Old 12-10-2013, 11:57 PM   #15
RRBS
Drives: 2013 Raven FR-S
Sitting still, probably normal. While driving...i'd say not, and it's time to pay the dealer a little visit.
RRBS is offline   Reply With Quote
Old 12-11-2013, 01:02 AM   #16
humfrz
Originally Posted by BaeK View Post
update for those who are interested...
my clutch still clicks even after they replaced the clutch, pressure plate, and the flywheel.
I went under the dash to further observe where the sound came from and concluded the following: the click comes from the welded joint where the clutch pedal shaft meets the triangular metal piece. (for those who did the clutch adjustment, the triangular metal piece is connected to the U-shaped bracket right above the accelerator pedal)
I guess I have to live with the clicking noise. :S
Thanks for the update.
But that sucks that you still have the clicking noise. Can you bend/pry those two parts apart .. ??
humfrz
Old 12-11-2013, 10:23 AM   #17
SteveGrillo
Drives: Brz
I think I have exactly the same click (more like a "tick"). And I can make it go away or get louder by pushing the pedal with a bit of left pressure or right pressure while pushing down and releasing.
Sounds like a spring clicking partway down. And it sounds like it's coming from the pedal assy somewhere.
Thoughts?
Steve
SteveGrillo is offline   Reply With Quote
Old 12-11-2013, 12:28 PM   #18
humfrz
Thoughts?
Steve
Maybe a shot of silicone .....
humfrz
Old 12-11-2013, 03:44 PM   #19
BaeK
BaeK's Avatar
Drives: 2013 Whiteout FRS
It clicks whether the car is stationary or moving. Even without the car running, it’ll make that sound.
humfrz
I doubt I can bend the welded joint. I tried to see if the metal cap is loose (the cap that is connected to the triangular piece and the clutch shaft), but it’s pretty firm. If you have a manual frs, go under your dash where the clutch rod/U-shaped bracket is connected to the triangular piece. You should be able to see what I’m talking about. I’ll try to post a pic later tonight!
Thoughts?
Steve
I agree with you. It does sound like it’s coming from somewhere in the pedal assembly; but figuring out where is the frustrating part lol. I’ve tried spraying a #$%$ load of WD-40 at the welded joint described above, but the clicking sound still exists.
BaeK is offline   Reply With Quote
Old 05-08-2014, 05:23 AM   #20
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Any update on what came of this @BaeK
I have the same problem, i'll be bringing it up with toyota early next week.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 05-08-2014, 06:27 AM   #21
kALMIGHTY
Drives: TRD Ultramarine '13
I'm not sure if this is just as simple as this, but I have the clicking noise as well, but I know exactly what it's coming from.
To describe my situation: When I press in the clutch, I hear a "click" sort of like the click when you push the button on a pen, only a little louder, and hear the same click when I let go of the clutch.
That noise is coming from a little switch. For those of you who have the gear indicator turned on, that "click" is the switch being turned on to show you what gear you're in. When you push in the clutch, the button "pops" out with a click, and the gear indication disappears. Once you let go of the clutch, the clutch return pushes the button back in, and you hear the click again, and the gear indication comes back on the screen.
I could be wrong about this, but I'm 90% sure that's how that mechanism works and that's what the noise you're hearing is.
EDIT: Just read the first post again for a second time. This isn't the noise you're hearing. Never mind. Hope you find out what's wrong.
Old 05-12-2014, 08:41 PM   #22
BaeK
BaeK's Avatar
@Khorne
Hey Khorne, sorry for the late response. I've been in Japan and Korea for the past 3 weeks and haven't had a chance to get on this forum.
Anyways, my solution can be found here (make sure to read through all pages first): http://www.ft86club.com/forums/showthread.php?t=57383
I placed a rubber washer between the rubbing plates (where the bolt is torqued to) and haven't had a clicking noise since.
Hope this helps.
retrofit
The Following 4 Users Say Thank You to BaeK For This Useful Post:
FT86Z (04-30-2018), Khorne (05-13-2014), Porcupint (06-09-2015), PulpBrah (07-06-2017)
Old 01-20-2020, 01:55 PM   #23
MJones_RB
MJones_RB's Avatar
Just checking to see if this issue was ever resolved.
I just started to hear this click noise when first depressing the clutch pedal. It doesn't happen every time the clutch is pressed, but enough to notice.
My theory is that it's the switch on the clutch that detects that it's being pushed in. Maybe the switch is failing, or needs adjusting.
Anybody else have this?
Thanks
MJones_RB is offline   Reply With Quote
Old 01-20-2020, 10:23 PM   #24
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Dollars to donuts its the "assist" spring on the clutch pedal. Mine started making that noise shortly after I bought it. I took the spring out and it stopped. Put a lower strength MTEC spring in later and it came back. I suspect I could lube wherever the problem is and shut it up, but I'm too lazy and wedging my 6'6" 240 pound self under that dash again is the stuff of nightmares.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
MJones_RB (01-21-2020)
Old 01-21-2020, 01:43 PM   #25
MJones_RB
MJones_RB's Avatar
Good point. I have the MTEC spring as well. I'll have to wedge my ample frame down there and lube up that area as well.
Old 01-21-2020, 01:52 PM   #26
Opie
Opie's Avatar
Drives: 2000 Subaru Legacy B4 RSK (JDM)
Subaru has a TSB for an updated pedal assembly for this noise, surprised Toyota does not.
Subaru's updated part # is 36004CA010 for the pedal assembly and requires 2 clevis pins part # 905200018
Repair is covered only under the 3-year/36,000 mile basic warranty.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 01-21-2020, 05:20 PM   #27
hpanju
hpanju's Avatar
Drives: 2016 Subaru BRZ
When I'm in neutral and depress the clutch, when it engages I hear and feel a click. Is this normal?
hpanju is offline   Reply With Quote
Old 01-21-2020, 06:54 PM   #28
xZAMx
Drives: '13 FR-S - Hot Lava
I'd like to chime in and say this is happening to me as well. I hear the *click* coming from the rear though. I've heard that tightening your axle nut may help this?
Can anyone confirm?
xZAMx is offline   Reply With Quote
clutch click, clutch clicking, take it to the dealer, use your warranty
Vibration/Noise when clutch is depressed Ravenlokk Issues | Warranty | Recalls / TSB 17 12-02-2013 11:15 AM
Clicking noise in engine bay teddydoggy Issues | Warranty | Recalls / TSB 4 08-12-2013 05:15 AM
Ticking/Clicking Noise front - passenger side PoRco Scion FR-S / Toyota 86 GT86 General Forum 9 05-06-2013 06:55 PM
Check on Strange Clicking Noise and Alternating Part Enigma789 Engine, Exhaust, Transmission 4 04-14-2013 07:32 PM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 07:39 PM
