Old 12-07-2013, 08:37 AM   #15
wparsons
wparsons's Avatar
Very cool, I thought about doing this but then tinted the tails all red.
I was considering it so that I could replace the bottom of the bumper with a proper diffuser, but decided against all that anyway.
flickr
Old 12-07-2013, 11:06 AM   #16
fuzzymachinist
Drives: '13 FRS MT
Real reverse lights
Edit:
fuzzymachinist is offline   Reply With Quote
Old 12-23-2013, 07:09 PM   #17
psuoh
psuoh's Avatar
Drives: scion frs 2013
Diode dynamics Stage 3 reverse lights
I think Stage 3 LED reverse lights and bright LED plate lights from Diode Dynamics would have achieved the same result without all that unnecessary wiring and voiding your warranty. Changing OEM bulbs don't void your warranty. it has a forward-facing projector lens LED chip so you can probably adjust the angle so the lights focus more up and center then towards the ground or maybe one point towards ground and one up and center.
Stage 3: 50W LED. Each of the four sides of this bulb contains two 5W-rated CREE chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
http://www.diodedynamics.com/store/l...leds-pair.html
psuoh is offline   Reply With Quote
Old 12-23-2013, 07:23 PM   #18
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
@psuoh
There is a little something called exposure. Those lights aren't THAT bright. I didn't get my reverse lights form DD, but an equivalent quality vendor on the forum and they still suck.
Old 12-24-2013, 03:28 PM   #19
fuzzymachinist
Drives: '13 FRS MT
Real reverse lights
Edited
Old 12-24-2013, 03:44 PM   #20
Diode Dynamics
Diode Dynamics's Avatar
Originally Posted by boredom.is.me View Post
@psuoh
Not all LEDs are created equal. The circuitry and effective brightness of a bulb can vary wildly based on the design. Just because it looks the same while off does not mean it looks the same while on.
While yes, that picture specifically is high-exposure, our bulbs provide a measurable increase in total lumen output - a high quality 18w 921 bulb produces, at maximum, 300 lumens. Most generic ones like those supplied OEM only output closer to 250 and cheap ones can only output as low as 200.
Our stage 2 LED bulb produces 300 lumens, and stage 3 produces over 500. We have made a big investment in scientific equipment at our location to test this kind of thing, unlike most other suppliers here.
Our general advertising pictures are shot individually with varying levels of exposure. In contrast, our comparison pictures are professionally shot (by that I mean professionally-trained, degree-holding photographers, not amateurs) with the exact same settings to provide a direct comparison of the difference in brightness. See comparison of stock 921 18W, stage 1 (SMD) and stage 2 (hi-power) here:http://diodedynamics.com/images/glob...comparison.jpg
Stage 3 is brand new, we'll be re-shooting a direct comparison in the next few weeks. This is not a "sales pitch," we have a lot of people here at Diode who know what they're doing, so please don't immediately assume you're getting "equivalent quality" from a different vendor.
Now, all that said, this is still a great idea and we'll be providing an easy-to-install kit to achieve the same effect soon.
Thanks,
Paul
John C.
Diode Dynamics
Old 12-24-2013, 04:57 PM   #21
kthxbai
kthxbai's Avatar
Drives: '13 Whiteout FR-S M/T
Not to take away from the work that @fuzzymachinist put down, I've loved this idea since I first saw this post. However, I'm not very confident in reading wire schematics and wiring in general. I would b very interested in a plug and play type option @diodedynamics.
Sent from my KFTT using Tapatalk
kthxbai is offline   Reply With Quote
Old 09-03-2014, 06:54 PM   #22
DC2R
Drives: 2014 Scion FR-S
bump @Diode Dynamics! whats up with the kit? im going downstairs to start building something i came up with...
DC2R is offline   Reply With Quote
Old 09-03-2014, 07:22 PM   #23
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
So, @Diode Dynamics, if you could potentially make a switch back work in the sense that, when it receives the reverse signal it would turn on the white LEDs how much would that run? It would also need to have a different plug so that you could add the reverse signal wire from the original spot to the signals. Did any of that make sense?
thatfilipinoguy is offline   Reply With Quote
Old 09-04-2014, 10:02 AM   #24
Diode Dynamics
We'll be releasing our nearly plug-and-play kit at the end of this month.
Stay tuned!
John C.
Diode Dynamics
Old 09-04-2014, 10:56 AM   #25
DC2R
Stay tuned!
As always you guys are awesome! I "completed" my setup last night. Still need to do some testing and cleanup the wiring a bit. Not sure if I'm getting enough power to run 4 high power led bulb assemblies from just the green lead running to reverse lights in trunk....
Sent from my SM-N900T using Tapatalk
Old 09-14-2014, 02:59 AM   #26
DC2R
Here's my mod. Still looking forward to @Diode Dynamics though.
http://www.ft86club.com/forums/showthread.php?t=74163
Old 09-14-2014, 09:27 AM   #27
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Just found it. Thanks.
Old 09-26-2014, 12:30 PM   #28
Sportsguy83
Drives: Limited BRZ
Stay tuned!
The clock is ticking.......
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 07:42 PM
HID Reverse Lights mezdup Cosmetic Modification (Interior/Exterior/Lighting) 10 06-19-2013 04:47 PM
reverse lights xdbuix Cosmetic Modification (Interior/Exterior/Lighting) 8 06-11-2013 10:00 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
GTA: CREE Reverse Lights Selvedge Canada Classifieds 0 12-27-2012 06:37 PM
