you have the money to spend. If you aren't going to do it right, I wouldn't do it at all. You can stretch the tires, but I just wouldn't do that myself. You could get springs. I have RCE yellows that I love and drop it just enough. When I was young, I did a lot of impulse buys. I still do on this car, but I make sure I do enough research before I purchase.
Learn what is good/bad for you and your car, then purchase accordingly. I'm not telling you anything you are doing is wrong, but your mom shouldn't know more about YOUR car than you.
husker741 is offline   Reply With Quote
Old 12-03-2013, 07:42 PM   #20
MrMarinakos
Do 18x9.5 +34 square fit? -someone just answer this, cause i'm getting all yes and no's. I might as well just take the wheels to a shop and see what can happen
Old 12-03-2013, 07:44 PM   #21
MrMarinakos
She doesnt, she just thinks stretched tires are a horrible idea (kinda agree by this point) but other then that she doesnt know a single thing about my car... Then again she was in the car business for around 10 years
Old 12-03-2013, 07:56 PM   #22
xia
Drives: 1995 Supra TT & 2013 FRS
Rear should be fine as it will poke a bit. I have 17x9.75 +25 rear and it pokes a little. You will have problems in the front. That shit will poke out like there's no tomorrow. I have 17x8.25 +25 front and they poke out. I can't imagine 9.5 wide lol!
With your set, you will have MANY shops turning you away because they do not want to be liable for any problems you may have in the future. New tires will run you $700-1000 for all four. I used stock tires for the fronts and had to buy two new tires to run wider wheels. Cost? $550 for two GL!
xia is offline   Reply With Quote
Old 12-03-2013, 07:57 PM   #23
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
18x9.5" square setup here also.. these wheels/tires combo is lighter than the stockers, and the added grip is great.
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
Old 12-03-2013, 08:02 PM   #24
Mmmm Te37SL...
Old 12-03-2013, 08:04 PM   #25
MrMarinakos
Already found tire shop willing to sell me falken all season tires for 800
Old 12-03-2013, 08:10 PM   #26
xia
Sexy luss! Offset?
Old 12-03-2013, 08:11 PM   #27
xia
Well, try it and if they work
Old 12-03-2013, 08:11 PM   #28
brianlo622
brianlo622's Avatar
That price includes TPMS swap and mount/balance I hope
悪魔のハチロク
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 09:26 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
