CANADA Canada
View Poll Results: Please check all that apply:
I rust-proofed by ft86 30 37.50%
I did NOT rust proof my ft86 (please indicate reasoning in post below) 36 45.00%
If applied: I used Krown 14 17.50%
If applied: I used Rust Check 3 3.75%
If applied: I used other (please indicate below in post) 17 21.25%
If applied: I had holes drilled in my frame 10 12.50%
If applied: I did not have holes drilled in my frame 10 12.50%
If applied: I plan on an annual application 12 15.00%
Multiple Choice Poll. Voters: 80. You may not vote on this poll
Old 11-19-2013, 08:08 PM   #15
roddy
roddy's Avatar
Drives: '13 Ultramarine
I used Rust Check, and had holes drilled, but not in the frame, so I didn't select "holes drilled in my frame".
Old 11-19-2013, 10:59 PM   #16
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Bought one of the rust inhibitor modules. Time will tell if it really works. Certainly no help for the exhaust (probably due to the rubber isolators).
Demandred7 is offline   Reply With Quote
Old 12-01-2013, 10:14 PM   #17
Kevstra
Kevstra's Avatar
Drives: 2013 Subaru BRZ Sport-tech 6MT
I didn't get it because:
A) I don't drive my BRZ in the winter. That's what beater cars are for.
B) My father's 1972 Datsun 240z is rust free after being a summer car all it's life and they didn't give a rats ass about corrosion in those days, and after over 40 years it's in perfect shape. I feel like the BRZ will only be better.
Veronica, the 2013 WRB Subaru BRZ Limited
Kevstra is offline   Reply With Quote
Old 12-02-2013, 10:19 AM   #18
Canadian Greg
Drives: Black 2013 fr-s
I use electronic rust control module. Dealer installed and guaranteed against corrosion for 10 years.
Canadian Greg is offline   Reply With Quote
Old 12-02-2013, 01:43 PM   #19
Burrcold
Drives: Subaru BRZ Limited
Aww you fell for that snake oil?
The Following User Says Thank You to Burrcold For This Useful Post:
djdnz (12-02-2013)
Old 12-02-2013, 03:40 PM   #20
Canadian Greg
A lot of doubters out there I know...
The science is sound, and oil doesn't really work.
NASA has been using this technology for 40 years.
Old 12-02-2013, 03:51 PM   #21
davidp
Drives: BRZ Limited
they put those electronic things on snow plows for decades now and it seems to work
davidp is offline   Reply With Quote
Old 12-02-2013, 04:16 PM   #22
Burrcold
There is an absolute difference in the type of module a dealer puts on your car, and the ones used by NASA and Aeromarine applications. Do a little research and you'll see exactly what I'm talking about.
Old 12-02-2013, 05:04 PM   #23
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I can tell you it clearly didn't work on my friend's mazda 3.
I rust proof my cars myself when I switch the tires to summer, I just use cans of rust check and apply it to all the fasteners and suspension parts under the car, it's mostly to save trouble from future repair/upgrades. New cars are very rust resistant, they take from 5-7 years to start rusting from what I can tell, unless you have a mazda 3 lol.
Rayme is offline   Reply With Quote
Old 12-02-2013, 07:52 PM   #24
tinma
Drives: '13 BRZ
got mine rustproofed from the dealership....i made a thread about it and how shitty of a job they did lol....basically made my engine bay look terrible
Here is the link to the thread
http://www.ft86club.com/forums/showt...=rust+proofing
tinma is offline   Reply With Quote
Old 12-03-2013, 03:41 PM   #25
Canadian Greg
True. But the technology is still the same.
Why folks resist these advancements I will never know.
Oiling is cerainly NOT the way to go. Messy, unreliable and no warranties.
Old 12-03-2013, 04:47 PM   #26
Burrcold
Because these "advancements" are unfounded and unproven (for automotive use). Sorry, but SNAKE OIL!
http://www.theglobeandmail.com/globe...article535224/
http://www.wheels.ca/feature/no-evid...ctually-works/
Old 12-03-2013, 05:46 PM   #27
PMPB
Drives: BRZ Sport-tech
For those electronic "anti-corrosion" modules to work, they would need to be wired to each portion of the car, especially the metal that is far away from the engine bay.
As you know, electricity will take the shortest circuit it can. If the module is wired from your battery to your frame, and because the frame is grounded to the battery, it will take a very short circuit from the location it's bolted to the frame, back into the battery. There may be a very small portion of the engine bay that is protected against corrosion.
On a boat in the ocean... every part of the hull is connected to the anode ( a huge chunk of sacrificial zinc) by the salt water. Big ships will have these zinc anodes at regular intervals along the hull to ensure coverage.
The premise of the module is not to be sacrificial, but to use a small amount of current to reverse the flow of electrons that naturally try to leave the iron (oxidation) and bond with water.
To do the same in a car, we could either submerse the car in salt water, ensuring that all portions of the car form a circuit with the module, or fusion weld many small insulated wires every couple inches to every body panel or chassis component, and run them all back to the 'module'. This isn't practical of course, and if we tried to increase the current, we'd just short out the electronics, and possible cause over-protection, and just cause oxidation of the lead at the other battery terminal (+ve IIRC).
Salt/water/steel will always form a local circuit, which is why galvanizing steel is the only way to protect it, in an air environment. Galvanizing is a sacrificial zing layer, than can help protect steel for many years, even if the galvanizing layer is cracked.
PMPB is offline   Reply With Quote
The Following 3 Users Say Thank You to PMPB For This Useful Post:
Burrcold (12-03-2013), Captain Stall (12-10-2013), Wattage (12-20-2013)
Old 12-03-2013, 07:26 PM   #28
LDN2012
Drives: '13 SWP Subaru BRZ Sport-Tech
Didn't rust proof as I'm leasing and I'll get the car washed once every two weeks during the winter to get the salt off (underbody as well).
LDN2012 is offline   Reply With Quote
Rust proofing? rip curl CANADA 17 06-20-2014 01:40 AM
Rust-Proofing Gunk Taro CANADA 4 10-10-2013 07:57 PM
Subaru dealership rust proofing tinma Issues | Warranty | Recalls / TSB 49 09-20-2013 02:26 AM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 04:15 PM
