Old 05-20-2013, 12:54 AM   #1
retrosmiths
Drives: Scion FR-S Whiteout
Demon Eyes
In the pictures above, I have painted assemblies and demon eyes. Only the demon eyes are covered in this post. Also, this is also a very good time to replace the stock halogen projectors with HID ones, to achieve better light output than just replacing the bulbs with HID conversion kits. The Retrofit Source sells a kit at a good price. They also offer great warranty and exceptional customer service. Disclaimer: Not an affiliate, just a very satisfied customer.
LINK TO PICTURES THREAD
DIFFICULTY RATING: 7/10
WHAT YOU NEED
  • Oven
  • 1 rattle can flat white paint/primer (will only use about 1/4)
  • 1x pair SMD LEDs (Oznium or SuperBrightLeds)
  • 1x pair CCFL angel eyes (85-95mm) (Retro-Solutions)
  • Heat shrink wrap (get the variety pack from Amazon/Radioshack) OR vinyl wrap (the harder method)
  • Heatgun
  • Drill with the small bits OR butane torch and small nail to create the holes for the halo mount
  • Thin mounting wires or stripped twist ties (not zip ties)
NOTES
  • The most optimum way I've found on baking the headlights apart: 250F for 8 minutes.
  • Be very careful with the halos! The CCFL tubes are very fragile and may break with slight force.
  • If you plan on painting the assembly (like I did in the sample pics), do that after creating the mounting holes.
INSTRUCTIONS
1. There are already some DIYs here for removing the bumper, taking off the headlights and baking it open. Find and follow them.
2. Remove the projector from the headlight assembly and disassemble it. You'll need to paint the foreground limiter (the metal piece in between) white. Why white? Because it reflects all colors and will work the best if you want to use other LED colors. I used a flat white primer rattle can.
Projectors above are Morimoto Mini H1 from another project. Just demonstrating the effect of the white paint.
3. Mount the LED to the bottom of the lens holder. It's important to put it at the bottom with the light beam facing upwards, otherwise the red light will shine on the front bumper and the effect will not look as good. Reassemble the projector.
4. (Optional) Remove the bare CCFL tubes from the protective diffuser casing. If you opt to skip this step, the light emitted with the diffusers on will be softer. I prefer mine without. The following steps assume that you removed the diffusers.
Use your nail to pry the metal clips behind the diffusers (they're soft). Pry the metal backing off.
(Optional, but recommended) Do not remove the clear rubber rings around the halos. Those will be used so that the wire mounts will not show up in front of the halos when it's on.
5. Masking the halos. Cut the CCFL wires (near the clip), remove the clear plastic tube from one wire. Test fit the halos to see which part you want to mask. I mask about 1/3 of the ring, starting on one of the rubber ends.
Shrink wrap method - snake a shrink wrap to the halos, use a sharp cutter to remove excess and heat with the heat gun.
Vinyl wrap - cut out the shape of the mask, attach and use heat gun to wrap it around the ring and make sure there's no light bleed.
6. Using the drill or the butane torch + nail, create two holes on the circle emboss on the front of the headlight's chrome assembly for the CCFL wires to pass through. Do this first if you plan on painting the chrome!. Then create two more holes for the wire mount on the opposite side.
Note: The second pair of holes I created was designed for the thin wires to tie the halo directly, it's perpendicular to the line of the circle emboss, but I realized soon after that I can tie the rubber rings to the wires instead. You'll understand this more below.
7. Insert the cut halo wires on the top pair of holes. The way I did it, these wires will also serve as the top mount so that the halos will not fall off.
If you did not took off the rubber rings from the halos, insert a short piece of mounting wire through them and then tie the mounting wire through the second pair of holes. This way, the mounting wires won't block the halo light. The rubber rings will, but they are clear. Another advantage is that the rubber rings will flex and will not put too much pressure on the ring when being mounted.
If you took off the rubber rings, mount the halo with the thin wire directly. Be very careful with the tightness of the wires, the rings will break easily.
8. You're done, but make sure to test them first. Re-connect the CCFL wires to the clip end, then to the inverter. Test it and the LED with a 12v source (car battery).
9. Re-attach the different parts of the assembly together. Snake the wires to the back and use the stock rubber caps to hold them in place.
10. Bake the headlights for 5 min at 250F. Press on both halves really well, otherwise, you'll have condensation issues. I usually press on one side and attach the screws to keep it sealed tight. I also attach industrial clamps to the sides, but that's optional.
WIRING
For now, I have the demon eyes wired to the park lights (one click of the light knob thing in the steering wheel). With the low beams on, the red LED will not show up because the halogen bulbs are way brighter. To hook it up to the park lights, locate the wiring for the signal lights. There are three wires: black, red and green. You need to tap into the green positive to the red positives of the CCFL inverter and the LED. You can hook up their black negatives to any screws that attach to the chassis body.
Another way to do this is by installing a remote control switch. A 1-channel remote will be around $12 from Amazon, while a 4-channel will run you around $30-40. Make sure to get the 12v. This way, you can turn it on/off at will, remotely. Great for car shows and for extending the life of your CCFL halos and LEDs.
FAQs
Is this legal in my state?
Most certainly not, in CA anyway. The way I wired it up is only temporary and I am planning to install a remote switch to it in the near future.
Will the LEDs burn out due to the heat of the halogen/HID bulbs?
I have been running this same setup on my tC for 4 months and haven't encountered any burnt out bulbs.
How did you do that paint technique?
Masking tape, patience and steady hands.
Will my headlights fog up or have condensation inside?
Only if you didn't push the halves together well. Also, if you've baked it open three or more times, it'll be safer to apply more butyl sealant. You can buy them for $15 from TRS. You only need a thin rope on the sides, that roll will last you around 10 full headlight sealing.
Picture above shot on a fairly bright day. The red LEDs really shine up well during dim days.
retrosmiths is offline   Reply With Quote
Old 05-20-2013, 01:11 AM   #2
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
This is awesome.
Blue LIGHTS are illegal on anything but cop cars (in WA at least), anyone know if I'd get jammed up for doing the ring blue though?
I think the effect would be awesome inside the strip on a BRZ
BlueSTaR is offline   Reply With Quote
Old 05-20-2013, 01:15 AM   #3
retrosmiths
Originally Posted by BlueSTaR View Post
This is awesome.
In CA, the only legal colors coming from the front of the car are white and yellow/amber. I know for sure that any blue/red lights (halos or LEDs) will get you pulled over almost immediately. Some with 8000K HID bulbs can get away with the bluish part.
So, yes, I think blue strips on the BRZ will definitely get you in trouble, even if it's just "accent" lighting.
Old 05-20-2013, 01:16 AM   #4
BlueSTaR
BlueSTaR's Avatar
Originally Posted by retrosmiths View Post
In CA, only legal colors on the front of the car are white and yellow/amber. Some with 8000K HID bulbs can get away with the bluish part, but I certainly know for sure that actual blue lights (halos or LEDs) will get you pulled over.
Damn, well I'll just enjoy my WRB paint then
Old 05-20-2013, 02:58 AM   #5
retrosmiths
There's a guy here who made demon eyes using the BRZ trim as halos.
2013 Scion FR-S
Old 05-20-2013, 03:50 AM   #6
Mo707
Mo707's Avatar
My friend almost got arrested for having blue halo's here in CA. The cop said he would have been charged for impersonating a police officer. just a heads up.
Mo707 is offline   Reply With Quote
Old 05-20-2013, 04:24 AM   #7
BlueSTaR
BlueSTaR's Avatar
Yeah I figured it would be one of those things. Sucks, would look totally bad ass!
Old 05-20-2013, 07:47 AM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
This is awesome.
Red lights are illegal on the front of a car anywhere in north american, AFAIK.
Old 05-20-2013, 07:48 AM   #9
Calum
That Guy
agreed
Old 05-20-2013, 08:45 AM   #10
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
Looks nice! Great write up!
JWMotoring is offline   Reply With Quote
Old 05-20-2013, 08:45 AM   #11
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
This is one of those show mods IMO. Wire up a remote switch or controller so you can turn it on/off at shows etc.
Old 05-20-2013, 10:51 AM   #12
retrosmiths
Definitely a show mod. I had this on my tC and wired the halos and red eyes to the remote separately (4-channel remote).
2013 Scion FR-S
Old 05-21-2013, 08:40 PM   #13
Mo707
Mo707's Avatar
Oh i know and he knew it too. He was just trying to show off.
Old 05-23-2013, 05:19 PM   #14
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Beautifully done!
BRZ headlight upgrade, paint, demon eyes (PICTURE HEAVY) Lee358 Cosmetic Modification (Interior/Exterior/Lighting) 59 04-18-2014 12:42 AM
Demon Eyes retrosmiths Cosmetic Modification (Interior/Exterior/Lighting) 16 05-20-2013 12:55 AM
Will Demon Eyes affect light temperature output? (also the legality) boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2013 05:37 PM
My GT86 with Carbon Demon Makeover GT86FKINEL FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 10-30-2012 02:39 AM
Headlight lens question (demon eyes) WolfsFang Cosmetic Modification (Interior/Exterior/Lighting) 19 09-30-2012 02:58 PM
