Old 10-30-2013, 03:38 PM   #15
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Originally Posted by phanguy View Post
you're an inspiration man. i did this too(because of you!), but my 90mm halos appear dimmer than the 60mm that i have. i wired up with the provided voltage regulators, have it running to a relay, and powered from the 12v at the arm rest. where are you powering yours from?
I run the halos off the fuse box inside the engine bay, they work as DRLs, the top left most 15amp fuse is where I use a Add a fuse
Originally Posted by Evil Jesus View Post
Wow, very cool looking. I like the halos on all 4 but I think I might like the demon eyes on just the outer lights. Can you have it so it's just the demon eyes on without the halos?
Yes the demon eyes are wired to a switch, they are independent to the halos.
Originally Posted by koteman View Post
What did u use for demon eyes I have 3 watt rgb less in each one on mine and the halos completely wash the color out and u can't even see it but the color projects on the ground about 4 feet in front of my car
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I use alpina led strips.. They can be sourced at many locations, but I think autozone is the most common.. I'm in the process of ordering 5 meter strips direct from them
Originally Posted by muffinz View Post
Very nice craftsmanship
are the outer halo's parallel with the inner halos? It looks like they may point outwards a bit...kinda like biggie smalls' eyes did.
You cant really tell from the front but I wonder if it looks a bit strange from an angle.
I will draw a terrible diagram to visualize my question. Front of the car is >
are they like:
\ <<<<<< beams of light
or are they like:
Well kinda.. The shrouds don't move, the projectors actually move up and down and side to side to aim them.. So looking on the top the are like the bottom picture.. Looking from the side they are not perfect as the lights are aimed and sit different from the shroud.. Not by much.. It does look really off looking at them..me very one I've done does, but aimed up on a wall they are perfect
Originally Posted by Ammonia View Post
Lol, illuminatinglightworx on FB or IG is my contact besides here
Originally Posted by vividracing View Post
I bow down to your godly skills O|¯|_
Thank you and everyone else for the support
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
Ammonia (10-30-2013)
Old 10-30-2013, 03:54 PM   #16
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Great Googly Moogly!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-30-2013, 03:57 PM   #17
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
How much would it be to do this? My headlights are already blacked out, so I could definitely use at least the inner set of projectors to boost my light output.
Would you mind PMing me a quote, with and without the demon eyes? I love the quad halos and the mini projectors.
Ammonia is offline   Reply With Quote
Old 10-30-2013, 04:49 PM   #18
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
We have a local guy in soflo with this and in a month hell b doin mine too. Minus the demon eyes tho (too much clash with ultramarine)
lbroskee is offline   Reply With Quote
Old 10-30-2013, 05:45 PM   #19
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Yes, how much does something like this cost?
ericmpena is offline   Reply With Quote
Old 10-30-2013, 05:48 PM   #20
Gixxersixxerman
A setup like this runs between 1100-1200$ more if you wanna run better bulbs or projectors
Old 10-30-2013, 06:06 PM   #21
soulstice
Drives: SWP BRZ LTD
awesome work. really sets the car off.
soulstice is offline   Reply With Quote
Old 10-30-2013, 09:09 PM   #22
ericmpena
ericmpena's Avatar
That's not bad! I'll just swap my BRZ headlights for FR-S headlights + $1000, then pay $200 out of pocket for this setup.
Old 10-30-2013, 09:37 PM   #23
Gixxersixxerman
I've been looking for BRZ lights.. I wanna do a swap lol.. I love the BRZ lights over the JDM GT86 lights..
Personally I don't think it's a bad deal.. But it's something the owner really really has to want.. But the light output on bright is insane..
I can't wait for my new setup.. It's going to be insane.. At least as far as light output from a single projector
Old 10-31-2013, 01:46 AM   #24
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sweet!
@Gixxersixxerman, how difficult was it to get the matchbox projectors and the low beam projectors to line up(if the lights are on/you're facing a wall?)
Or is there separate adjustments for low beam/highbeam locations?
Old 10-31-2013, 02:41 AM   #25
Gixxersixxerman
Originally Posted by Shutter View Post
sweet!
No freaking separate adjuster there should be make my job much easier.. There are a couple ways I've come to try, the easiest and not the best way, is to have them on and add spacers to the bottom of the main projector mount.. The problem with this is, the morimoto kit already "raises" the projector higher and then this makes it worse.. So when you adjusting the lights the main will make contact with the shroud, it'll start to move it up, but then your matchbox starts to tweak.. The proper way, is to keep adjusting the "cut" on the high beam reflector bulb mount until you get the angle you need when you tighten it down.. I'm sure spacers, shims or what not would work also.. But when I cut the piece I have it tilted slightly upwards for a easier time to aim the cut off properly.. Now if your going to use the matchbox as a high beam only, I take the flap out and just make sure it's aimed close with the hottest spot of the bulb.. In this case it took me about four hours to get the cut offs just perfect as he wanted all four on as low beams and the bixenon hooked up
Old 11-01-2013, 01:05 AM   #26
continuecrushing
Haha, great that's what I was afraid of. Oh well! Least I know what I'm up against!
Old 11-01-2013, 05:05 AM   #27
retrosmiths
Drives: Scion FR-S Whiteout
Done similar, but to my tC, and with the halos half-masked
http://retrosmiths.com/img/tc/demon_eyes/1.jpg
And just a single pair for my FRS
http://retrosmiths.com/img/frs/demon_eyes/1.jpg
I used SMD LEDs instead of shoving a strip in there, and bare CCFLs for thinner halo lines.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 11-01-2013, 08:36 AM   #28
charged86
charged86's Avatar
Outstanding job sir.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Quad projectors and Quad halos Gixxersixxerman Cosmetic Modification (Interior/Exterior/Lighting) 73 07-05-2014 12:19 AM
Demon Eyes retrosmiths DIY (Do-It-Yourself) Guides 19 09-04-2013 05:07 PM
$400 Headlights with on/off demon eyes mode (SoCal pickup) retrosmiths Exterior Parts (Aero, Lighting, Etc.) 30 08-03-2013 01:59 AM
Demon Eyes retrosmiths Cosmetic Modification (Interior/Exterior/Lighting) 16 05-20-2013 12:55 AM
Headlight lens question (demon eyes) WolfsFang Cosmetic Modification (Interior/Exterior/Lighting) 19 09-30-2012 02:58 PM
