Old 11-03-2013, 08:20 AM   #15
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Originally Posted by obriennathaniel View Post
interesting, let me know how that turns out because my smart start subscription is slowly waisting away.
Well. That part won't work for what I want to do either. It works great for a standard alarm but once the engine is started you are screwed. I think there is a CAN id in there that is looking for a running engine (engine speed rpm maybe) and once it sees this it ignores input. I am currently trying to find out what that id is so I can shut it off. The sense doors will always work and could be a problem when you are in the car with the doors locked. Someone might be able to grab the door handle and get into the car. If anyone wants to help me find the CAN location I would appreciate it
calispec is offline   Reply With Quote
Old 11-03-2013, 10:04 AM   #16
tinma
Drives: '13 BRZ
Subd as I am also interested in remote start
tinma is offline   Reply With Quote
Old 11-29-2013, 12:28 AM   #17
calispec
calispec's Avatar
I installed my smart start today.. Super easy install especially when you use the 1101t bypass. I think there were like 8 wires to hook up and no large gauge wires. Door locks are + so you need two relays for that. Clutch is + so you need a relay for that. And the push to start button needs a - trigger so I relayed the + starter wire to give the ground signal. Everything works. Door locks and trunk work while the car is running but ONLY through the phone. I am still trying to find a way to hack the BCM. This will at least keep me happy now that it's cold out. If anyone has any questions how I did it let me know and I'll do a better write up on it.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
Old 11-29-2013, 11:01 AM   #18
Screw Loose Dan
Drives: '14 BRZ
I would appreciate seeing any and all details you wish to share about the remote start installation.
Screw Loose Dan is offline   Reply With Quote
Old 12-02-2013, 07:49 PM   #19
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
I used to work at a car stereo place. HiFi Buys if anyone remembers that store. Anyway, we had installers that would install remote starters and you would do it thru the factory keyfob but you needed a module to do so. If I remember correctly, the "lock" and "unlock" buttons had to be pushed at the same time to start the car. Then unlock would unlock the car so you could get in the car. Lock would lock the door while car was running. But would also "arm" the alarm connected to the remote start. If the door was opened without "disarming" the car alarm, the light would come on as the door is opened setting the alarm off and enabling the engine immobilizer. I would imagine that same technology is around. I'm looking for a remote start system for my car now. Cant find who I want to go with. I heard bad reviews on the viper and python android phone systems.
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Old 12-02-2013, 08:02 PM   #20
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Originally Posted by calispec View Post
I think I may have found the key to the city. http://www.carboncarsystems.com.au/v...ubaru-brz.html this is an alarm made by DEI which ties into the CANBUS system of our car. The alarm is controlled by the factory key fob. It should also retain all functions for remote start functions. I am going to make a few phone calls tomorrow to verify but the best part about it is.... ITS ONLY $50!!! I'll let everyone know what I find out and I might do a DIY as well. Because it's a CANBUS alarm you really only have to tie in to 4 or 5 wires. STOKED!!!
The link I clicked says $259. Either the exchange rate is really bad or it's that expensive. Bummer, because I could really use a remote start but I'm probably not interested at that price.
DoomsdayJesus is offline   Reply With Quote
Old 12-02-2013, 08:27 PM   #21
calispec
calispec's Avatar
You can get them for 50 but they won't work for a remote starter any way.
@ravenblackfrs all that is possible. Just not with our vehicles. The VW's have the whole can network figured out and yes they can make it work. Tech stream may be able to tap into some of this and I am ordering a cable to see what I can do but I am not holding my breath. What I have done works but it's not ideal. It'll get me through the winter and give me some more time to try different options. I'll make a write up as soon as I have a little more time.
www.GT86Mounts.com
Old 12-02-2013, 08:39 PM   #22
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
so you got the remote engine starter working ? while retaining all the stock smart start features ?
ucsmfu is offline   Reply With Quote
Old 12-03-2013, 02:51 AM   #23
caffeinejunky
hella stock
caffeinejunky's Avatar
Drives: BRZ Limited
I havent really looked into it in detail, but we might be able to retrofit one of these into our cars (owners of limited brz's with smartkeys). Just a thought.
http://www.toyotapart.com/PT398-03120.pdf
Cost is $300 though, so unless someone already has this part on hand and doesn't mind testing...
caffeinejunky is offline   Reply With Quote
Old 12-03-2013, 08:11 PM   #24
calispec
calispec's Avatar
The smart start works as it should. There are a couple quirks. Because I used the 1011t the car starts fine. If someone were to smash the window and get in they could drive away. Once the car has been started there is NO way to shut it off without getting into the car and pressing the start/stop button. It will run until it runs out of gas. You can not shut the car down by using the app. When the car is started using the smart start the only way to unlock the car is by clicking the unlock button in the app. The key fob does. Not work. If you start the car with the app and your phone dies while you are walking out to your car you will be crawling in through the trunk.
These are all things I am trying to get around. It works just fine for the time being. It starts. And I can unlock the car from the phone when I am almost there.
www.GT86Mounts.com
Old 05-15-2014, 03:43 AM   #25
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
anymore info regarding the remote engine start ?
thanks
Old 05-15-2014, 03:25 PM   #26
calispec
calispec's Avatar
I have been meaning to do something with an arduino. I haven't looked to see if someone has come out with a new bypass module that will fix all these issues. Even if someone comes up with a bypass module I am 99% sure you will still have to carry around a second fob and I don't want to do that. I don't mind the hick ups. It works great for what I am using it for. As soon as I hook up an arduino I'll do a diy and post the code. Just need to find the time.
Also. I never noticed the key hole in the drivers door. You can use the key to get in that way if something goes wrong. Just don't start it unless you know you can turn it off.
www.GT86Mounts.com
remote start, smart start
Remote Start Anyone? arleewa BRZ First-Gen (2012+) — General Topics 43 08-20-2014 02:43 PM
Request remote start info Fallen hero Scion FR-S / Toyota 86 GT86 General Forum 0 12-21-2012 12:32 PM
Remote start installer in north nj Lee358 NY / NJ / CT / PA 7 08-22-2012 01:08 PM
Schematic for remote start install? empower-auto Electronics | Audio | NAV | Infotainment 3 07-31-2012 05:13 PM
Compustar needs a BRZ w/PTS for remote start info. burnt_rice Northwest 2 06-19-2012 05:31 PM
