Old 11-19-2013, 01:37 AM   #15
humfrz
Originally Posted by Kelbyat07 View Post
Since we are talking about car issues.
Can anyone tell me what might be the problem with my car? Every time I hit a decent size bump I would hear a noise like a plastic sound coming from the speaker or the little air vents next to it. The noise really sound like someone is tapping on a paper that is in the air. I even turned of my radio and can still hear it, the thing is that I don't even blast my speakers at all so I don't really know where it is coming from or what it is at all.
Any advice or comment would be appreciated.
You might check to see if the right side A piller cover is snapped on proper. I suggest you press in, on the top near the windshield then put pressure on the outside nearest the side window.
humfrz
Kelbyat07 (11-19-2013)
Old 11-19-2013, 01:38 AM   #16
Trmx2
Trmx2's Avatar
Drives: 2014 Raven FR-S 6spd
Originally Posted by benlaz88 View Post
I have the same issues that you mention on my 2013.....
Yeah, it's kind of aggravating. Does replacing the tail lights fix the condensation? I hope so...
as for the Fuel-pump chirp, this is the first time it has happened and it's been kind of intermittent.
The idle dip has been really intermittent too....not sure what causes it or how to recreate it.
I'm going to go to Toyota with a list of these things and demand they get fixed.
Trmx2 is offline   Reply With Quote
Old 11-19-2013, 01:43 AM   #17
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Originally Posted by AznKirby View Post
Are you lowered? Maybe you're scraping on the pavement.
No sir, no mods.
Kelbyat07 is offline   Reply With Quote
Old 11-19-2013, 01:44 AM   #18
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
humfrz
Yeah I was thinking of the same thing. I will do this first thing tomorrow.
Old 11-19-2013, 01:56 AM   #19
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by Trmx2 View Post
I've actually been getting 28.9 avg currently. My "granddad" driving is really paying off.
I filled up and set the average L/100km trip to get a 5.8L/100km reading back in my garage after 100km. I was careful but overtook a couple of cars and cruised at 117kph for half the trip home. That's 40.5mpgUS and about 39mpg actual consumption.
I think that's impressive.
My GTS is Nov 2013 build and I haven't had any of those issues, although there is a similar noise LHR but only as the car articulates over a drive entrance at an angle.
sierra is offline   Reply With Quote
Old 11-19-2013, 02:17 AM   #20
Kazuya
Kazuya's Avatar
Drives: Takumi
I have most of the issues, i learned to accept them as it is and that it really doesnt affect performance. My car built date was July 7th, 2013, i have light condensation and it disappear overtime.
I think most of those problems slowly disappear overtime, drive it and turn up your audio, 95% of the shit you hear in the car no longer relevant.
Kazuya is offline   Reply With Quote
The Following User Says Thank You to Kazuya For This Useful Post:
Trmx2 (11-21-2013)
Old 11-19-2013, 03:02 AM   #21
arashishozen
Guest
Posts: n/a
I have the same issues that you mention on my 2013 except the Rear driver side "clack" "harsh click" noise. I'm sure the TSB should be the same as 2013.
The chrip noise still cannot be fix, i bring my car in today and the service guy told me that there is no fix however, he said its has better insulation. They have TSB for this.
For the tail-light condensation, the dealership will fix it for you and yes they have a TSB on that too.
For the RPM dip, its seem like its hard for them to see what happen because it does not happen all the time. They did see the RPM dip and was told it was normal but they did not feel any shaking/stalling while the RPM dip, so they cannot do anything about it. (Possibly the HPFP cause it.... idk?)
Hope this help. I Will get my car back tomorrow and see "If" everything got fixed.
to fix the chirp run non ethanol gas. ive had the chirp ran non ethanol gas and it went away. the chirp will only go away once its completely out of ethanol gas. once it runs off pure gas the chirp poofs.
tried it several times with changing back and forth. hasn't failed me yet
ive had the tsb.done to mine and it didn't fix the problem.
The Following User Says Thank You to For This Useful Post:
Trmx2 (11-21-2013)
Old 11-19-2013, 03:21 AM   #22
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
I got a taillight replaced and it hasn't got any condensation in it yet.
As for everything else, I tend drown it out with non-economical driving.
- The Ancient BRZ Sacrament
by Zaku
Old 11-19-2013, 03:32 AM   #23
86viper
Drives: 2013 Toyota 86 GTS
So far no other issues, I drive my car like a grandma would 95% of the time and have only laid down on it a handful of times.
There is your problem right there. With 1000miles on the clock it should be seeing redline often. Thats the whole point.
The only issue of yours that i have had is the rev drop. Its a pretty common known issue but in the grand scheme of things isn't too annoying.
86viper is offline   Reply With Quote
Old 11-19-2013, 03:54 AM   #24
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
I have all of the named issues except the tailight condensation and my car was made mid- late 2013
Maverick22 is offline   Reply With Quote
Old 11-19-2013, 07:58 AM   #25
kevman_101
Drives: 2013 Scion FRS
So everyone has talked about these and many of them are known, but I wanted to make people aware that even the 2014's are doing this too, so Toyota/Subaru hasn't fixed the issue from the factory.
1. Fuel-pump Chirping mine is intermittent but it started up last night, I have about 1096 miles on it. I ONLY use 93 octane and have only used Shell/Chevron. Is it worth getting this fixed since it doesn't seem to be going away even for those with numerous fuel pump changes?
2. Rear driver side "clack" "harsh click" noise when driving hard, turning hard Only noticed this once or twice, haven't been able to recreate it. I notice a clack/click sound almost as if a penny is falling onto metal in the rear side of my car. I think it's the rear decklid thing. Heard this can be fixed but also inevitably returns. Worth the fix?
3. Idle dip/engine shudder, intermittent about a handful of times I've gotten a strange idle dip/engine shudder either when coming to a stop and it happens around 25mph (whilst coming to a stop) or when completely idle at stop. Idle will dip below 800rpm then back up to about 1100 rpm then to normal idle. The other issue seems to be as stated during stopping, engine will make a strange shudder-noise like if it's stalling? Not sure...doesn't seem to really affect anything.
4. Beginning condensation in tail-lights most noticeable after washing my car, I get MINIMAL condensation right around the top edge of the tail lights going around the rim. Has anyone gotten this successfully fixed?
No mods currently stock.
Any known fixes or TSB's that they will fix and honor without complaint?
#1 - No fixes. There is a TSB to change the high pressure fuel pump for the DI system, but it comes back after it breaks in. It's only a chirping noise and it's normal. Your going to have to learn to deal with it unless they find a permanent fix for it.
#2- Sorry, mine doesn't do it, or I just don't hear it.
#3- I see you are living in Florida, so I would imagine you run with the AC on. Living in Canada, I run with the heather on . I went a few years back to see the Nascar race in Miami in November. Mostly everyone had sweat shirts and coats on and we were in t-shirts and shorts and dying of heat LOL. Anyways, to get back on point, when you have the AC or the heater set to either windshield positions, it will click on and off the AC pump, and that click is what drops the RPM so low. It never does it when the fan is either off, or if its just simply blowing regular air with no AC or defrost.
#4- Mine also has condensation and there is a recall, so just bring it to the closest dealer and they should fix it right up.
kevman_101 is offline   Reply With Quote
Old 11-19-2013, 08:15 AM   #26
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
Originally Posted by kevman_101 View Post
#3- Anyways, to get back on point, when you have the AC or the heater set to either windshield positions, it will click on and off the AC pump, and that click is what drops the RPM so low. It never does it when the fan is either off, or if its just simply blowing regular air with no AC or defrost.
Untrue.
Mine dips to ~600RPMs all the time with absolutely no fan/AC/heat on whatsoever
I have recorded it in every possible setting and it has no affect. If you read up on the forums a lot of people have the issue regardless of AC setting
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 11-19-2013, 08:42 AM   #27
Mikem53
Drives: FR-S 6MT
You need some more miles on your car.. Things do smooth out some over time. I get the idle dip under certain conditions, but it's normal. You are overly aware of these issues being a new car and all.
Everything you mentioned seems to be on par with what others experience.
Taking a list to Toyota and demanding they fix everything may not be the best plan. I would give the car and yourself some time to break in before you go getting yourself all aggravated by visiting the dealer..
Its human nature to focus on everything that seems wrong.. But the more time spent driving it and enjoying all that is good... Will let the other issues either work themselves out or give you time to realize what is normal for this car..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
humfrz (11-19-2013)
Old 11-19-2013, 08:49 AM   #28
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
Thought they were all being affected by this, so I've heard....
It is a shame, brand new car with such annoyances. I've been driving like a grandpa too....so it shouldn't be having any of these issues.
You said in the first post you hear a sound when driving hard and turning hard. Grandpa driving?
SoCal909 is offline   Reply With Quote
2 weeks from getting a brz tr1x5tuh Southern California 16 10-31-2013 09:27 PM
Not even three weeks gr8scott Scion FR-S / Toyota 86 GT86 General Forum 19 05-21-2013 10:01 AM
Another 8 weeks!! Wesley Scion FR-S / Toyota 86 GT86 General Forum 28 09-21-2012 06:25 PM
had my frs for two weeks..this is what happens bcmakesiteasy Scion FR-S / Toyota 86 GT86 General Forum 98 08-07-2012 10:20 AM
