#15 | ||||
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Lol, illuminatinglightworx on FB or IG is my contact besides here Thank you and everyone else for the support
| The Following User Says Thank You to Gixxersixxerman For This Useful Post: | Ammonia (10-30-2013) |
#16 |
Drives: 2013 Scion FR-S Raven
Great Googly Moogly!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#17 |
Drives: Whiteout FRS, Audi A4, 135i (sold)
How much would it be to do this? My headlights are already blacked out, so I could definitely use at least the inner set of projectors to boost my light output.
Would you mind PMing me a quote, with and without the demon eyes? I love the quad halos and the mini projectors. |
#18 |
Drives: 2023 WRB BRZ (MT)
We have a local guy in soflo with this and in a month hell b doin mine too. Minus the demon eyes tho (too much clash with ultramarine)
#20 |
A setup like this runs between 1100-1200$ more if you wanna run better bulbs or projectors
#21 |
Drives: SWP BRZ LTD
awesome work. really sets the car off.
#22 |
Drives: Subaru BRZ Limited
#23 | |
Personally I don't think it's a bad deal.. But it's something the owner really really has to want.. But the light output on bright is insane.. I can't wait for my new setup.. It's going to be insane.. At least as far as light output from a single projector |
#24 |
Drives: 2013 Firestorm FRS
sweet!
@Gixxersixxerman, how difficult was it to get the matchbox projectors and the low beam projectors to line up(if the lights are on/you're facing a wall?) Or is there separate adjustments for low beam/highbeam locations? |
#25 | |
there should be make my job much easier.. There are a couple ways I've come to try, the easiest and not the best way, is to have them on and add spacers to the bottom of the main projector mount.. The problem with this is, the morimoto kit already "raises" the projector higher and then this makes it worse.. So when you adjusting the lights the main will make contact with the shroud, it'll start to move it up, but then your matchbox starts to tweak.. The proper way, is to keep adjusting the "cut" on the high beam reflector bulb mount until you get the angle you need when you tighten it down.. I'm sure spacers, shims or what not would work also.. But when I cut the piece I have it tilted slightly upwards for a easier time to aim the cut off properly.. Now if your going to use the matchbox as a high beam only, I take the flap out and just make sure it's aimed close with the hottest spot of the bulb.. In this case it took me about four hours to get the cut offs just perfect as he wanted all four on as low beams and the bixenon hooked up
#26 |
Haha, great that's what I was afraid of. Oh well! Least I know what I'm up against!
#27 |
Drives: Scion FR-S Whiteout
Done similar, but to my tC, and with the halos half-masked
![]() http://retrosmiths.com/img/tc/demon_eyes/1.jpg And just a single pair for my FRS http://retrosmiths.com/img/frs/demon_eyes/1.jpg I used SMD LEDs instead of shoving a strip in there, and bare CCFLs for thinner halo lines.
2013 Scion FR-S
#28 |
Outstanding job sir.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
| Quad projectors and Quad halos | Gixxersixxerman | Cosmetic Modification (Interior/Exterior/Lighting) | 73 | 07-05-2014 12:19 AM |
| Demon Eyes | retrosmiths | DIY (Do-It-Yourself) Guides | 19 | 09-04-2013 05:07 PM |
| $400 Headlights with on/off demon eyes mode (SoCal pickup) | retrosmiths | Exterior Parts (Aero, Lighting, Etc.) | 30 | 08-03-2013 01:59 AM |
| Demon Eyes | retrosmiths | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 05-20-2013 12:55 AM |
| Headlight lens question (demon eyes) | WolfsFang | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 09-30-2012 02:58 PM |
