Old 06-18-2013, 01:30 PM   #1
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
HID Reverse Lights
anybody do it? i've found some 15W T10 kits online and am kinda interesting in doing it as LEDs are just useless. my brake lights provide more light when i'm reversing than my LEDs. and yea i could go back to stock bulbs, but i'd rather keep it white all around.
if you have done it, where'd you buy it from and what are your thoughts?
mezdup is offline   Reply With Quote
Old 06-18-2013, 04:32 PM   #2
DIM
I've heard stories on other forums that people don't use HID's as reverse light's cause it'll melt the housing.
DIM is offline   Reply With Quote
Old 06-18-2013, 04:39 PM   #3
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
I have LED reverse lights, but to be honest, it doesn't really make a difference in lighting, it just looks better. I got mine from a vendor here, just look in the lights section and you'll see them. I got the max reverse titans or something like that.
Old 06-18-2013, 05:02 PM   #4
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I believe HID's run a lot cooler than incandescent bulbs. Has someone confirmed their housings melted or was it just a thought? HID kits are so cheap these days, it's not a bad idea. I'm personally trying to find a bright set of license plate lights that look like the IS350 (uniform blanket of light) and not 2 white bulbs beaming down on the plate...not doing HID for that lol.
Old 06-18-2013, 07:35 PM   #5
mezdup
#1362
mezdup's Avatar
Yea plus since they're reverse lights they won't really be on for long periods of time
Sent from my HTC Rezound using Tapatalk 4 Beta
Old 06-18-2013, 07:37 PM   #6
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
Problem is they take a minute or two to warm up. The LED backup lights I got from a vendor here are really nice and bright.
Narcoden is offline   Reply With Quote
Old 06-18-2013, 09:26 PM   #7
KI_ZN6
KI_ZN6's Avatar
There are different LED upgrades for reverse lights and they vary in brightness:
http://www.ft86club.com/forums/showthread.php?t=11815
KI_ZN6 is offline   Reply With Quote
Old 06-19-2013, 02:11 AM   #8
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
HIDs are not meant for reverse lighting. best stick to nice LEDs
mrlewistan is offline   Reply With Quote
Old 06-19-2013, 02:12 AM   #9
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
quick bursts are bad for HID bulbs, thats why they shouldnt be used in our highbeam slots.
The Following User Says Thank You to mrlewistan For This Useful Post:
mezdup (06-19-2013)
Old 06-19-2013, 04:40 PM   #10
iJDMTOY
iJDMTOY's Avatar
Drives: 2008 Honda Civic Si
Most HID reverse lights are rated at 15w which is much lower than the traditional 35w and 55w kits out for the headlights/fog lights. Melting the housing shouldn't be an issue since you are not going to be staying in reverse long enough (for most cases at least), but it can still happen if its on long enough.
Personally, I would go with an LED setup for the reverse lights since the light is instant and is already at maximum brightness whereas HID's require warm up time, typically 5-10 seconds and it would suck to just sit in reverse for a few seconds just to warm it up to see behind you.
iJDMTOY is offline   Reply With Quote
The Following User Says Thank You to iJDMTOY For This Useful Post:
mezdup (06-19-2013)
Old 06-19-2013, 04:47 PM   #11
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
The only person who needs HID's in her reverse lights is this kid!
Honestly, it's a waste of time since you only reverse for a short period of time.
[ame="http://www.youtube.com/watch?v=Ivmr0MoGKVs"]Boy racer tries to outrace police - on the wrong side of a dual carriageway - YouTube[/ame]
The Following User Says Thank You to RRnold For This Useful Post:
jbsali (06-25-2013)
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 07:42 PM
reverse lights xdbuix Cosmetic Modification (Interior/Exterior/Lighting) 8 06-11-2013 10:00 AM
Water in reverse lights roddy Scion FR-S / Toyota 86 GT86 General Forum 30 05-09-2013 09:18 AM
Reverse Back-up lights mit_peid Electronics | Audio | NAV | Infotainment 2 05-04-2013 07:04 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
