Old 10-13-2013, 02:05 PM   #15
JD86
Drives: 2013 Toyota 86 GT
I might be about to get murdered for saying this but changing that relay is really easy. Instead of trying to pry it off the little white hook that it hangs on and messing up your knuckles... Pull the hook down, it's just one of those plastic clips like they use to hold down carpet in the car. Then you can spin the flasher round and use a flat head screw driver to disconnect the cable from the flasher. Once the flasher is out of the awkward spot you can then swap the clip to the new flasher and reinstall. Took me about five minutes. Don't shoot me, just thought it might help anyone doing it in the future.
JD86 is offline   Reply With Quote
Old 10-13-2013, 02:57 PM   #16
Demotic
Drives: 2013 FR-S, IS-300, 2004 VW R3
Originally Posted by ScionFR-S View Post
beware when you install them , you will have blood dripping down your hands and may need a chiropractor after it from the awkward bending... make sure you disconnect the battery harness before install to prevent any popped fuses like i did and it caused the whole car to shut down and not turn on until i found the problem... just be careful =) and yes you def need the hyperflash relay
That wasn't that hard. What was hard was repinning the damn wires. Got me heated.
Demotic is offline   Reply With Quote
Old 10-13-2013, 05:06 PM   #17
Nassty
Drives: 13 FR-S, 08 ZX-10R
I never understood all the problems...Everyone makes it sound like hell but mine came out with a nice firm grip and a strong pull
I also didn't disconnect the battery and I was fine - just make sure you don't turn on the car or have it on at all when you pull the relay out
Nassty is offline   Reply With Quote
Old 10-13-2013, 05:28 PM   #18
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Same here. I just made sure I had grip, pulled, POP came out, swapped the plastic rivet to the new one, pushed back in. No blood, no sweat. Easy
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 10-13-2013, 06:46 PM   #19
BRAWL
Drives: Toyota 86 GTS Velocity Orange
Got it in and out in 5 mins no problems. Oh and that's what she said
BRAWL is offline   Reply With Quote
Old 10-14-2013, 12:15 AM   #20
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
she cant say that though unless she has a 8====D .... im glad it worked well for you though looks like the kitten murder police wont be coming to knock on your door
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Selling both rear OEM tails with amber LED turn signals ThaBigUnit Exterior Parts (Aero, Lighting, Etc.) 2 05-24-2013 02:33 PM
***FR-S/BRZ LED Turn Signals (6K WHITE/AMBER FOR TURNING, NO HYPER FLASHING!)*** Vicious LED Exterior Parts - The Rest 7 11-02-2012 10:05 AM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
Turn signal amber LED's flashing quickly michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 11 07-13-2012 10:55 PM
