Drives: '13 FRS MT
Real reverse lights
EDIT: An update on my original setup, after about a month it became apparent I couldn't use these most of the time I wanted more light, other drivers were around, I disabled them. I looked for a bit for real aux reverse lights, similar to fog lights with a flat upper cutoff, but nothing would easily integrate into the rear of this car. So there you have it, $100+ later I would have been better off leaving stock alone and not putting an illegal setup on my car, yes illegal. All exterior lights are regulated for output, directional intensity is VERY important and my setup overpowered a light with a proper cutoff with a massive blinding flood light.
EDIT: TL,DR don't waste your money like I did, stock is as good as it gets without a real custom setup to mount real aux reverse lights. My setup was without question illegal and was removed about a month after install, being an illegal setup I chose to remove the how-to. It's not a hard setup, but I'm not interested in giving a how-to on an illegal setup. Last edited by fuzzymachinist; 11-30-2014 at 06:13 PM. |
Drives: '13 FRS MT
Real reverse lights
Edit: deleted
Drives: 2013 frs
Thats interesting
Where'd you purchase the switchback's from? Link.
Drives: '13 FRS MT
Real reverse lights
Edit: delete
Drift King
Drives: '13 Firestorm FR-S 6MT
Wouldn't you be able to just tap the wire which produces the white leds to go on into the wire that sends the signal to your stock reverse lights? That way they go into white mode when you're in reverse?
'13 6MT Firestorm FR-S
DADA
Drives: 2013
This is a better option. I actually made a small harness at work to do this but I decided not to and instead bought super bright lights
Drives: '13 FRS MT
Real reverse lights
Edit: too bright, illegal etc
#1362
Drives: 2014 Ice Silver WRX
great idea
#10 |
Thanks for the right up!
#11 | |
Drift King
#12 |
Drives: '13 FRS MT
True, they are used in the front as parking lights but for me after tieing directly to the reverse lights I thought they were too much and needed a switch. Just test them with a test lead before hacking up your factory harness if you have any question about it.
#13 | |
Drives: MKVI VW GTI
Is this as easy as tapping into the hot for the reverse lights, and sending that to the power for the LEDs? I really know nothing on the subject of wiring and whatnot, but my driveway is impossible to negotiate in the dark and this would be a huge help. |
#14 |
Memphis
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Did you tint your reverse lights at all?
"It's ok... It's not structural."- Mikey
| **PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) | PhastekSport | Exterior Parts - Lighting | 18 | 07-09-2014 07:42 PM |
| HID Reverse Lights | mezdup | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 06-19-2013 04:47 PM |
| reverse lights | xdbuix | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-11-2013 10:00 AM |
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 08:38 PM |
| GTA: CREE Reverse Lights | Selvedge | Canada Classifieds | 0 | 12-27-2012 06:37 PM |
