#15 |
NASA SpecE30 Racer
If in the proccess of dying it got too much current or something melted such as some contacts then it is possible. What did the dead bulb look like inside?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#16 | |
SLO NO MO
Perhaps a short inside the plastic base that I can't see from outside? Sent from my Nexus 4 using Tapatalk 4 |
#17 |
NASA SpecE30 Racer
That would be my guess. I would be worried about the design of the wiring that is feeding it as it may just happen again in the future.
- King Tut
#18 |
Drives: 2013 FRS
Sorry for bringing up an old post. I am having a similar issue. I installed the phastek 4th brake light kit using the tap connectors supplied. It has been installed for years. I havent noticed any issue the whole time. I recently realized it wasnt working.
Assuming a burnt out bulb I bought a new sylvania silverstar bulb which is what the kit came with. Still didnt work. I purchased a harness that connects to the brake light that has wires coming off to connect to the 4th brake light instead of taping into the stock wiring. I removed the old connectors verified only insulation on wires were damaged and shrink sleeved over the exposed portions and reinstalled with the new harness. Light worked again. I then noticed that when I hit the brake it dims the clock and turns the aftermarket head unit backlight on. This seems to correct if the headlights are turned on. I removed the wires from the new harness and it fixed the problem. I then removed the bulb and this also corrected the problem. I tried the second bulb in the package and even the old bulb and had the same issue with them all. Is there a special bulb to use to correct this issue? Or am I stuck living with it or not having a 4th brake light? |
#19 |
not playing cards
I'll guess that the incandescent bulb load takes the whole system over the top. Try using an LED bulb instead.
| DIY-- How to bypass your NAVI without moving out your NAVI (Canadian BRZ only) | 8987846 | DIY (Do-It-Yourself) Guides | 77 | 04-29-2015 01:45 PM |
| Pressing/releasing clutch pedal - audible click sound (not the clutchs switch | tanner | BRZ First-Gen (2012+) — General Topics | 26 | 06-03-2014 08:24 PM |
| Bypassing your NAVI without moving out your NAVI | 8987846 | CANADA | 0 | 12-24-2012 02:20 AM |
| CLOCK QUESTION | poudre | BRZ First-Gen (2012+) — General Topics | 16 | 07-02-2012 02:20 PM |
| Details: Interior dims, glass, light bulbs | Ryephile | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 03-01-2012 10:28 AM |
