#16 |
Drives: WRB BRZ
You had me at "Formula 1", but you lost me at "more expensive".
#17 |
Drives: 2013 FR-S Ultramarine
#18 |
What part of these brakes were used in NASCAR and F1? I'm assuming you meant the brand and some of the tech?
#19 |
Mark @ STILLEN
Drives: 2015 Subaru BRZ
The asymmetrical design and forged construction was originally used in Formula 3. After its huge success there it was then used in both Formula 1 and Nascar. The design and functionality is the same. However (as a lot of you I'm sure know), Nascar and Formula 1 use a smaller diameter brake rotor that is much thicker. The Formula 1 and Nascar kits don't work on most (if not all) production cars. So we worked with AP to develop kits for production vehicles.
#20 | |
That Guy
Drives: 2013 asphalt FRS MT
#21 |
Mark @ STILLEN
Smalled diameter does lower the moment of inertia and the thicker rotor provides larger mass for heat sink and dissipation. Nascar has regulations on wheel size and F1 has their own set of rules as well as their own physics calculations that make the torque on the rotor less important. Also the cars are so light it is a different ballgame. The thickness of the rotors used in Nascar and F1 are way too wide for production cars so a AP Radical System from one of these cars would never work.
There are a lot of factors when figuring picking out and building a BBK to consider that go beyond my scope of expertise. I know we are looking into making kits that fit smaller wheels but nothing is official or final yet.
#22 | |
Site Moderator
Drives: Stuff
You really want the rotor to be as small as possible while having the capacity to absorb and eventually remove heat from the system. There's a limit on how small both based on thermal mass and brake torque of course. The pros use a LOT of cooling that isn't practical on production based cars also. This is why I'm not a fan of most big brake kits. They are needlessly big. Why increase the thermal mass to a point where you can NEVER actually get close to it's capacity? You just slow the car down in every way without any actual benefit under braking. Sure, you get more torque, which can be good and bad depending on your goals and what you are trying to fix.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#23 | |
Mark @ STILLEN
#24 | |
Site Moderator
Drives: Stuff
I'm assuming that these are CP8520/21 or 22 calipers. They use the CP7555D74 pad shape. They are aluminum piston calipers with dust seals. They are forged, but two piece (I'm not against two piece calipers, just saying). Anti rattle springs for the pads, etc. They are a street caliper but should hold up fine for the track. Looks like a new shape, for AP at least. Info here: http://www.apracing.com/product_deta...cp7555d74.aspx If I was really bored I'd hunt through pad catalogues to fine a more standardized pad shape to search for.. but..
-Dave
#25 | |
Site Moderator
Drives: Stuff
What were we talking about again?
-Dave
#26 | |
Mark @ STILLEN
LOL, my brother has one with a 3rd gen. Still love them and miss mine sometimes
#27 |
Because compromise ®
Drives: Red Herring
*dons skeptic hat*
@Team STILLEN I have read that the Essex Sprint Kit has been tested (read abused) by Dave-ROR and CSGMike and both have found that the kit is up to the task of handling their punishment. I have also read that 6 piston calipers are over kill for this car. What performane gains are there to be had with these new Radi-CAL Brakes over the Sprint kit? *Removes hat*
#28 | |
Drives: '13 Argento 6MT FR-S
+5 to all braking
+10 agility +11-15% movement speed +1 random magic properties Item Level: 60 Quote:
| Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 05:53 PM |
| BMW Officially Unveils the i3 | DIM | Other Vehicles & General Automotive Discussions | 3 | 07-29-2013 06:29 PM |
| Stillen Brakes | jdzumwalt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-15-2013 11:57 PM |
| The STILLEN BBK Thread (AP RACING COMPONENTS) - JUST RELEASED! | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 12-21-2012 04:00 PM |
| KW Coilovers, Brembo Brakes, Cusco and more! at Vivid Racing | vividracing | Brakes, Suspension, Chassis | 5 | 10-15-2012 06:23 PM |
