| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2013 BRZ limited SWP
OP could stagger the tires. Put 235s up front and 245s in the rear.
Sent from my DROID RAZR using Tapatalk 2 |
#16 | |
Drives: Asphalt Monogram Fr-s
#17 |
is better than you
Drives: 2013 raven FRS
Listen to your mom. Stretched tires are retarded, and the car basically came rolled from the factory. Why don't you just spend $200-$300 on lowering springs..
#18 |
We will be running 9.5" wheels with unmodified fenders on our second BRZ for track duty...
#19 |
Drives: 2013 Whiteout Scion FR-S 6MT
I'm not as young as you are, but I still consider myself younger in comparison to a lot of owners of this car. You need to do a lot of research to figure out what will work with what, and know if you have the money to spend. If you aren't going to do it right, I wouldn't do it at all. You can stretch the tires, but I just wouldn't do that myself. You could get springs. I have RCE yellows that I love and drop it just enough. When I was young, I did a lot of impulse buys. I still do on this car, but I make sure I do enough research before I purchase.
Learn what is good/bad for you and your car, then purchase accordingly. I'm not telling you anything you are doing is wrong, but your mom shouldn't know more about YOUR car than you. |
#20 |
Do 18x9.5 +34 square fit? -someone just answer this, cause i'm getting all yes and no's. I might as well just take the wheels to a shop and see what can happen
#21 | |
#22 | |
Drives: 1995 Supra TT & 2013 FRS
With your set, you will have MANY shops turning you away because they do not want to be liable for any problems you may have in the future. New tires will run you $700-1000 for all four. I used stock tires for the fronts and had to buy two new tires to run wider wheels. Cost? $550 for two GL!
#23 | |
Drives: 2013 FR-S, raven
悪魔のハチロク
2013 Scion FR-S, Raven Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite |
#24 |
Mmmm Te37SL...
| The Following User Says Thank You to CSG Mike For This Useful Post: | brianlo622 (12-03-2013) |
#25 | |
![]() Quote:
#26 |
| The Following User Says Thank You to xia For This Useful Post: | brianlo622 (12-03-2013) |
#27 |
#28 |
That price includes TPMS swap and mount/balance I hope
悪魔のハチロク
| FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) | kanundrum | Wheels and Tires | 19 | 10-11-2013 09:26 AM |
| Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! | stratodyne | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 07-17-2013 02:21 PM |
| 17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? | SteveH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-14-2013 10:26 PM |
| Wheels, Wheels, Wheels | Island Import Performance | IslandImportPerformance | Wheels and Tires | 4 | 07-31-2012 10:08 PM |
