Old 10-23-2013, 03:30 PM   #15
husker741
Originally Posted by thill View Post
The issues that have been reported with tracked cars should have been fixed with any car produced after January 2013. There was an update to the ECU which should prevent further damage to the direct injectors. As others have said, this issue seems to be pretty limited and there are lots of folks that have tracked their car with zero issues.
That said, if you are expecting to spend a lot of time at the track, you may want to spend some money on additional cooling (radiator, oil cooler, etc). Probably worth the peace of mind.
Have they made an ECU update to everyone or only people experiencing the issues? I've to the same sound this guy has... http://www.ft86club.com/forums/showthread.php?t=44851
husker741 is offline   Reply With Quote
Old 10-23-2013, 03:45 PM   #16
strat61caster
strat61caster's Avatar
No, only the cars rolling out of the factory after January 2013 have the updated tune, dealerships don't have the procedure in place to flash older cars with the newer flash. December production is still up in the air but definitely not November cars.
ineedyourdiddly
husker741 (10-23-2013)
Old 10-23-2013, 04:09 PM   #17
FR-S Matt
Going on 12k miles and my only issue is crickets. I don't see a problem with the engine. I had a slight idle issue breaking in, but that is completely gone. Running great and I am also Ecutek tuned now.
Old 10-23-2013, 05:31 PM   #18
Tromatic
Everything is fine. I have none of the problems posted all over this forum, other than the fuel-pump chirp and that does not bother me at all.
Tromatic is offline   Reply With Quote
Old 10-23-2013, 06:12 PM   #19
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Okay i don't poke my nose too much into this section
and i can't find any current stickies regarding this DI thing
what is the most current thread on the subject? As someone with one of the earliest cars i'm rather concerned...
Old 10-23-2013, 06:15 PM   #20
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
22 000 KM, may 2012 built date, everything's fine so far, I don't even have crickets *knocks on wood
Rayme is offline   Reply With Quote
Old 10-23-2013, 06:41 PM   #21
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
You'll find more info in the tracking/motosports section. But I wouldn't worry much if your car is used for street only.
iLuveKetchup is offline   Reply With Quote
Old 10-23-2013, 08:37 PM   #22
TeamZleep
Drives: 2013 FRS/2011 TDI
Going to hit 20k next week. I've had it since Jan.
No issues, Crickets are here and there (who cares). Not a darn thing wrong. I've given up worrying about little things and enjoy the car. So much better this way.
TeamZleep is offline   Reply With Quote
Old 10-23-2013, 09:12 PM   #23
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Originally Posted by iLuveKetchup View Post
Edit: Are you guys aware of the ringland issues going on with the 07+ STi engines. Subaru is not doing anything about that. Which leads me to second guess Subaru engine reliability (on their new cars).
Apparently those were also due to bad tunes and was fixed in 09 models. Dont think there were many, if any that failed at stock power. I know of a few that had ring failure over stock power though
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 10-23-2013, 09:18 PM   #24
MeFryRice
Drives: '13 SWP BRZ
THe ringland issue on Subaru's wasn't limited to the 07+ model but goes back to the 02+ EJ20 motor as well. The motors have a cast piston but can be fixed (or at least less of a worry) with a set of forged pistons.
Like others have already mentioned, why worry when the vehicle has a new car warranty? If you've already exceeded the warranty mileage and your're still concerned then trade it in on a new one or start budgeting for another motor. Every car is going to have their issues. I personally wouldn't loose sleep over it.
MeFryRice is offline   Reply With Quote
Old 10-23-2013, 10:22 PM   #25
ayau
Drives: Some rust bucket
I'm surprised you haven't seen it. It's been discussed in many threads in the track subforum. I don't believe there's a sticky thread.
Old 10-23-2013, 10:26 PM   #26
ayau
@iLuveKetchup, what's wrong with your track S2k and STI DD? Seems like the perfect combination.
Old 10-23-2013, 10:49 PM   #27
P5yk0t1c
Drives: 2014 FR-S
My motor was blown after 2,000miles. No racing, only street driving. They replaced the motor under warranty and it has been a nightmare ever since. Car has been in for service 13x in 6 months...I kept losing about 30% of power, so they checked the cylinders and said #2 is off, but within parameters....lol. So basically saying cylinder #2 is crap but just deal with it.
Like a doctor after a heart transplant, "Sir, your heart exploded, so we have replaced your heart with one that has 1 clogged artery...but don't worry...you'll be fine."
P5yk0t1c is offline   Reply With Quote
The Following User Says Thank You to P5yk0t1c For This Useful Post:
strat61caster (10-24-2013)
Old 10-23-2013, 10:54 PM   #28
iLuveKetchup
Drives: EFF JAY
Nothing wrong with it. I go through these phases with cars. Although I have a hard time letting go of the s2k. You should keep your BRZ!!
Has anyone had a warranty claim denied? Seized engine! Pics of teardown added 6/5 CSG Mike Issues | Warranty | Recalls / TSB 909 09-15-2016 11:31 AM
FR-S/BRZ MY13 vs MY14 whatsinaname FR-S / BRZ vs.... 7 09-13-2013 10:29 AM
MY14 BRZ HeubergerMotors Dealer Cars 9 08-06-2013 03:23 AM
will the MY14 be cheaper? EJ20 Scion FR-S / Toyota 86 GT86 General Forum 12 05-22-2013 11:01 PM
MY14 Production? Weeber Scion FR-S / Toyota 86 GT86 General Forum 9 01-30-2013 09:35 PM
