Old 09-29-2013, 07:03 PM   #15
Frostyman
Drives: 2013 Raven FRS
Originally Posted by Dustin View Post
PST Carbon Driveshaft - 13.9 lbs - $1100
DSS Carbon Driveshaft - 12.2 lbs $1000
DSS Aluminum Driveshaft - 13.2 lbs - $438
Axle Exchange Aluminum Driveshaft - 12.? lbs - $425
How is Carbon DS > Aluminum? Explain that one to me.
An extra $600 - $700 to save potentially 1 extra pound of ratational mass does not seem "better" to me. And the only reason I say potentially saving 1 pound is if you were only looking at the DSS. You could potentially save approximately 1 pound of rotational mass AND save $675 if your two options were PST and Axle Exchange.
Just food for thought.
Honestly, the aluminum shaft will be better for most people, as it has a lower max torque application than the 1200hp rated carbon fiber ones.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
The Following User Says Thank You to Frostyman For This Useful Post:
cslntuee (09-29-2013)
Old 09-29-2013, 07:45 PM   #16
cslntuee
Drives: Subaru BRZ Limited
I doubt with these mods anyone would be worried about the noise level of adding a driveshaft.
Sorry. I am off the topic. I am asking my case which still keep the stock
exhaust.
I am still debating should go with carbon fiber or aluminum driveshaft.
I read both product description.
http://ft86speedfactory.com/drivesha...t-at-1141.html
http://ft86speedfactory.com/drivesha...t-at-1142.html
I notice that the carbon fiber one mention " it will also make a noticeable difference on the noise level in the car", but the aluminum one did not mention this benefit which bring my concern.
Thanks a lot for your suggestion.
cslntuee is offline   Reply With Quote
Old 09-29-2013, 07:56 PM   #17
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
carbon fibre is a vibration damper, compared to an aluminum driveshaft you will feel less vibration from the cars various rotating assemblies, conversely aluminum is lightweight sure, but it can transmit vibration instead of absorbing it. NVH from stiffer bushings such as rear diff cradle and even subframe locks will be less noticeable with the carbon shaft. atleast in my experience. carbon is worth the cost IMHO.
FreshFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to FreshFRS For This Useful Post:
akyp (09-29-2013), cslntuee (09-29-2013)
Old 09-29-2013, 08:05 PM   #18
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Taken from another thread in regards to the aluminum driveshaft......
Originally Posted by slates74 View Post
No notable increase in NVH and no vibration issues at any speed. Feels as smooth as stock, if not smoother. Shifts feel more positive when engaging into each gear. The only notable change in sound is that the typical noise you hear from the trans at low speed even with the stock shaft, is slightly more audible, likely because of the hollow construction of the driveshaft and the one piece design that removes all of the connecting points of the stock two piece driveshaft. I only noticed it the first time I drove the car and really can't tell the difference now.
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
Old 09-29-2013, 08:10 PM   #19
cslntuee
Will the carbon one slight increase in RWHP than aluminum one, due to
smaller diameter?
Thanks.
Old 09-29-2013, 08:19 PM   #20
Dustin
Twin Screw You
Dustin's Avatar
It won't increase HP so to speak. It only frees up power that was used to spin the extra weight in the factory drive shaft. That being said, the diameter doesn't matter so much as the weight does. The one with the lighter weight will not take as much power to spin as one with more weight. But the 1 pound give or take depending on the driveshaft with be almost negligible when considering the aftermarket options.
Old 09-29-2013, 09:11 PM   #21
cslntuee
I checked the testing result which only 4Hp different.
http://theattack.rallysportdirect.com/2012/09/new-products-brzfrs-pst-carbon-fiber-driveshaft
Is there any benefit for the carbon fiber one? I heard that 350Z( or 370Z)
and GTR using carbon fiber driveshaft.
I will go with aluminum one, if there is no benefit from the carbon fiber one.
Which aluminum one you recommend (Axle Exchange or Dss)?
Axle Exchange wrote "This one piece 3" aluminum shaft saves you almost 17lbs !"
Does that mean only 7.2 lbs (24.2-17)?
http://www.axle-exchange.com/inc/sdetail/29/399
Thanks again.
Old 09-29-2013, 09:55 PM   #22
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Originally Posted by Anthony View Post
Oh, and for batteries, the two best that I know of would be:
4.96lbs - Shorai LFX36L3-BS12 - ~$350
3.90lbs - Super B 10P - ~$750
Shorai is actually only $260. At least, that's what I paid from Amazon. Also does not absolutely require a special charger, either, according to the manual that comes with the battery. But if you do want to use the Shorai charger, it is a little over $75.
neurokinetik is offline   Reply With Quote
The Following 2 Users Say Thank You to neurokinetik For This Useful Post:
Anthony (09-30-2013), boxer 2.5 (09-30-2013)
Old 09-29-2013, 11:22 PM   #23
SPCorBUST
SPCorBUST's Avatar
Originally Posted by suaveflooder View Post
It sounds like you already pretty much know your answer. You will probably get about 20-30 horse overall to the wheels, but with the rotational mass being much lower, the car is going to clime the RPM range MUCH quicker.
This is the rout I'm going as well. It may not be a horsepower beast, but it'll still be quick
yeah i just wanted to get some confirmation
In the Open Tablet thread, it looks like they picked up ~20 from the tune on 91 alone... i'm optimistically hoping for ~50 but before I do any binge shopping on parts I wanted to see if anybody else has gone this route.
Here's my estimate, not sure how off-base it is, so corrections welcome:
Engine: ~2
Perrin crank pulley
Clutch: ~3
Undecided, lightweight street clutch and flywheel
Driveshaft: ~3
DSS or PST carbon fiber driveshaft
Fuel: ~20
e85 and 91 tunes, likely with OpenTablet
Exhaust: ~15
Borla UEL (sound profile, not max HP)
Perrin overpipe
Perrin catted front pipe
Invidia N1 exhaust
Wheels: (maybe)
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 09-29-2013, 11:26 PM   #24
SPCorBUST
SPCorBUST's Avatar
I said as far as weight goes, for which you proved my point
I did not claim that one was "better" than the other... No need to get the panties in a bunch. :happy0180:
Thanks for providing the weight of the other shafts, I was wondering about that. Cool note, if anybody is interested in the DSS shaft they have a nice video about their process and testing them as well!
Old 09-30-2013, 01:17 AM   #25
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Oh man, I didn't know the Axle Exchange one was that light. I'll have to look into that one.
The carbon fiber ones are rated for that much!? Last I saw, their limit was still unkown to the community. I can't remember specifically which one the thread I was reading was talking about, but holy shit, 1200hp?! Strange they rate it in horsepower and not torque, though.
Oh man! I was just going off Shorai's website. Didn't realize the savings elsewhere. And are you implying the Super B one will or might need a special charger?
Maybe @JRitt can give some insight on living with a Super B battery.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-30-2013, 01:52 AM   #26
Dustin
Twin Screw You
Dustin's Avatar
No panties in any bunch. I come off very direct at times I guess but was only trying to inform. I don't see how I proved your point though. Unless I read your statement incorrectly which is possible. When you said greater than (Carbon DS > Aluminum) I took that as you meaning the carbon was better than the aluminum. Did you mean that the weight of the carbon was greater than the aluminum? Meaning the carbon ds is heavier?
Old 09-30-2013, 02:44 AM   #27
Anthony
Weight Nazi
Anthony's Avatar
Originally Posted by StormTrooper View Post
Never mind I didn't read the post lol
LOL @ reason for editing. Yeah, I don't remember what you had said, but I remember being confused by it, haha.
Old 09-30-2013, 05:05 AM   #28
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Haha op, I knew your sn looked familiar...I was on srtforums with you! Morgantj13 on there, with flame red srt.
Sorry for being off topic lol
Ill probably see you one of these days, I'm no longer in OC, but I'm up there a lot for work/family.
The Following User Says Thank You to continuecrushing For This Useful Post:
SPCorBUST (10-02-2013)
TRD CAI and Exhaust HP Gains tennisfreak Engine, Exhaust, Transmission 51 11-08-2016 08:30 PM
ECU HP gains? ender2664 Engine, Exhaust, Transmission 45 03-31-2013 03:33 PM
Torque gains, what does the job? JoeBoxer Engine, Exhaust, Transmission 21 10-01-2012 05:46 AM
Biggest gains yomchi1989 AUSTRALIA 5 09-28-2012 07:31 PM
Exhaust HP Gains FoolCyclist Engine, Exhaust, Transmission 79 06-22-2012 12:47 AM
