Old 09-14-2014, 02:47 AM   #1
DC2R
Drives: 2014 Scion FR-S
My Auxillary Reverse Lights "DIY"
Much like most of you I was quite disappointing with the output of my reverse lights. I was used to the Cree Projector R4 LEDs in my GS-R.
I went through a few pairs of replacement LEDs and finally settled with the strongest HIDPowerhouse bulbs.
http://hidpowerhouse.com/shop/hybrid...sbrztoyota-86/
Light Output was still subpar. So I ordered these:
http://www.banggood.com/Wholesale-Pa...t-p-48922.html
I tried to get specs from supplier but no luck. They seem like direct driven LEDs.
I Had to drill out my plate and my plate frame to make room for the LED bolts to fit through. I didnt have the proper size bit so my modifications are far from OEM-looking.
Next step is to remove the plastic pieces in the trunk that the plate screws screw into. This can be done by compressing them with pliers and pushing them out through the exterior.
Next just pop the plate back on, put the LED bolts through the holes, and thread on the nuts on the back.
I still need to clean up the wiring on mine but basically you need to tap into the green reverse wires for positive and you can use the black for negative. I used vampire taps as to not mess up the the factory wiring too much. Yes I know i should have put the fuse on the positive side but I had already crimped the positive side when I realized I had run out of the counterparts to the vampire taps. I honestly just used the fuse because it was the only thing I had on me that fit into the tap.
Perhaps a proper relay setup would provide more power to the bulbs but I didn't notice much difference when supplying separate power. Without knowing the specs of the bulb it makes it much less than an exact science.
These LEDs don't provide much throw but every little bit helps. They also provide some needed illumination up high.
I currently just have my wires hanging loose. I'd like to run them though the trunk wiring loom when I get a chance.
I am also interested in @Diode Dynamics reverse kit coming out soon. Anyone try these out?: [ame="http://www.amazon.com/gp/product/B00JK020H2?ref_=wl_it_dp_o_pC_nS_ttl&colid=1KHSZJU BXVB0J&coliid=I3PQ1VDSFVY9FB&pldnSite=1"]Amazon.com: iJDMTOY (2) 30W High Power CREE XP-E 912 921 920 906 LED Replacement Bulbs For Car Backup Reverse Lights: Automotive[/ame]
DC2R is offline   Reply With Quote
Old 09-14-2014, 02:50 AM   #2
DC2R
Don't know why one pic came out sideways but that is the one showing the output before the mod.
Old 09-14-2014, 09:22 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks man.... Now MAKE THE MEETS!!!!
Old 09-14-2014, 02:55 PM   #4
Diode Dynamics
Diode Dynamics's Avatar
Cool stuff! Indeed, we will have a very nice option soon to add a pair of real backup lights to your vehicle with no cutting or major wiring.
This looks pretty good though, definitely a big improvement!
John C.
Diode Dynamics
Old 09-14-2014, 02:57 PM   #5
DC2R
Ha ha yeah next one Thursday?
Sent from my SM-N900T using Tapatalk
Old 09-14-2014, 02:59 PM   #6
DC2R
Thanks guy. Yeah, the stock housing is just atrocious. Perhaps 3 sets of reverse bulbs will make reverse lighting functional lol!
Old 09-14-2014, 03:04 PM   #7
Sportsguy83
Drives: Limited BRZ
Next one Oct. 25th at Markham Park.
Old 09-14-2014, 04:22 PM   #8
DC2R
Hope it cools down by then!
Old 09-20-2014, 12:12 AM   #9
DC2R
Cleaned up the wiring. Ran out of wire or I would have made it look better. Cables now properly routed through trunk wiring loom boot thingy.
Old 09-20-2014, 12:20 AM   #10
DC2R
Cable routing.
Old 09-20-2014, 12:25 AM   #11
DC2R
Old 09-26-2014, 12:28 PM   #12
Sportsguy83
Drives: Limited BRZ
Attachment 91334
Bro, the red cable looks SICHKKK.. oh wait....
Old 09-26-2014, 01:29 PM   #13
DC2R
It's pretty hard to get. Had it overnighted from Japan.
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 169 08-20-2016 01:15 PM
"Genuine" reverse camera manboobs AUSTRALIA 35 09-13-2013 08:35 AM
USDM "TOM'S Style" Special Edition Tail Lights (DOT/SAE Approved) --- Pre Order 86_ZN6 Exterior Parts - Lighting 248 08-15-2013 11:13 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 187 05-15-2013 01:07 AM
