Old 08-23-2013, 12:16 PM   #15
Djen
Drives: GT86
I have never ever seen boost creep on my FBM kit, only boost loss in the upper RPM range. I would say there might be an exhaust leak at your wastegate.
oooh don't tell me that how can I tell if there is leak in wastegate and what the cuases to leak? there is no loud or exhaust sound from the front if the engine
Djen is offline   Reply With Quote
Old 08-23-2013, 12:17 PM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It will be hard to tell since it might only show up when you are boosting hard. I would look for black marks on the flanges showing exhaust escaping. What style MBC is the Full Blown one? I didn't even know they sold one.
Old 08-23-2013, 12:19 PM   #17
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Originally Posted by Djen View Post
what can I do im using two of T brass tees that's not good at all or?
Why? Just plumb it direct to turbo. Why on earth are there 2 tees? Splitting one source of vaccuum/boost multiple ways is bad.
A goo rule for any "sound" build. Boost referenced fuel pressure regulators, map sensors and wastegates get their own dedicated boost source.
Everything else doesn't matter.
Toma is offline   Reply With Quote
Old 08-23-2013, 12:34 PM   #18
Djen
Drives: GT86
ill tell tee T brass from the intake manifold gose to left for BOV and the right goin to anther .tee T brass the the one down gose to Boost Gauge and the right goin to boost controller and the left connectd back to the manifold I hope its clear to you
Old 08-23-2013, 12:44 PM   #19
Djen
Drives: GT86
this is the manifold I cant snap shot the one down there I already connect tee T brass goin left for BOV and right For Anther Tee T brass
this is the 2st Tee T brass coming from the connectd 1st T brass manifold. the down for Gauge and upper goin to boost controller.
Old 08-23-2013, 12:46 PM   #20
Djen
Drives: GT86
by the way the 1st Tee T brass not clampd on any ways or zip ties.. and if this wrong way im doin it please help me fix it
Old 08-23-2013, 01:00 PM   #21
Djen
Drives: GT86
what about Boost Gauage?
Old 08-23-2013, 01:21 PM   #22
Toma
Boost gauge, blow off, all that extra crap is not critical.
Good install practice is as I said...
Wastegate gets it OWN pressure source, preferably right from the compressor housing.
Map sensor gets it's own source.
Fuel Pressure regulator (in the case of return style rising rate systems) Gets its own intake manifold source.
I am not saying this is your problem, but it is how it SHOULD be done.
Old 08-23-2013, 01:52 PM   #23
DJCarbine
Thupercharged
DJCarbine's Avatar
Run a line directly from your compressor housing to the wastegate.
If there is no boost creep, I would suspect your boost controller.
2013 FRS
Vortech V3 11psi
Old 08-23-2013, 01:55 PM   #24
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The Garrett compressor housings don't come tapped for a vacuum source. My recommendation has always been to run a vacuum manifold off one of the two vacuum hoses that come off the back of the intake manifold.
Old 08-23-2013, 02:10 PM   #25
sw20kosh
Drives: 2013 Black FR-S
Like I said, if you want to diagnose this problem you are going to have to remove the boost controller from the equation. Connect boost or manifold source directly to wastegate. See if there is still creeping going on.
Old 08-23-2013, 02:42 PM   #26
DJCarbine
Thupercharged
DJCarbine's Avatar
I've drilled/tapped compressor housings in the past to solve that issue. I like running my WG signal as close to the compressor as possible
Either way, I think isolating the boost controller is a good first step in troubleshooting the creep
2013 FRS
Vortech V3 11psi
Old 08-23-2013, 03:04 PM   #27
Raven604
Swat come into my house., disrespect my family, and do you know what. It was you!
Sent from my SGH-I337M using Tapatalk 4
Raven604 is offline   Reply With Quote
Old 08-23-2013, 03:07 PM   #28
charged86
charged86's Avatar
I never narced on nobody
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Jet. Boost build. jet86 Member's Car Journals 310 10-06-2015 10:41 AM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
E85+boost subatoy Forced Induction 5 11-06-2012 11:55 AM
any way to reduce or eliminate "idle creep"? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 8 07-03-2012 02:00 PM
AE86 w/F22 + Boost Dragonitti FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 01-09-2011 01:06 AM
